Question about Hotpoint Washing Machines
WMA 48 machine about minute into wash cycle door warning light comes on have changed lock but it still does it
  • leslie_hyde May 11, 2010
    PERHAPS THE EXPERT SHOULD READ THE PROBLEM IT IS NOT THE DOOR SWITCH THAT HAS BEEN REPLACED
  • 15,935 Answers
Have you tested the wiring TO the lock to be sure there is not an issue there?
Posted on May 11, 2010
  • 11,896 Answers
The door switch is likely faulty and will have to be replaced. You can get the parts and diagram from the partselect website.
  • Nate Stansfield
    Nate Stansfield May 11, 2010
    DID YOU REPLACE THE SWITCH OR THE LATCH? They are two different parts!
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Is the washer is going into wash cycle within one minute or the washer is not advancing the cycle? Please elaborate to enable me to provide further assistance.
Thanks
Rylee
Tecnik Washing Machine 9290 Red light not gone out so not able to open door. I switched it off by mistake but put it on and did the whole cycle again but still on and unable to open door . Please help
from the manual always WAIT.
DOOR
Use the handle to open the door.
During the wash and dry cycle, a special safety device keeps the door locked.
To open the door, turn off the machine using the ON-OFF push-button and wait about 30 seconds after the switching off the warning light before turning the handle to open the door.
also...
WARNING: Set the cycle only when the machine is off. - Always turn the control dial clockwise. If you pass the desired position, make a complete turn and reset the dial to the
exact position.
Jul 25, 2016 | Tecnik Washing Machines
I need help with my Duet washer
it sounds like an electronic problem with the board.
Nov 07, 2013 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool 6th sense washing machine with a warning light coming up and F13 on it.This machine is only 6 months old
f13 is a problem with the door lock, I have the same machine and it takes 4 minutes for the door latch to open and if it dont in the 4 minutes F13 comes up and the machine will go off and not start again.
Sep 30, 2010 | Washing Machines
When my hotpoint wma 48 is on a wash cycle water starts seaping through the front door. Gets worse when it goes on to the spin cycle. Please help
Clean the door itself and the door seal. close the door and give the glass bowl a tap at the bottom where it meets the seal with your fist this should do it.If not change the door seal
Jun 11, 2010 | Hotpoint WMA48 Front Load Washer
Wash cycle will not start door locked led flashes
sound like water has been splashed over circuit
board. dry out and replace any damaged components.
Mar 15, 2009 | Hotpoint WMA31 Front Load Washer
Front loader washing machine
This is normal, the unit usually goes into a SD or slow down mode. To stop this press the start pause button and the door will unlock.
Sgt 48
Jun 04, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Hotpoint aquaruis extra WMA A34 WASHING MACHINE
hellooooooo
Well its either the door interlock or the pcb behind the control panel....
What sometimes happens is that the door lock will blow the the pcb obard if there is an electrical short and if so you will need to replace both..
however sometimes its just the door interlock..
if you need advice on how to get to it then let us know cheers
Jan 11, 2008 | Washing Machines
Maytag neptune washer
Doesn't your unit have a lock light in addition to an on light? On mine when you start the machine a red light comes on, then after a minute or two the lock light above it comes on. Once the lock light lights, the machine shouldn't stop. If only the initial light comes on, the door isn't locking. As a result, as the drum moves the clothes and they push against the unlocked door, it turns the machine off. You might need to check/tighten the door latch. Also check the door wax motor/door lock assembly.
Dec 10, 2007 | Maytag Neptune MLG2000A Front Load Stacked...
Bosch Nexxt Essence Washer
start a cycle, once the door lock light comes on pull on the door to see if its really locked if not, you need a new door lock assembly
Nov 12, 2007 | Bosch WFMC2100UC Nexxt Essence Washer
Washer door pops open during wash cycle
Start the washer in a cycle. When the door locked light comes on, before unit gets to full of water, see if you can pull door open. If so, you probably have a broken latch. The wax motor is activating the switch, but latch is not actually closing. There was a door latch upgrade for some of these models.
Oct 06, 2007 | Maytag MAH6500 Neptune Front Loading...
Washing Machines Logo
32 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
