Question about Car Audio & Video
Ok i have a 1999 mazda protege nice car but when i put a cd in, it spits it back out right away how could i fix this ?
  • adamlovelady May 11, 2010
    thank you so there is no way that i could fix this ?
    President:
  • 1,297 Answers
Assuming you have tried more than one CD then your problem is the optics in the CD player and they only cost effective fix is to replace the radio
you can take it out and try someone to fix it, but I know in my area there is no one that will touch a stock radio
even the dealers will not send it out for repairs
MOST factory radios are considered disposable
Posted on May 11, 2010
  • Sean Reisdorf
    Sean Reisdorf May 11, 2010
    well... if you are lucky, and don't mind spending more to fix this radio than actually buying a new aftermarket radio you could contact Mazda directly to see who manufactured this radio and then sent it back to them
    anything CAN be fixed, but the cost to fix it will almost ALWAYS exceed the cost of replacement
    if you want to try something, go to either Best Buy or Radio Shack and ask for a CD cleaner.... you need the type that looks like an actual CD but its got a cloth texture.... this may clean the optics but I haven't seen these around anymore but maybe because I haven't been looking since they never solved my optic concerns
Where can I download a manual for 1999 Mazda protege car
You may be able to download the owner's manual at the Mazda owners site but if you need the a service and repair manual you must buy it, try eBay for a used one.
Nov 02, 2016 | 1999 Mazda Protege
Can you show me a diagram of an egr valve for a 1999 mazda protege?
https://www.google.com/search?biw=1536&bih=710&tbm=isch&sa=1&q=99+mazda+protege+egr+locaton&oq=99+mazda+protege+egr+locaton&gs_l=img.12...21014.28237.0.31287.18.14.1.2.2.0.139.1095.13j1.14.0....0...1c.1.64.img..2.7.396...0j0i30j0i8i30j0i24.6332pmbkKZI#imgrc=jJ5CIOyc_k3dbM%3A
Oct 04, 2014 | 1999 Mazda Protege
When starting the car, its runs fine for a moment then it seems like when the motor starts warming up it is right on the brink of dieing so i then have to feather the throttle to try and bring it back
now with all of these facts do it spend alots of gas than usual ?
to fix the problem change some thing is called oxygen sensor and your problem is done ;)
Nov 25, 2013 | 1999 Mazda Protege
1999 mazda protege when starting of at a slow speed the car starts to buck and o/d light will flash
The tube after the air filter might be cracked (Fix it). Next the you will see the Mass Airflow Sensor. Unplug that and see if you car runs differently (better while driving, worse while idling). If so then it is definitely the MAS (Mass Airflow Sensor). There is actually a recall on this part (at least, for the 2000 Protege). Also, try cleaning it and plugging it back in. Change spark plugs (OEM only, nothing fancy). Also, some gas does this worse than others.
Jan 26, 2010 | 1999 Mazda Protege
Lots of oil leaking how many seals are there that could leak and is it a big job to fix. the leak appears to be on the back drivers side of the engine, it is a 1999 mazda protege 4 cylinder
you need to clean the engine off and fill it with oil,put your car on a hoist to find the oil leak when it starts so it doesn't run to other places and you think its leaking there.
Dec 18, 2009 | 1999 Mazda Protege
2000 Mazda Protege has problem taking gas in.
Does this happen no matter what gas station you go to? If so then you may want to carefully check inside the the gas fill tube. If there are no obstructions then check the gas fill hose itself for kinks.
Apr 24, 2009 | 2000 Mazda Protege
How do I replace the bulb for the headlight on a 1999 protege?
First I removed the power connector by squeezing the sides of it. Then you have to pull back the rubber hood from the light. Remove it completely and lay it aside. After that I pushed downwards on a metal tab to unhook a clip that holds the bulb in the mount. The tab is on the side of the bulb that is away from the motor. The bulb will come out easily then. Note the way it comes out and put it back the same way. There are 3 tabs on the bulb housing that need to go in the same place they came out of. This keeps the bulb secure I think.
Mar 30, 2009 | 1999 Mazda Protege
1999 Mazda Protege balloint
that nut is welded on the frame hopefully its not strip because yes you have to drop the frame good luck pierre
Sep 17, 2008 | 1999 Mazda Protege
Car Audio & Video Logo
21 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
