Question about King Kutter Tow Behind Garden Tractor/Atv Compact Disc
Can't find manual on line for 33 inch harrow ATV disc
I could not locate the manual for 14-10-CD 33 inch harrow on line. I just bought one and was wondering if it could be hooked up with 3 point hitch to my Kubota and not just the 1 7/8" ball. Also I need to know how to adjust the force down on it with the rod that can be shortened or lengthened. This is my first experience trying to turn soil.
Thanks,
TJ
Mototech mini quad. Where do I charge it
Looks like you need a battery charger. It has two 12 volt batteries. Didn't it come with a charger? And your parental control is via a key.
The MotoTec 24v Mini Quad v2 is the ultimate kids atv! Great for driveway and backyard fun, cruise over bumps and speed through dirt trails with ease. Comes standard with front & rear suspension, front & rear brakes and large 13 inch knobby pneumatic tires. This mini quad provides longer ride times than the competition with TWO large 12v 12amp hour batteries. New features include: headlight, key start, battery meter, forward & reverse, 2 speeds selectable by key and twist throttle with safety foot switch. SAFETY FIRST - ALWAYS WEAR YOUR HELMET AND ALL SAFETY EQUIPMENT AND OBSERVE SAFE RIDING RULES!!! Motor: 24 Volt 350 Watt
Battery: TWO 12v 12ah (24v Total)
Top Speed: 5 & 10 MPH (parental speed control by key) Recommended Age: 6+ years old (A parent's decision to allow his or her child to ride this product should be based on the child's maturity, skill and ability to follow rules.)
Max Rider Weight: 150 lbs
Frame: Steel
Tires: 4.10-6 Knobby Pneumatic (13 inch)
Brakes: 2 disc front, 1 disc rear (with parking brake)
Suspension: 2 independent front shocks, 1 rear shock
Throttle: Variable twist-grip (with safety foot switch)
Seat: Padded (single rider)
Handlebars: Adjustable Forward/Back
Battery Meter: Yes
Key: Yes
Headlights: Yes
Charging Time: 4-6 hours
Charger Included: Yes
Assembly Required: Yes
ATV Size: 42x23x25 inches
Handle bar height from ground: 25 inches
Seat height from ground: 19 inches
ATV Weight: 101 lbs
Box Size: 43x25x22 inches
Box Weight: 114 lbs
Product decoration and specifications subject to change without notice.
Warranty: 30 days parts replacement
MotoTec 24v Mini Quad v2 Blue
Dec 09, 2015 | MotoTec Kids ATV-24v Mini Quad
Wher can I view a on line ownersmanual for a 1999 tl bose cd disc changer
What is the exact modle number to your Bose Changer? If you send this information, along with your email address, I'll send you copy of it if I have in my manual library, by return mail.
Apr 28, 2012 | Audio Players & Recorders
I have an old Curtis Mathis direct drive turntable that I bought in 1984. The arm needs to be adjusted so that it will line up with the 33 rpm record. It currently lines up about 1/2 inch outside of the...
hi,
power off and remove from mains. put the arm manually to the center of rotating plater(end of the record) it will stop. from there slightly push the arm to the center little ( do not use more pressure). the take back it to the arm rest. power it on and test it. watch the difference. need more do the same again.
ok
Dec 24, 2010 | Audio Players & Recorders
Hi have just bought this used item ,no manual unfortunately,but have tried 2 diff.CDR recordable discs & all i get after reading is,wrong disc & use audio cd, hope you can shed some...
There are 2 types of recorders. Professional, which you can use any kinds of cdr blanks and the Consumer, which requires to use
"Audio or Music only" discs and harder to obtain locally nowadays, but probably plenty on line.
Oct 04, 2010 | Marantz DR-6000 CD Player
I bought a Yardman 21" Series 560 self-propelled mower used and the belt was missing. What belt does it take? The manual says 754-04080, but I'm looking for a locally available V-belt. Thank you.
Are you sure the belt part number is not 754-04088?
That is a 33 inch belt. I do not know if you need the 1/2 inch or 3/8 inch wide belt. Pulley size would be the key for belt width. I think it is 1/2. Any local source automotive parts or Lawn Mower supply will have this belt in stock. 1/2 x 33 or 2L 33
If by chance I got the belt part number wrong, (I don't think so) just respond here and we can keep searching for your belt.
Thanks for using Fixya.
Kelly
Jun 17, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
I just bought a Vivicam 8025. It comes with a 3 inch disc with user's manual. I cannot use a three inch disc in my computer. I can take pictures, but the camera won't save them. It says my disk is full....
hi
the 3inch disk fits into the same drive as your cd just place it in the center depression of the CD/DVD drive
as for the disk full error check to see from the camera settings if you have set to save the photos on the camera or on the memory card
cheers
pls rate if it was any help
Jul 03, 2009 | Cameras
33 inch Panasonic gaoo bought in 95 picture trble
Check for leaky capacitors in the vertical section of the TV or cold solder joints.
I would also check in the power supply.
Good Luck.
Jan 16, 2008 | Televison & Video
Xbox360
Depending on the type of disc drive that you have in your Xbox 360 console, use one of the following methods:
Method A: Insert a straightened paper clip or another small, stiff wire into the first hole from the left side of the disc tray. To release the disc tray, push the paperclip into the hole to press the manual eject mechanism. The manual eject mechanism is a white lever that is visible behind the console casing. The hole is located about one-and-a-half inches (approximately four centimeters) from the left edge of the disc tray.
Method B: Insert a straightened paper clip or another small, stiff wire into the second hole from the left side of the disc tray. Push the paperclip repeatedly into the hole to turn a gear to release the disc tray. The hole is located about one-and-a-half inches (approximately four centimeters) from the left edge of the disc tray.
Method C: Insert a straightened paper clip or another small, stiff wire into the into the hole that is directly under the "X3" in the Xbox 360 label on the disc tray to release the disc tray. The hole is located about one inch from the right edge of the disc tray.
In each case, make sure that you line up the paperclip or stiff wire to pass through another notch behind the hole on the console casing.
Oct 17, 2007 | Microsoft Xbox 360 Console
King Kutter Tow Behind Garden Tractor/Atv Compact Disc Logo
49 people viewed this question
Top King Kutter Garden Experts
Jay Finke
Jay Finke
George Merkley
George Merkley
john h
Are you a King Kutter Garden Expert? Answer questions, earn points and help others
