Question about Nokia 3110 Cellular Phone
Memory card not supported
My nokia 3110c is not supported micro sd.when i put the memory card inside the mobile set then mobile is just switched off.oterwise its smoothly working without memory card..
  • 450 Answers
THIS WILL MAKE YOU LOOSE ALL FILES!!!
(even password)
Take the memorycard out of the phone and,
put it in a computer.Use filesystem FAT-32
to reformat your memorycard.
Now the card will work again!
No password, No files will be left after a
complete reformat
This is your solution! Please vote!
Posted on May 12, 2010
Nokia 5233 in memory card not sport
Posted on Jul 19, 2012
My nokia 3110c is blinking n switch off after the logo appear
Those who still have this restarting problem on Nokia 3110c ... Im telling the solution again, step by step. It ll work . you dont need to go 4 the firmware v5.05 If ur phone restarted 3 or 4 times and switched off automatically. Try this method 1] Remove the battery and Micro SD card 2] wait about 5 minutes 3] Then switch On the phone WITHOUT the memory card
Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu [default security code:12345] {i know most of people have done this thing,but remember u have 2 go with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD {Don t Format the memory card}
9] Switch On ur Nokia 3110c phone. 10] Now Keep ur free Phone memory space [Not the memory card's free space] between 470kb - 499kb.
Now surely ur 3110c working fine about 5 months.During these time u can 1] Send/receive any file via bluetooth. 2] Enjoy Music,video, GPRS,Yahoo Go .....etc 3] Also u can Update music library anytime.
Apr 19, 2011 | Nokia 3110 Cellular Phone
My memory card is showing in nokia 3110c mobile it is not showing in samsung E250i can u tell me y?and give me solution for this proablem plzzzzzzzzzz
According to the specifications it is suppose to take up to 2gb Micro SD cards.
Therefor the only reasonable explanation will be the fault might be with the card since you had it in Nokia 3110c it might effect the compatibility with Samsung.
What I would suggest to format the SD card with a PC or card adaptor to PC and put it directly into the Samsung and test it. Also test another card that has not been used before to see if that makes a diference at all?
And if all else fails try a smaller card because allthough the specs say up to 2gb some phones just can't handle it and you might have to try a 512mb or 1gb Micro SD card.
Hope this helps
Feb 02, 2011 | PNY 2GB microSD Memory Card
Micro sd memory card for 3110c password protected was forgotten
connect ur memory card, to the comp. through card reader,, then format it,,, lock will be opend
Jan 09, 2010 | Nokia 3110 Cellular Phone
I have a problem with switching my nokia 3110 classic answer pls!
The Problem with Nokia 3110c – Switching off and automatically restarting This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory.
Solution – Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 – Changing Themes – Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution – Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 – Transferring data via Blueooth / USB data cable (or) Updating Music Library – A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 – MP3 files
Solution – This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Also try this:-----
method
but remember below DONTs
1] Don t try to change themes.{u have to stick with a theme}
2] Charge ur phone in ON mode
3] Dont fully discharge the battery
4] Start charging ur phone when there is only a bar on Battery indicator
5] Dont erase calender notes
Make sure about above 5 Donts
Dont worry if ur phone restarted once.{U know the problem is restarting several times
and automatically swiched off.}
After 4 or 5 month there is a possibility to occur the problem again.
if so Follow the above steps again.
Good luck
To be frank, This mobile has this as a generic problem. As I told, The problem can come back again.
Thank you Sir, Have a nice day.
Sep 21, 2009 | Nokia 3110 Cellular Phone
1 GB micro sd memory card for my mobile nokia 3110c ..
try reformatting your memory card, however, previous data will be lost...
To format a memory card, select Menu > Gallery or Applications, the memory card folder , and Options > Format mem.
card > Yes.
When formatting is complete, enter a name for the memory card.
May 01, 2009 | Nokia 3110 Cellular Phone
Restart my nokia 3110c automatically
hi,restart my nokia 3110c automaticly 3 times and then swich off.what is the rision send me solution.
Sep 10, 2008 | Nokia 3110 Cellular Phone
NOKIA 3110C DOES'NT WORK WITH MEMORY CARD
Dear sir,
I have Nokia 3110c mobile.When i was insert memory card(micro sd 1gp),it was continuously restarting.So please give some solution.
Jul 16, 2008 | Nokia 3110 Cellular Phone
Lock memory card in nokia 3110C
Use memory card unlocker. Its a small device like card reader. You can unlock your card with that.
May 15, 2008 | Nokia 3110 Cellular Phone
Nokia 3110 classic
Solution 4 Nokia 3110c Restart
If
method
4] Then you must restore Factory settings from the Settings Menu
6] Now
ur phone
9] Switch On
Feb 11, 2008 | Nokia 3110 Cellular Phone
Nokia 3110 Cellular Phone Logo
321 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
