Question about Philips MCD708 System
I have a Philips MCD708 Stereo remote control that does not react to. The remote control is confirmed full.
2 Suggested Answers
Pellepeloton
  • 55 Answers
SOURCE: Philips MCD708 Remote does not work...
Test your remote with a digital camera display, if no flashing LED then try to repair the remote with my Instructable: http://www.google.co.nz/url?sa=t&source=web&ct=res&cd=1&url=http%3A%2F%2Fwww.instructables.com%2Fid%2FRepair-your-remote-controls%2F&ei=mpVVSrr6O4_-sgP0-oDPDg&usg=AFQjCNGyomjVuVMr6mFT1L36ffi06FhCDg&sig2=kheNi9TulBWzmhGOMiIX7g
Posted on Jul 09, 2009
Hey are PHILIPS remote is not working i don't no what to do help me pleces ;)
Hi Laura,
You can confirm if you're remote control is dead or not. Get a digital camera, point the infrared emitter of the remote to your digicam, while pressing any button look it at the screen of your camera. You will see the flash of the infrared if it is functioning. If you don't see infrared flashing then your remote control is dead. Replaced the battery as much as possible.
If you confirm that the remote is defective, you can may the replacement on ebay.com or shopjimmy.com
Hope it may help you.
Thanks for using fixya.
Feb 09, 2011 | Philips SRP4004 Remote Control
Hi We won't the plustron remote control code to operate a phillips tv. The remote is a Plustron URC11E-8. The model number of the TV is 29PT3323/79R.
Hi bro, I haven't a code for urc11e-8, i've only have a code for urc11c-8a.Just try the code hope it will work for your unit :-)
philips tv:
036,037,056,060,068,082,100,109,113,114,122,132,154,156,157,162,163,167,176,179,198,215,216.
try one code (3 digit) at a time.
if not working try the quick search.
Press the set+tv at the same time. (the tv must be powered on.)the led on the remote will be on at the moment.
Then press the set key again,the remote control enters into quick search mode, led keeps flashing.
then point the remote to your unit then press the power key (see the device reacts or not) if not try press the power key every one second until the unit reacts.
hope it will work bro....gud luck.
Jan 03, 2011 | Televison & Video
How can I arrange the sound from DVD's to come from the Tv set rather than the MCD708 speakers
Run audio (and video) cables directly from the dvd player to the TV. Don't expect anything but stereo. BTW: this would be a good way to watch TV without the Philips turned on.
The BEST video from anything you watch should go to the TV (with analog audio); and the BEST audio fro manything you listen to should go to the Philips.
Jun 13, 2010 | Philips MCD708 System
Philips TV 42pfl9664 remote control interferes Onkyo
HI it is entirely possible that the function you are using on your tv has the same command that your Onkyo uses for selection of GAME-mode. You should be able to prove this by using the Game-mode button on your Onkyo remote and it should affect your TV.
If Not then try shielding the remote receiver on your stereo with something thick ( a piece of paper is transparemt to IR - use a book or pillow) and see if the problem clears.
If this test proves correct, then the only solution is to see if you can change the remote command ID on the stereo and remote (if it supports it). The philips will most probably not have this feature. otherwise the only solution is to upgrade 1 device for a different brand.
Mar 21, 2010 | Philips Televison & Video
First time to operate indicater light comes on reacts to remote but no picture or sound 42 philips flat tv
First red light normal
Now select channel or other source from remote with full batteries or pushing buttons left down side of TV. Red light is only stand-by
Apr 28, 2009 | Philips 42 in. Plasma TV
Philips MCD708 System Logo
109 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
