Question about Maytag MED5600TQ Electric Dryer
My dryer has a rumbling noise when starting. It is 14 yrs old. the noise subsides after the intitial start. Are there pillow bearing in these dryers?
  • Maytag Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryermy dryer has a rumbling noise when starting. - 2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Posted on May 12, 2010
I have a Whirlpool Duet Dryer about 4 years old. It just began making a screeching sound at startup. I say startup because it subsides after awhile. It sounds like a bad bearing , but acts like its a bad...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 06, 2011 | Whirlpool GEW9250 Electric Dryer
LG Model DLEX7177RM makes a rumbling noise upon start up like a bad bearing or gear drive sound. Noise is cyclic at dryer spin speed. Dryer is only a couple years old. Are there any recalls, warranty...
heatman101
Asker
Jan 02, 2011 | LG Dryers
High pitched squeal when running. Capacity Plus Gas Dryer ten years old.
tumble dryer / twin tub is making a loud rumbling noise when running, unplug it, take the rear cover off and remove the drive belt. Then turn the inner drum by hand. If there is a grating noise, the bearings will almost certainly need replacing
Mar 09, 2010 | Dryers
Maytag dryer makes rumbling noise when drum starts and again when
Sounds like a broken spring or a spring mount.
Jan 17, 2010 | Maytag Dryers
MayTag Neptune MDE6800AYW dryer drum making rumbling knocking noise
Have someone change the bearing, it sounds like it has busted on ya. The rumbling sounds like the ball bearings in the bearing have failed.
Jul 09, 2009 | Maytag Neptune MDE6800 Electric Dryer
Grinding Noise
Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Hope this helps.
God Bless.
Jul 08, 2009 | Maytag MED9700S Electric Dryer
Hi, my GE model DBXR463ED1WW dryer is LOUD!
Roaring could be an over firing burner or fan related. Squeak or rumbles are bearings. Is the noise all the time or only when the burner is on? Eric
Jun 20, 2009 | GE DBXR463EBWW Electric Dryer
Dryer makes rumbling sound when starting
If you remove the front cover and access the blower fan and see if it is still tight on the shaft. if it isn't it makes a rumble sound when started due to vibrating and after a while it makes more noise as it goes. Now I removed the fan and placed a shim in the flat area and matched the flat area of the shaft and replace it back on the shaft and it should solve it.
Mar 21, 2009 | Maytag MDE2600 Electric Dryer
Electric dryer makes a rumbling when tumbler is turning.
Check the drum bearing, a load noise, and often spinning problems are symptoms of a bad drum bearing.The bearing is at the base of the drum and accessing it is not easy.
You can find diagrams and replacement parts entering model number here.
Jan 06, 2009 | Maytag PYE2300AY Electric Dryer
Maytag MED5600TQ Electric Dryer Logo
69 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
