Question about Refrigerators
Fridge too warm
The fridge feels too warm, but the freezer part at the bottom is at the correct temperature (i.e freezing)
we have tried turning the control knob to 5 and 1 but the temperature is still just a "bit cold" and not normal
the make is a bosch classixx, the one with 3 freezer trays at the bottom
  • 109 Answers
First, verify that the fan is running in the freezer compartment. second check that there is no airflow blockage between freezer compartment and refrigerator compartment. if that does'nt solve the issue verify the defrost system is working.
Posted on Mar 28, 2008
SOURCE:
Hello, my LG Refrigerator (lmx28988st) is acting up. The fridge stays cold, but the freezer won't freeze (its stays around 45F). It has the french doors for the fridge, 2 drawers for bottom freezer.
Have you confirmed the freezer door switch is functional? If this switch fails to detect the door is shut (you may or may not get an alarm), the unit will fail to cool properly. Meaning the actuator will not allow cold air to be diverted to the freezer.
If all else fails, you may try contacting LG directly by clicking here:
LG Get Product Support LG
Feb 17, 2018 | LG Refrigerators
Freezer has ice fridge is warm food going off
change the temperature sensor its not working fine
cause the compressor is working all time never stops
this is located inside a metal box with a dial
Sep 16, 2015 | Refrigerators
Have samsung american fridge freezer with ice dispenser i bought it second hand the problem is the digital display says the freezer is 20 degrees but its freezing inside also every minute or so we hear a...
If it's American, the temperature probably reads as fahrenheit. If so, 20 degrees F is 12 degrees F below freezing which converts to only -6.67 degrees Celsius.
Domestic freezers should be set to -17 degrees Celsius (= 0 degrees F), so the beeper is warning you that the freezer compartment is far too warm. If it's working correctly and has the temperature control set correctly, then it should achieve the correct temperature if you leave it for 24 hours and do not open the door nor try to use the ice dispenser. If the freezer is full of unfrozen items and so has to cool those down as well, then it may take even longer to reach the correct operating temperature.
Te operating manual for your appliance will tell you how to set the temperature correctly and whether it's possible to select between fahrenheit and Celsius scales. Most models allow you to set an override on the beep alarm as well. I cannot guide you on this without knowing the exact Samsung model.
Please take a moment to rate my reply.
Sep 22, 2010 | Microwave Ovens
Fridge Freezer will not maintain fridge temp, but freezer fine
My miele fridge freezer has just come up with a fault code F4 where the temp is... what does this mean and how can we fix it???
Dec 30, 2009 | Miele KFN8762SDED Bottom Freezer...
Salad in salad tray keeps freezing
contact the people who made the frig, sounds like a service call might be needed. you are paying for food that is destroyed, the service guy may save you money in the long run.
Oct 03, 2017 | Refrigerators
Fridge not staying cool, freezer still freezing
The defrost thermostat on the defrost heater is probably bad, it's a good place too start.
Mar 18, 2009 | Maytag MBB1956GES Bottom Freezer...
Hoypoint ffa9op.defrosted
hotpoint ffa90, I have fridge and freezer problem, non of them are keeping the required temperature though the fridge temperature is showing the right temperature but not cold and the freezer is not freezing as it is contstant between -2 to -5 but it should be
-22, the fast freeze bottom does not fridge either, it does not take instruction.
Feb 01, 2009 | Hotpoint FFA90 Bottom Freezer Refrigerator
Kenmore freeze on the bottom.. model 596-72219200
just called in a sears technician 150 dollar bill that was an easy fix. he says my bottom freezer kenmore fridge with warm fridge problem was due to the pathway being blocked by ice and garbage which is common with these fridges. he took off cover from the fridge bottom and poured boiling water down to the freezer. try that before you replace any parts or call in a tech. next time im getting a top freezer because the blower is on the top not in the middle with the bottom freezers and thus more problem prone.
Aug 11, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Ffa70 hotpoint fridge freezer
Adjust the temperature control for the freezer to a normal setting. Fast freeze is only for when new products are put in that need to be frozen. This locks the system into a continuous run mode and could be responsible for the freezing condition in the refrigerator section. Check the temperatures with a thermometer as the sensor for the freezer temperature could be bad causing the light to come on.
May 18, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Has been bleeping a while, then fridge got warm, then freezer defrosted!
So the freezing element in your fridge is broken and it's beeping because it gets below a certain temperature ?
Dec 27, 2007 | Hotpoint FFM90 Bottom Freezer Refrigerator
Refrigerators Logo
375 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
