Question about Samsung 206BW Monitor
Not showing display
Its not showing any display..the power light is blinking unusually i.e. very fast....
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 165 Answers
When it have this kind of error is a problem of the powerboard.
Anyway you must open it and look at the all capacitors and if are them inflated, if them are inflated must change them.
But can be a problem with inverters... control the transistors - MOSFET on the powerboard.
Posted on Oct 04, 2014
  • Samsung Master
  • 2,404 Answers
Try the monitor on another working computer. If you get the same thing then the monitor is bad for sure. The only thing you can try at this point if you have some technical skills would be to open up the monitor so the back is exposed. There will be a power board and a main board. Look for capacitors that have a puffy top, like if they were pregnant. Good capacitors have flat tops, bad capacitors have puffy tops.
If you find any puffy capacitors then get them replaced with ones with the same Uf rating and at least the same voltage or more. You have to unsolder the old ones and solder back the new ones and make sure the striped line matches up with the striped line on the board.
If the monitor still doesnt work after this then the monitor is bad for sure so getting it replaced is the only option.
Posted on May 11, 2010
1999 Durango left blinker blinks really fast right blinker normal all bulbs are good and operate what's the problem
Do you have ta railer wiring harness? This could be causing the problem. Turn on all your lights and perform a walk around the vehicle to see if there is anything unusual going on with any of the lights. A light will dim when the turn signals are flashing if the wires are bad.
May 24, 2014 | Cars & Trucks
The blue light still continues to flash
Push in and hold the switch on the back of the subwoofer until the light starts blinking fast. Then, with the soundbar power turned off, hold the mute button on the remote. "ID SET" should show up on the display. Then turn on the soundbar, and the subwoofer should link to it.
Oct 31, 2013 | Samsung 40" AudioBar w/ Wireless Subwoofer...
Phillips tv no pic no sound just flashing light
Its not going to be a do it yourself repair--likely a bad board or even boards--have a repair center (authorized for this brand) inspect it.
Just getting a set like this apart safely is tricky.
Apr 29, 2012 | Televison & Video
Monitor power light is blinking and no image is displayed.
The problem is in the power supply board, there are one or more capacitors that open, causing the power to stop. Sometimes they will bulge at the top making it easier to spot.
Apr 17, 2012 | Samsung Computers & Internet
I have a SyncMaster 920N Samsung Monitor and today it stops working. The power light is slightly constantly blinking,but the monitor is not turning on,when I m pressing power button. I tried changed power...
A fast blinking power light is an indication that the power supply is in a shorted condition. Parts called capacitors that filter the output power on the power supply board can fail and the power supply will short out causing the fast blinking power light. If you can solder then you can repair the monitor. Here is a link to a repair guide that has pictures and videos showing how to dis-assemble the unit and what to look for and replace to do the repair.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-920n-920nw-monitors/
I hope this helps, if so please rate my solution.
BuddyMc
Jan 06, 2011 | Samsung SyncMaster 920N 19" LCD Monitor
Originally my passenger door on my 2003 Chevy Trailblazer EXT would not always unlock with the FOB. Was an intermittent problem. Then last friday my driver and passeenger doors would not lock or unlock...
fast blinking lights are a sign of a burned out light bulb. Door lock actuators wear out. Since all the actuators operate every time you lock or unlock the doors, it's not unusual for multiple actuators to go bad
Jul 09, 2017 | Chevrolet TrailBlazer EXT Cars & Trucks
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Oct 02, 2009 | Kyocera FS-920 Laser Printer
T2682 power up, just get fast blink on front panle lights.
prb a bad mother board ... look on ebay for a used or new motherboard
Mar 28, 2009 | Computers & Internet
Samsung 206BW Monitor Logo
171 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
