Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
JVC AV-56WP74 56 in rear projection convergence
Problems with the convergence. I have run the auto convergence also have tried manual adjustment with no luck. Need to order parts but do not know the part number to fix this problem. Any help would be appreciated.
Thanks
  • 2 more comments
  • 543482 Mar 29, 2008
    I would like to get the link and instructions to make this repair
  • fumanchu Mar 29, 2008
    I have the same convergence problem (second time in 4 years) I would like to get the step by step and necessary replacement part numbers if possible.
  • nickiz Apr 14, 2008
    I have the same thing going on for the second time!! They replaced two 1c's part number 392-150 last time. It is doing the same thing it was before ,however, I called JVC last week and they said the number they have is 392-110. They did offer to replace the parts for free since I just replaced them last year. I had to throw a fit , but I have had it with this TV!! The authorized repair center wants 400 bucks to put the free part in though!My hubby is going to try to put this one in but he would like to know what the difference is in these two numbers and could it be something else even though it's doing the same thing?
  • Neblay Apr 23, 2008
    Red on right, green on left, cannot correct with adjustment.Occasionally the entire picture will shift out of whack, though just the outside edges. I'd like the part numbers and instructions if possible. Thanks.
  • JVC Master
  • 8,617 Answers
If you remove the lower front panel where the speakers are then the small access panel you will see the convergence module right there in the front. It will have the two Convergence ICs attached to that heat sink. They are probably STK392-110. Then if you would like let me know and I will post a link where you can get the parts along with step by step instructions on how to do the repair.
Posted on Mar 29, 2008
HAD MY CONVERGENCE ADJUSTED BY REPLACING SOME PARTS. I NEED JUST ONE OF THE CROSSES ADJUSTED IN THE RIGHT UPPER CORNER OF THE NINE CROSSES
Ur tv still have convergence problems,if u can't reajust manually crosses or auto convergence.U must have 2 not just 1 STK convergence ICS to be replaced,all the resistors must test by the Ohm mulitimeter to the right resistance of the resistor's and replace them as require.
Jul 01, 2010 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP74 BLUE CONVERGENCE ADJUSTMENT PROBLEM
Make sure you bought genuine Sanyo chips...if not goto www.TvRepairKits.com and get theirs.
Aug 05, 2009 | JVC AV-48WP74 48" Rear Projection...
JVC AV-56WP30 Convergence Problem
Hi
You have defective convergence correction amplifier IC replace the STK IC...
Thanks!
Jun 12, 2009 | JVC AV-56WP30 56" Rear Projection...
Remote LOST - need info on what button to press...JVC AV-48WP30
There might be some features that the universal remotes aren't able to do. To perform the convergence alignment you should have the original remote.
Do you have the user manual or service manual?
The service manual will explain this process better.
Apr 10, 2008 | JVC AV-48WP30 48" Rear Projection...
Convergence
B+ voltages to run the convergence circuit missing == check power supply for open fuse devices..........................T.
Apr 06, 2008 | JVC AV-65WP74 Rear Projection Television
Red Convergence on JVC AV- 65WP74
convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 28, 2008 | JVC AV-65WP74 Rear Projection Television
Jvc av56wp74 rear projection tv
Jan 18, 2008 | JVC AV-56WP74 56" Rear Projection...
have pts rebuild the board which will cost around $130, www.ptscorp.com, or replace the stk392-110 x 2 located on the convergence panel.
Dec 08, 2007 | JVC AV-48WP74 48" Rear Projection...
PCB's when available,are expensive.Replace convergence IC(s),
re-adjust and you are good to go!
Oct 12, 2007 | JVC AV-65WP74 Rear Projection Television
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
100 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
