Question about Canon PIXMA MX850 Multifunction Printer
Magenta does not print.
Have troubleshooted but nothing works. Can I replace the print heaed?
  • 2,404 Answers
I would try replacing the magenta cartridge first. If it still doesn't print magenta after a cleaning then you can replace the print head, its located here:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=290420606793&rvr_id=&crlp=1_263602_263622&UA=%3F*F%3F&GUID=880ec7f81280a0e202d52fe5ff07cb54&itemid=290420606793&ff4=263602_263622
Posted on May 11, 2010
Hp 3600n laster printer has started printing pink blothes on pictures
You probably have a defective magenta cartridge. To test that you need Print Test Quality pages.
1. Press Menu to open the MENUS.
2. Press to highlight DIAGNOSTICS, and then press .
3. Press to highlight PQ TROUBLESHOOTING, and then press .
The message PRINTING... PQ TROUBLESHOOTING appears on the control-panel display until the
printer finishes printing the PQ troubleshooting pages. The printer returns to the Ready state after
the pages it produces are individual colors, black, magenta, yellow and cyan and a white page and a config sheet.If the defect is on all pages then it might be a bad transfer belt. If it is only on one of the color pages, that will tell you which cartridge is bad.
Mar 11, 2011 | HP LaserJet 3600n Printer
NO YELLOW ON MAGENTA ON PRINTOUT
your printer's gear box time seting is not in its place so you dont have the right colors
Jun 17, 2009 | HP LaserJet 3000 Printer
Only black and blue will print on test page; yellow and magenta does not. Ink was just replaced.
Did yellow and magenta print OK before the previous cartridges ran out? If so, it looks like your new cartridges are not working properly. Try another yellow and magenta cartridge - you can re-use the previous cartridges if they turn out not to be faulty. If new cartridges don't solve the problem, you can try soaking the print head, in case you have nozzles blocked with dried ink for some reason.
Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If you get any magenta/yellow ink on the nozzle check, then there is hope! Repeat the head clean/nozzle check process 2 or 3 times, but not more. Leave for 24 hours for any air bubbles to disperse. If nothing, repeat the soak process once more. If still nothing, post a new comment detailing what you have done and the results.
May 04, 2009 | Epson Stylus C86 InkJet Printer
Magenta ibk problem
Have you tried running head-cleaning cycles? If not, try 2 or 3 followed by a nozzle check and see if magenta starts to appear. If this still produces no magenta print, or you've already tried this with no success, report back.
Feb 01, 2009 | Epson Stylus C84 InkJet Printer
Phaser 8560 magenta ink not transfering to paper
Hi jbasset285: Your printhead may be bad do to third party ink.
Try these steps first.
Diagnosing Print-Quality Problems
The Troubleshooting Print-Quality Page provides a good overview of the most
common print quality problems. To print the Troubleshooting Print-Quality Page,
follow these steps:
1. From the Control Panel, scroll to Troubleshooting, then press OK.
2. Scroll to Print Quality Problems, then press OK.
3. Scroll to Troubleshooting Print Quality Page, then press OK.
The Troubleshooting Print Quality Page includes instructions for printing the
Eliminate Light Stripes test print. These instructions are also provided on the next
page of this manual. The Eliminate Light Stripes test print indicates individual weak
or missing jets or an obstruction in the imaging path that affects a vertical band down
the entire page. Also, you may see color variation from jet to jet on the Eliminate
Light Stripes test print. Some variation is normal, occasionally occurs, and usually
self-corrects within a few printed pages. If a print-quality problem is not resolved
with the information provided in the Diagnosing Print-Quality
Nov 26, 2008 | Xerox Phaser 8560DN Laser Printer
Mfc 3249c
Ensure that you are replacing the cartridge with a Brother LC41M ("M" denotes magenta) cartridge instead of replacing it with a "knockoff" (third-party equivalent) or refilling the cartridge. Some third-party inks -- found in many knockoffs and ink refill kits -- do not work well with their intended cartridges and/or print heads. I discovered this the hard way, and then verified it with representatives of HP, Canon and EPSON.
If you have tried two or more actual LC41M cartridges and still receive the Near Empty error message, your unit might need service. Contact Brother Customer Service for further troubleshooting -- see page i of the Users Manual. (Opening the Users Manual with this link requires a PDF viewer such as Acrobat Reader or Foxit Reader.)
Feb 29, 2008 | Brother MFC-3240C All-In-One InkJet...
Canon pixma 3000 not printing magenta at all
you have a blocked print head on the printer. you can try this removed the print head place it small amount of metho this could removed the blockage not always. i deak fix is to replaced the printer head .
Nov 22, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
First, wouldn't print black, now won't print magenta- all new cartridges!
Unplug machinepowercord. Open printer and take all carts out. Plug in power. Machine demands carts. Put new one in: Replace with original ink carts!. When asked push 1 (yes New cart). If you have used thirdparty carts, there could be a prob due to construticon or ink quality. In case there is no bk after 3x cleaning cycles anymore, the head is clogged: This happens because the filter in front of the nozzels is clogged by pigmented ink. DO USE ONLY DYE INK for all types of brother inkjet machines!!!
Sep 24, 2007 | Brother MFC 420CN All-In-One InkJet...
Canon PIXMA MX850 Multifunction Printer Logo
282 people viewed this question
old marine
old marine
