Question about Hotpoint RGB745 Gas Kitchen Range
Bake display pad
The display pad on the console of my stove got warped during the self cleaning oven cycle. I need to replace the wee plastic display thingy. How do I order such a thing? ( It's a Hotpoint RGB745).
    President:
  • 1,314 Answers
Contact ge and order a touch pad but tell them it melted during self clean and they just might give you one its 1-800-ge-cares ask for customer relations not cust service
Posted on Mar 28, 2008
Bake element wont cycle the temperature
PDF]ELECTRONIC OVEN CONTROL Control Pad ... - Frigidaire
manuals.frigidaire.com/prodinfo_pdf/Lassomption/318204143.pdf
Note: The oven function will not work if the time of day clock is not set. ... The ovencan be programmed for any temperature from 170°F to 550°F (77°C to ... Can be used with BAKE TIME to program a delayed bake cycle. Timer Pad- Used to.
[PDF]ELECTRONIC OVEN CONTROL Control Pad ... - Frigidaire
manuals.frigidaire.com/prodinfo_pdf/Lassomption/318204125.pdf
cycle. Bake Time- Use to enter the length of the baking time. Timer ON/. OFF- Use.... It does not disable the clock, Kitchen Timer or the interior oven lights. TIMED. DOOR .... The Preheat feature will bring the oven up to temperature and.
Gas Oven Repair Manual - Chapter 6 ' Gas Ovens Manuals
www.appliancerepair.net/oven-repair-6.html
If it does not ignite, you certainly do not want the gas valve to stay open. ... these sensor bulbs do not cycle the burner on and off to maintain oven temperature.
How To Fix An Oven Door That Won't Open After A Self ...
Jan 28, 2016 | Frigidaire Kitchen Ranges
I have an electric stovetop and did a self cleaning it would not unlock so i turned off breaker and was able to unlock when i did the baking element was so brittle that it snapped and now all the burn
Ok,... First, and foremost, stop using the self clean. It takes the temperature up to 900 deg F, and creates all sorts of other problems with the lock motor and the walls and the bake/broil elements. Use a Low odor Easy-off spray cleaner to clean your oven from now-on, please.
Now, the bake element needs to be replaced. If you have the model number (found on the body of the Range behind the lower drawer, if you pull it out) I can look-up the manufacturer's suggested part to be replaced. You may also need to replace the broil element, but that usually is the last element to burn-out as most people don't use the broil function of an oven.
You will have to pull the range away from the wall, and unplug it before you attempt to replace any parts. No need to have 240 VAC/30 Amps running through your body. There are several black 1/4" screws that secure the back panel on the oven section to the body (about 6 to 8) and they will have to be removed to pull and replace the wires on the oven bake and/or broil elements. You will also have to go to the oven door (on the front of the range) open it, and remove the two 1/4" screws that secure each element to the body before you can change-out the element(s). The most popular bake elements for GE Ovens are part #WB44K10005 and/or WB44T10010, but there are other Bake elements. Will need the model of your Range to ID the correct element and the cost.
Now as for the rest of the burners on the stovetop not working, they are usually independent from the oven functions, which are wired into the controller in the center of the range control console, but there are a couple of GE models that wired the stove burners into the oven timer/controller. If this is the case, then you may also need to replace the oven timer/controller.
If the stove elements are independent and are only wired to the Infinite switches that control the front left, rear left, front right, rear right burners, than the problem is either with the actual radiant heat burner elements or the infinite switches that independently control each burner. I would still need a model number for the Range to help you more with this.
Hope this is of some help.
Dave
Dec 01, 2014 | GE Stove / Oven / RanMain Top Assembly...
Lost Manual and would like instruction on how to set for self clean cycle?
Make sure you have everything out of the oven, including the oven racks.
1. Press SELF CLEAN.
2. Press the TEMP/TIME "+" or "-" arrow pads to enter the desired self-clean cycle.
3. Press START.
The oven door will automatically lock. The DOOR LOCKED and CLEAN indicator lights will be
displayed.
4. When the self-clean cycle is complete and the oven cools, the DOOR LOCKED and CLEAN
indicator lights will turn off.
5. When the oven is completely cooled, remove ash with a damp cloth.
Recommended times are 2 hours 30 minutes for light soil and 4 hours 30 minutes for heavy soil.
If your oven has a HI and LO self clean time, HI is 4 hours 30 minutes and LO is 3 hours 30 minutes.
It is also recommended that you remove anything plastic from the top of the stove during cleaning.
Nov 27, 2010 | Whirlpool RF263LXTQ Range
The oven doesn't turn on in the bake cycle
oven doesn't come in broil but the broil should . the bake should in bake . but if it does work in self clean then your oven is ok and its the clock ( erc) that has failed . some times there is a code in the display stating the problem. but ist loks like a clock failure . **** ..
Dec 23, 2009 | Amana AGR5735QDS Gas Kitchen Range
Oven went in self cleaning mode and shut off door unlocked f90 error code will not bake
During the cleaning cycle, there was a temp sensor malfunction that may have damaged the temp sensor. this is a common occurrence with this model. this is refereed to as a runaway temperature code. the sensor lost control of the cleaning cycle and it got to hot. the temp sensor is fried and it will need to be replaced.
May 22, 2009 | Stoves Ovens
I need direction on how to start the clean cycle on my jenn air
CLEAN PAD
Use to set a self-clean cycle or a delayed
self-clean cycle. One press of the Clean
pad sets up an immediate clean cycle. A
second press of the Clean pad sets up a
delayed clean cycle.
