Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Have 5 color cartridge. one color head will not clean.
Have 5 color cartridge Epson stylus photo 1280. One color head does not respond to cleaning cycles; replacing cartridge did not help. What now?
  • 540 Answers
You have to replace the print head to resolve the issue as the print head is unable to detect the cartridges.
Posted on Aug 12, 2010
Epson Photo Stylus 1280 print heads do not work
The problem is the print head, The ink cartrige for this printer is just a little bottle of ink. What really causes problem in it IS THE CLOGGED HEAD. If you have skill to reach thepen of the head (part that touchs the paper) use a quill tip or rag soak on water and clean it. Or go to EPSON SITE AND ORDER A HEAD CLEANNER FLUID TO POUR INSIDE THE HEAD AND CLEAN IT.
Oct 23, 2012 | Epson Stylus Photo 1280 InkJet Printer
Printer jamed after putting in more paper and accidently pushed the power button off. Will not respond to anything I have tried.
Reset your Printer by following these steps for your Printer Model:
EPSON Stylus Color 900, 980
Pressing and holding LOAD/EJECT and CLEANING buttons, press POWER button, You will see blinking INK OUT led.
Release all buttons.
In 2-3 seconds time press and hold CLEANING button for 10-12 seconds.
EPSON Stylus Color 3000
Pressing and holding PAUSE, LF/FF and DOWN ARROW buttons turn on printer.
EPSON Stylus Photo 785, 895
Pressing and holding Maintenance and Roll Paper buttons, press POWER button, You will see blinking Error led.
In 2-3 seconds time until led is blinking press and hold for 10-12 seconds Roll Paper button, until all leds will blink.
EPSON Stylus Photo 890, 1280, 1290
Pressing and holding Maintenance and Roll Paper buttons, press POWER button, You will see blinking Power led.
Feb 27, 2011 | Epson Stylus Photo 785EPX InkJet Printer
I'm trying to resurrect an old Epson 1280 Photo Stylus. I've changed ink cartridges, and run the head cleaning/nozzle check utility numerous times, but nothing prints out on any test pages, nor on any...
It's time to "cut your losses"; either the electronics that tells the inkjets when to shoot ink is screwy, or the inkjets are totally plugged, despite the "cleaning" cycles.
Responsibly recycle the printer, and buy a new printer.
Maybe, try to find another Epson that accepts the same ink-cartridges that you recently inserted into the old printer.
Nov 19, 2009 | Epson Stylus Photo 1280 InkJet Printer
Epson stylus C88 won t print color ink black is
If you have carried out 4 to 5 head cleans, waited about 8 hours and done another 3 or head cleans doing nozzle checks after each clean (as recommended by the manual) and there is still no improvement then you will need a third party head cleaning solution such as this one:
http://websites.uk-plc.net/UK_Inkjet_Cartridges_PLUS/products/Print_Head_Cleaner.htm
Other makes & brands are available just google "inkjet head cleaning solution" Hope this helps.
Apr 02, 2009 | Epson Stylus C88 InkJet Photo Printer
Epson 1280 red ink low light will not go out. Have tried replacing both ink cartridges and have disassembled the unit and cleaned the waste pads. I have tried the reset sequence posted on here but it...
Epson color 777 Printer isn't working, the print light is on, but so is the red error light, ink jets are filled, had that confirmed, plenty of paper, what's the problem?
Jan 16, 2009 | Epson Stylus Photo 1280 InkJet Printer
Black lines on prints
Remove the cartridge.....
using a cotton bud clean the ink nozzle area on the cartridge for excess ink..take extra care not to damage the nozzles
... while at it take a piece of rag and try to clean the..service station area(this is where the cartridge goes to the side of the printer)for ink build ups....try to clean the rubbers that wipe the ink off the head as it runs across ..this is near the service station area clean well
it just requires cleaning..try to use little bit of cleaning solution that is available for that particular model..if not use bit of alcohol but do not use it on the cartridge itself ..make sure the alcohol is properly dried as not to damage the head
do reply if this helped
Nov 11, 2008 | Epson Stylus Photo 1280 InkJet Printer
Ink not empty
You have confused the software in either changing a cartridge when not required or having a chip failure whilst changing multiple cartridges.
Full info on how to get out of this is on my site.
Please go to my website http://www.the-inkstore.co.uk . I have the latest version of SSC Service Utility to download directly onto your computer and instructions on how to use it, what to click on etc etc. Click any of the Epson links if you can't find it, everything you need to know will be there, including printer Firmware resetting which sorts out a multitude of problems.
The 'maintenance required' problem with Epson printers has absolutely nothing to do with which cartridges you are using, it is a built in page counter in your printer firmware, which has a different maximum amount for each Epson model. Don't listen to old wives tales and heresay, we are the experts and it's an Epson scam to cause a lot of people to pay for maintenance or throw their printers away.
I haven't found a model that can't be reset with the latest version of SSC Serve or the manual reset on my site.
For Epson RX500 users there is also a manual reset on my site, as the SSC Serve software won't do it for you.
When using the program & choosing your printer from the list, it may have a weird name with 'x' in the model number, this is because some configurations are for many models in a series. For example, the C46 will be listed as C4x as it is for the C42, C44 & C46 models.
I hope this helps all Epson users to overcome the Epson scam of page counting and locking out until you pay their dealers money for maintenance.
If you like what I've done for Epson users, please show your appreciation by spreading the word and perhaps buying your ink from my site.
Happy trouble free printing
The INK Store (UK & Europe)
Apr 13, 2008 | Epson RX620 All-In-One InkJet Photo...
My Epson 1280 Problem
The cleaning button would be your maintenance button and the load/eject button would be your roll paper button.
Mar 13, 2008 | Epson Stylus Photo 1280 InkJet Printer
Epson 1280 red lines on photo
One of the best possible solution that we can suggest is to run a cleaning cycle for three times. Just to make sure that cleaning is effective please try the step below:
1. Using your computer go to printer utility.
2. Click on Maintenance then select Head Cleaning. Head cleaning usually took 1 minute.
3. Once the Head Cleaning is done Print a nozzle pattern to check whether the head cleaning is effective or not.
Repeat those steps for 3 times. If the nozzle pattern after 3 cleaning cycles still bad. Reseat ink cartridge if possible replace the ink cartridges.
After all those steps and issue still present printer needs to be in service.
Aug 05, 2006 | Epson Stylus Photo 1280 InkJet Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
35 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
