Question about Amana ABD2533DES Stainless Steel Bottom Freezer Refrigerator
Temperature frigeration air flow very weak and refrig section barely cold, freezer all ice has melted to water
  • Amana Master
  • 17,970 Answers
Won't cold enough or poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt. Firts check this components...
Evaporator coils
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: - The defrost timer - The defrost thermostat (also called the bi-metal switch) - The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser
Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Tell us news.
Posted on May 11, 2010
GE Side by Side Refrig - loud noise behind the ice maker section Model PSS25SGMB BS
it sounds like the evaporator fan blade is hitting some ice that has built up around the blades i have seen this happen a lot on g.e. SxS lately,if you can remove the ice maker and dispenser you can see the fan blade,if you dont want to do this then shut down the refrigerator and leave freezer door open and heat it carefully with a hairdrier to speed the process up to melt this ice then restart it and the noise should be gone
Aug 30, 2012 | GE PSS25SGNBS Side by Side Refrigerator
Have ge gt mdl# gts22jbpbrww. the freezer is cold but the refrig is not getting cold. I took apart the cover showing me the freezer fan and it is not working could this be why the refrig is not getting...
Yes, if the fan is not forcing the cold air from the freezer section to the refrigerator section, then it will be warmer than it should be. Also check to make sure that the cooling tubes aren't blocked with frost/ice. If you put a hair dryer to the cooling tube openings you should feel the air flow on the other side.
Sep 06, 2011 | GE Refrigeration 21.8 Cu. Ft. Top-Freezer...
I HAVE A SIDE BY SIDE REFRIG. THE FREEZER WORKS FINE, THE OTHER SIDE IS BARELY COOL. WHAT COULD BE WRONG? THANK YOU
the damper vent door from the freezer to the refrige located between the 2 sections has frozen shut and cannot open to let cold air into the refrige from the freezer,its behind a plastic grille near the top of the units divider you should be able to hear a fan in this area too its in there open this up and defrost with a hand held hair dryer if iced over,then make sure fan is operating,then move the temperature control and see if it opens up
Mar 22, 2011 | General Electric Kitchen Ranges
My maytag refrig. is 3 years old. model #747908 HS520AS. freezer on bottom-refrig on top. the refrig part is not staying cold. have cleaned under frig and vaccumed back and underneath and it still is not...
All the cooling coils for this model are in the freezer section. There is a fan down there behind the back wall on the top. This fan directs air up to the fresh food section.
Check the temperature of the freezer you can do this by inspecting the ice cream, if the ice cream is soft you are above 5 degrees F. If you have a good cold freezer then the problem is with air flow, the evaporator fan that I spoke of could be bad).
If your freezer temperature is not as cold as it should be you may have a defrost problem, look for any signs of frost build up on the back wall of the freezer section, if you see frost you will most likely need to put in a new control.
If the freezer temperature is warmer than normal and you do not have frost you may have a sealed system leak, this will require a technician for sure.
Apr 18, 2010 | Maytag Refrigerators
Water wont dispense but still makes ice. Also fridge side gets extremely cold no matter the settings and freezes stuff in the bottum drawers
Since your freezer control is the main thermostat , and your refrig control is only a damper , lower your freezer setting and turn the refrig control mid way . This will make the refrig run less , and keep the air flow moving , throughout the complete unit . When the airflow stops , by turning down the refrig control ( closing the damper ) , all the cold air will settle in the refrig section , thereby freezing everything in the lower section .
Since the water line runs thru the freezer door , too cold in the freezer section , will cause the water in the line to freeze . I would also suggest installing a dispensor heater ( pt. # WR49X10173 ) , which would hopefully avoid water line freeze , in the future . This part comes with installation instructions .
Nov 08, 2009 | GE Monogram® ZISS420DMSS Side by Side...
ED25PQDW01 side by side refrig -freezer is inconsistent. Need to have full cold to maintain freezer temp. cleaned coils, but still an issue.
Do you see a light coat of frost in freezer section about 12 inches up (defrost problem indication) ? Has the icemaker slowed down a bit in ice production ? What is the refrigerator control set on ? When you turn the freezer up completely , it cuts off the cold air flow which cools the refrig section . If refrig control is set mid way , turn it up higher , so refrig will run longer , but lower the freezer setting so some cold air will enter the refrig section . Also check to see if the freezer fan is working .
Aug 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The freezer works but no cold air in frigerator in side by side unit.
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 14, 2009 | Refrigerators
Freezer will not keep foods frozen fridge will not keeep temp.
Sounds like a main control board problem keeping the freezer fan from working . If no air flow to the top of the freezer , the icemaker will stop working and the ice will begin to melt ( leaking from freezer ) . The coils will start to freeze up due to no air flow across them . If continued for a period of time , the cold air could return thru the return vent located in the bottom of the ref/freezer section and freeze the water tank in the refrig section , causing the no water thru dispensor .
Jul 11, 2009 | Hotpoint HSS25GFP Side by Side...
Maytag Refrigerator
You don't have enough cold air circulating over into the refrigerator section. This is usually controlled by an adjustable "flap" or door which is hooked to a conrol knob. When you rotate the knob you change the size of the opening which controls the air flow to the refrigerator secton. Also you may may have something blocking this air flow -- --- - like a wrapper from an ice cream bar, etc. Try to find the opening between the freezer and refrigerator sections and look for an obstruction.
Stargazer
Mar 19, 2008 | Refrigerators
Open Questions:
Amana ABD2533DES Stainless Steel Bottom Freezer Refrigerator Logo
63 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