• Clean oven
frame, door
frame (area
outside of gasket)
and
around the
opening in the door gasket with a nonabrasive
cleaner such as Bon Ami*. These
areas are not exposed to cleaning temperatures.
• Remove air grille.
• Remove oven racks. If racks are left in
during a clean cycle, it may impair function
and they will discolor. Turn off the
oven light and close door.
* Brand names for cleaning products are
registered trademarks of the respective
manufacturers.
TO SET FOR IMMEDIATE START:
1. Press Clean pad once.
2. Press the Auto Set pad for 3 hours of
cleaning time, press again for 4 hours
and again if 2 hours of clean time are
desired.
3. CLEANING and LOC plus the clean
time will appear in the display.
4. When the clean cycle is complete,
CLEANED will be displayed. LOC will
remain on until the oven has cooled
(approx. 1 hour).
5. When the oven is cool, LOC will no
longer be displayed and the door may be
opened.
6. Wipe out the oven interior with a damp
cloth. If soil remains it indicates the
cycle was not long enough.
TO CANCEL SELF-CLEAN:
1. Press Cancel pad.
2. If LOC is NOT displayed, open oven
door. If LOC is displayed, allow oven to
cool.
Thanks for using Fix Ya, Please take the time to rate this solution.
clarkco
Feb 08, 2009 | Jenn-Air JDS9860A Dual Fuel (Electric and...
Self cleaning oven
Unplug the power cord for few minutes. then plug it back to see if the light still keep coming.
then do this:
Check if you have it in the lock mode.
Press bake and broil pads together for 2 to 3 seconds until SF shows in the display.
Press the self clean pad, display will show loc off or loc on.
Let me know if it clear the fault.
Good luck from : Prince P
Jul 25, 2008 | Kitchen Ranges
Cleaned stove, replaced bottom element, stove reading F3, F7 and F9. Oven will not work. But will work on Clean Cycle.
Initially, it sounds like a problem with the lock mechanism. Without the brand or model number, it's impossible to know what the fault codes mean. You may find them listed on a tech sheet in a plastic pocket behind the console.
F3 is usually a temperature sensor. F7 may be a keypad problem and F9 (on some machines) means there's something wrong with the door lock.
Sometimes during a self clean cycle, a high temp thermostat/ fuse fails, preventing the door from unlocking.
Mar 09, 2008 | Kitchen Ranges
Self cleaning
You can go to the Maytag web site and download the manual.  www.maytag.com, or go to http://shared.whirlpoolcorp.com/assets/pdfs/literature/8113p293.pdf
and download the manual CAUTION
• It is normal for parts of the ovens to become hot during a self-clean cycle.
• To prevent damage to oven doors, do not attempt to open the doors when LOCK is displayed.
• Avoid touching doors, windows or oven vent area during
a clean cycle.
Do not use commercial oven cleaners on the oven finish or around any part of the ovens.  They will damage the finish or parts.
Do not leave baking/pizza stone in the oven during self-clean.
The self-clean cycle uses above-normal cooking temperatures
to automatically clean the oven interior.
The oven should be cleaned regularly by wiping up spillovers
to prevent excessive smoke and flare-ups.  Do not allow a
heavy build-up of soil to accumulate in the oven.
During the cleaning process, the kitchen should be well
ventilated to get rid of normal odors associated with cleaning.
Before Self-Cleaning
1. Turn off the oven light before cleaning as the light may burn out during the clean cycle.
2. Remove broiler pan, all pans, and oven racks from the oven.  The oven racks will discolor and may not slide easily after a self-clean cycle if they are not removed.
3. Clean oven frame, door frame (area outside of gasket, and around the opening in the door gasket) with a nonabrasive
cleaner such as Bon Ami* or detergent and water.  The self-cleaning process does not clean these areas.  They should be cleaned to prevent soil from baking on during the clean
cycle.  (The gasket is the seal around the oven door and window.)
4. To prevent damage, do not clean or rub the gasket around the oven door.  The gasket is designed to seal in heat during the clean cycle.
5. Wipe up excess grease or spillovers from the oven bottom. This prevents excessive smoking, flare-ups or flaming during the clean cycle.
6. Wipe up sugary and acidic spillovers such as sweet potatoes, tomato, or milk-based sauces. Porcelain enamel is acid-resistant, not acid-proof.  The porcelain finish may discolor if acidic or sugary spills are not wiped up before a self-clean cycle.
Important:
• Oven temperature must be below 400° F to program a clean cycle.
Only one oven can be cleaned at a time.
• Both oven doors lock when either oven is being cleaned.
To set Self-Clean:
1. Close the oven door.
2. Press the Clean pad.
    • CLEAN flashes.
    • SET and UPPER or LOWER flash in the display.
3. Press the Autoset pad.
    • “MEd” (Medium Soil, 3 hours) is displayed.
4. Press the Autoset pad to scroll through the self-cleaning settings.
     “HVy” (Heavy Soil, 4 hours)
     “MEd” (Medium soil, 3 hours)
     “LITE” ( Light Soil, 2 hours)
Choosing the soil level of the oven automatically programs the self-cleaning time.
5. After four seconds, the oven will start cleaning.
    • If the door is not closed, beeps will sound and ‘door’ will display.         If the door is not closed within 30 seconds, the self-cleaning       operation will be canceled and the display will return to the time of day.
    • CLEAN will appear in the display.
    • LOCK will flash in the display.  Once the door locks, LOCK will
      remain steady.
    • The cleaning time will start counting down in the display.
Nov 27, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Hotpoint RGB745 Gas Kitchen Range Logo
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
