Question about OKI C9300 Led Printer
I have repalced 2 fuser unit in a okidata c9300 and the both can up with a fatal 176 error. how can i fix it.
  • 4,924 Answers
First check not to be an issue with the mobile parts inside...after you are sure that all is ok mechanical..you should reset it to fix errors...Im not sure for the model ..but if it is not specified the procedure in the user guide(usually it is if has unusual way to reset) ..than you should try the general way ...and shut it down ..remove cord...put it back after 30 sec..than power it up,,and when you do that keep the power button pressed for 15 seconds...or try to keep it and release it every 5 seconds..if it beeps..Most models do reset on this if they do not have reset in the menu ..or special buttons or combination of buttons ...
Posted on May 12, 2010
177 Fatal Error
Error 177: Thermistor indicates Low Temperature (COLD) Error.
Usualy the fuser has overheated first (error 172/176) and tripped the thermal protection causing the fuser not to heat up anymore.
Normal procedure if a restart doesn't fix it is to replace the fuser unit.
Dec 29, 2010 | Xante CL30 HSE Laser Printer
I have changed the fuser unit in a okidata c9300 and still getting a 174 fatal error. how cani i fix this problem?
First of all unplug the printer from the mains (safety first). Get the toner out again and check for dirt on the contacts. Also check the contacts inside the printer itself.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs".
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 11, 2010 | OKI C9300 Led Printer
I have an OKI 5650 printer and am getting a 172: Fatal Error - how do I fix this?
Abnormal temperature
detected by
fuser thermistor
(high-temp or low
temp.)
Turn power ON again.
Replace fuser unit.
Feb 12, 2010 | OKI C9300 Led Printer
Fatal error 173?
It points to an internal error. It may be from the fuser unit. Make sure all the wires are connected praoperly and that you didn't disconnect anything when you repalced the fuser. If the problempersists, you'll have to take it in for service.
Aug 20, 2009 | OKI C5150n Led Printer
I just replaced the fuser unit in my Okidata 5200 and it will print for awhile and then stop with a fatal error #177. How do I fix this?
lift your top cover up and check the ribbon cables to the black leds (4) under the cover 2 on each led, these have been known to be loose and cause those fatal error codes
Jul 09, 2009 | Office Equipment & Supplies
Service Call 172 Fatal Error
Hi stuart34:
Here is your problem.
Service Call
172: Error
176: Error
High temperature
error detected at
Thermistor.
1) Is the error message displayed?
2) Does the error repeat?
Yes
Yes
Turn off/on the printer.
Replace the Thermistor and turn off the
1 Upper roller 2 Lower roller 1
b
Thermostat Thermostat
Heater Between pins a and b:
Between pins c and d: 231.4kω
Between pins e and f: 231.4kω (at 25°C)
Between pins c and d: 0ω or open
Fuser Unit
a
b
Heater
e
f
Thermistor
c
d
Fuse
e
f
Thermistor
c
d
printer. Leave it for 30 min.
The Thermistors are located in the fuser assembly.
Hope this helps
May 29, 2009 | OKI C9300hdn Led Printer
Okidata c5200n printer 173:FATAL ERROR. What is this? How do I fix it?
In the fuser unit the Heat roller thermister indicates a low temperature error. Replacing the fuser unit will usually resolve this. Fuser units are consumable items bur for an early life failure such as this it may be worth contacting the manufacturer.
Mar 11, 2009 | OKI C5200n Laser Printer
Error number 172
the problem is on the fuser unit, ther thermistor on it is damaged.
Jun 02, 2006 | OKI C9300 Led Printer
OKI C9300 Led Printer Logo
47 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
