Question about Kohler Miller 907209 Bobcat 225 Welder Generator
NEED A STARTER SWITCH DIAGRAM FOR BOBCAT 225 PERFORMER ONAN ENGINE
2 Suggested Answers
wentlanv
  • 710 Answers
SOURCE: How do you drain the
Hi pplmelita,
If you don't have a petcock to turn the fuel off below the tank, I would disconnect the line at the filter and drain the gas out that way.
If you're wanting completely drain all old gas out, drain as above and then run until dry.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on May 14, 2011
Location of oil switch onan motor miller welder
Hi Martin,
I do have this site that has manual for you in order for you to locate it and its function as well. Hope it helps.
https://www.millerwelds.com/pdf/spec_sheets/ED4-4.pdf
Apr 26, 2014 | Bobcat Miller 225 Welder Generator 907209...
My bobcat has an onan mtr it wont stay on only on the rabbit
Float level may be low or high. There may be dirt in the low speed circuit of carb. Ot may also be a defective needle and seat or even a sunken float. If you eun E10 or E20, you may have corrosion in the carb from sitting- Ethanol absorbs water from the atmosphere.
It may also be an issue of the fuel quality too. If the gas sat for any length of time, volatility is impoaired. Especially with oxygenated fuels.
Sep 28, 2012 | Bobcat Miller 225 Welder Generator 907209...
Bobcat starter stays engaged
Trace the wire from the "st" on the ignition switch to the small post on the starter relay or solinoid. If you find another wire going off from there follow it to the diode. It is likely covered with insulating sleeve at one end of the wiring harness. It is about 3/8" in dia and 3/8 long.Please note the colored band at the end which denotes the cathode.It must be replaced with one going the same way..
Hope this helps, Robert
Aug 16, 2012 | Bobcat Welding Tools
SHOP MANUALS
http://www.millerwelds.com/om/o4434b_mil.pdf For the Onan engine
if you have the Robin, Kohler or other engine, just go here:
http://www.millerwelds.com/service/ownersmanuals.php?model
Scroll down to the bobcat 225 welders and select the correct or closest to yours as you can. your serial number did not cross.
For servicing the engine itself, I can find the specs, but Onan is quite tight with their manuals and discontinue a great deal of them so parts would need to be aftermarket in many cases. You might find hardcopy on Ebay, but the basics of teardown and inspection are the same across most of the flat twins.
Jan 20, 2012 | Bobcat Miller 225 Welder Generator 907209...
How do I remove and replace a fuel tank on a BobCat Miller 225 Welder Generator model no. 907209 or 907210
Which engine on your unit do you have?
Kohler
Robin
Onan
Subaru
Diesel
There are 11 different 225 models there shoule be 2 letters in front of your model number I need those letters.
The 907209 is a 23 Hp Kohler engine unit and the 907210 is a 22 Hp Robin(Onan) unit.
Parts list
http://www.millerwelds.com/om/t4434l_pt_mil.pdf
Looking at the slot in the side of the fuel tank it appears that the bottom pan has to be separated from the unit. That would involve unmounting anything with wires attached from the base and supporting them. Engine frame, transformer / reactor, side panels, end panels battery and lower brace. I don't see any other way. I would try working from the engine end.
In all seriousness
I would contact Millerweld here: http://www.millerwelds.com/service/contactus.html
Mention your on a very remote worksite, have the replacement part in hand and would like to know if there was a service manaul or any techical assistance available for the tank change.
Even with my 40 years of experience this would be a task I would have to study up close and personal to sort out exactly what the sequence would be to change the tank. It appears to be a very major evolution that could go very wrong very quickly resulting in some major damage if you are not careful.
Kelly
Sep 16, 2011 | Garden
Need manual for miller bobcat 225n the engine is an onan performer 16
Millerwelds.com Owners manual. You can download any manual for any miller product they have ever made for free. Here is the link. Download to your pc/print out whatever works. i always save a copy of my welder to the pc for future reference.
http://millerwelds.com/om/o4434b_mil.pdf
Aug 04, 2009 | Welding Tools
Kohler Miller 907209 Bobcat 225 Welder Generator Logo
309 people viewed this question
Top Kohler Welding Tools Experts
Bill Boyd
Are you a Kohler Welding Tool Expert? Answer questions, earn points and help others
