Question about Hoover F5866-900 SteamVac Deluxe Wet/Dry Vacuum
Brushes won't turn.
The square drive slot that the square drive pin, on the brushes, fits into does not turn to operate the brushes. everything else works fine. I removed the cover to find the housing where the drive slot lives but could'nt gain access to see inside. is there a belt in there or something inside that I might be able to fix or replace? Unable to locate the manual to see if problem would be corrected by something I forgot to do, since the steamvac is'nt used all the time. Any suggestions?? Thanks
  • 25 Answers
The drive is an geared assembly you will have to buy the whole turbine assembly, they are rarely fixable, but you can try taking apart cleaning and regreasing, if you can remember how to reassemble it. make sure you give proper model of machine to ensure you get correct turbine as there are many different models of these steamers
Posted on Mar 28, 2008
Brushes aren't turning. switch is on
Remember that the brushes turn best when the handle is tipped back. If this does not work, remove the brush assembly and insert a flat screwdriver into the square hole that the pin on the brush usually fits into. Try to turn the fitting. If it won't turn, the air driven turbine has seized up and will require replacement.
Jul 26, 2011 | Hoover SteamVac F5914-900 SpinScrub...
The brushes won't spin. I put new brushes on and it still doesn't spin.
Usually when the brushes won't turn it is due to a bad turbine. Insert a screwdriver into the square hole that the pin on the brush fits into, and see if it turns. If it is seized up, the turbine assembly will need to be replaced.
Jun 28, 2011 | Hoover SteamVac F5914-900 SpinScrub...
The brushes on my hoover f7411-900 carpet cleaner will not turn. any ideas? thanks, Hank
The most common reason for this is that the air driven turbine that turns the brush has seized up. To test it, remove the brush and insert a flat screwdriver into the square hole that the pin on the brush normally fits into. If you can't turn the fitting with the hole in it, the turbine assembly will need to be replaced. ( part # 91001019 ) - msrp $19.99. Be sure the square pin has not broken off from the brush assembly, as this is another possibility.
Apr 29, 2011 | Hoover Vacuums
My model F5906-900 --- problem is the brushes have stoped working... I pulled the brush assembly out by holding the two tabs, and all seems clean and the brush assembly rotates easly... onced the brush...
(1) Assure the Brush Control on the hood is NOT set to the OFF position.
(2) Remove the brush assembly by pulling/unlatching it from base on each side.
(3) Does one of the brushes have the drive pin present? It should be about ¼ inch square, and two inches long. It attaches the brushes to the drive mechanism.
(4) Remove and clean the intake filter. One the base of the cleaner, behind the brushes, squeeze the two red abs together and pull the panel down to access the screen. Clean the hair/debris off the screen and reassemble.
Mar 10, 2010 | Hoover F5906-900 Upright Steam Vacuum
BRUSHES NOT TURNING
Dec 31, 2009 | Hoover F7220900 SteamVac V2 Upright Vacuum
I have a Hoover SteamVac SpinScrub. The brushes
If the speed control switch on the hood is in the On position, it would appear the drive mechanism for the brushes is not spinning internally. The drive mechanism could easily be replaced by a technician.
Oct 03, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Brushes on hoover deluxe steam vac cvarpet cleaner are not rotating. Took out the brush assy and drive spins slowly but with little torque. Cannot seem to open the bottom to see if belt or direct...
(1) Assure the brush shut off lever on the hood is not set to the off position.
(2) Is there still a square pin standing up from the one drive brush? It should be 1/4 square, and about two inches tall. That pin is the drive from the transmission to the brushes.
There are no belts. The transmission is air and gear drive mechanism.
Oct 02, 2009 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Brushes will not turn
(1) Remove the brushes by pulling down at the ends.
Is the square pin present on the top of one brush? It should be approximately 1/4 inch square, and two inches long. That connects the brushes to the drive mechanism.
(2) Assure the manual shutoff on the hood is not set to OFF, for the Brush Speed
(3) Remove and clean the filter screen under the cleaner. This should be a red panel, behind the brushes. Squeeze the two tabs, pull down the panel, and clean the hair/debris off the filter screen.
Sep 29, 2009 | Hoover SteamVac F5914-900 SpinScrub...
My hoover carpet scrubber the brushes won
(1) Remove the brush block and assure the presence of the square drive pin on top of one brush. It should be about 1/4 inch square, two inches long to connect o the drive mechanism.
(2) Remove and clean the filter screen from the base, behind the brushes. Squeeze the two red tabs together, and pull down from the base. Clean the hiar/debris from the screen.
(3) Assure the Brush Speed knob on the hood is NOT set to the OFF position.
Aug 30, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Roomba Discovery
The plastic gears that drive the sweep brushes strip out easily on these. You can get the company to repair it for you but they make it a big hassle. I opted to buy the gear set on EBAY and replace them myself.
Dec 04, 2007 | Roomba Robotic Floor Bagless Vacuum
Hoover F5866-900 SteamVac Deluxe Wet/Dry Vacuum Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
