Question about Kenmore 62232 / 62234 / 62239 Bottom Freezer Refrigerator
Kenmore Bottom Freezer Works; No Cooling In Main Refrigerator
Kenmore Model # 596.73212200
Freezer works fine. Main Refrigerator not cooling. Damper is wide open. Damper drove towards closed when tested with ice cube on little coil on damper control. no air flow at all coming through damper.
Found condenser and evaporator very dirty with dust. Vacuumed as best as I could with out turning fridge completely over.
What supplies airflow to refrigerator section? A fan? There is a fan to the left of the compressor (seen from rear) that is operating. I'm assuming that is to blow air across evaporator. Is there another one?
Thanks!
  • 6,784 Answers
HI. There are two fans in this unit. The one you are referring to from behind the unit will be the condenser fan. The other fan will be the evaporator fan. This is responsible for the air flow throughout the freezer and refrigerator sections. If this unit is not moving air, and the damper is wide open, the evaporator fan will be the culprit. The evaporator motor and fan assembly can be located just behind the inside freezer panel. Once he freezer concealment panel is removed, the evaporator and fan assembly can be accessed for thorough inspection.
Click here to view a exploded diagram of the evaporator fan blade and motor assembly. The actual fan blade can b removed form the motor. If you notice fan blade issues, kindly replace it. If the fan blades are ok, simply remove the fan blade, an replace the evaporator fan motor.
The fan motor will be labeled #18 on the diagram provide. The motor bracket is labeled #19. The evaporator assembly concealment panel is labeled #4 on the diagram..
Posted on May 11, 2010
  • 2 more comments
  • stoutflier May 11, 2010
    Localwonder:
    Thank you for the reply!
    I did remove the panel exposing the evaporator and found it and everything nearby a complete block of ice. The fan was not covered in ice. I melted the ice and then plugged in the cord and lo and behold the fan operated and there is positive airflow coming through the damper on the fridge side.
    Now, what caused it in the 1st place? there appears to be an evaporator heater that wraps around the sides and bottom of the evaporator. How can I test the integrity of that? Also, what is the round apperattus that the orange wire is coming out of in this photo? The other end is one end of the evap heater. This is looking at top right of evaporator.
    There seems to be some kind of plug in to the left. Is that some sort of diagnostic port?
    Thanks for your help!
  • Michael Masters
    Michael Masters May 11, 2010
    Ok, there are two causes here, in this situation. The most common will be a faulty defrost timer, or adaptive defrost control board. The defrost mechanism will vary from unit to unit. Most newer units will be equipped with a defrost control board. This will be located in the control housing, just above the heat shield, in the upper right had side. Older models will have a standard defrost timer mechanism. If this device fails, the evaporator heater Assembly will not receive the command to defrost the coil, on time. The easiest way to isolate the cause, will be to test the heater element. If the element is functional, the defrost timer/board, will be the culprit. Your unit will be equipped with a standard defrost timer mechanism.
    There are three primary types of defrost heater elements; exposed metal rod, metal rod covered with aluminum tape or a wire coil inside a glass tube. All three elements are tested in the same way.
    The heater is connected by two wires. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
    Test the heating element for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should display a reading somewhere between zero and infinity. Because of the number of different elements, I cannot tell what your reading should be, but we can be certain of what it shouldn't be. If the reading is zero or infinity the heating element is definitely faulty, and should be replaced. If the element test proves that the element is functional, the defrost timer will be the culprit.
    Concerning the cylindrical device you are referring to:
    This will be the monitoring thermostat for the evaporator core. This is wired directly into the heater assembly, and can be tested for proper continuity as well.
  • Michael Masters
    The extra peripheral connector is simply an auxiliary input device.
  • Michael Masters
    • Additionally, it is standard practice to replace the thermostat and defrost timer if the heater proves to be functional. If the heater assembly fails the electrical testing procedure listed above, simply replace the heater.
Kenmore fridge, model 253.63754302 freezer working fine, main fridge not cooling much (approx 62 degrees F.) Have been away for 7 months. Usually plug it in to restart and all works fine. Not this...
Your refrigerator is made by frigidaire it sounds like your damper is opening up if your freezer cold and the fresh food compartment isn't.
Nov 03, 2013 | Kenmore Refrigerators
The refrigerator portion of my Amana ARB2217CW stopped cooling (the fan is still running), but the freezer drawer portion still works fine. What can
most likely you have a bad damper,go here to see it
http://www.repairclinic.com/PartDetail/Damper/67003410/1025326
all that happens is the evaporator coil in the freezer gets cold,the evap fan blows the cold air to the fridge section and it goes through the damper,when it gets cold enough in the fridge section the thermostat on the damper closes the damper door,your damper broke in the closed position,this is as long as the door wasn't left open or anything like that,if it was the air ducts could have froze up but most likely it will be the damper.go here and it will show you where it is up near the light in the back and it's part number 18.hope this helps
http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-ARB2217CWPARB2217CW1/1268/0161000/M0403273/00003?blt=06&prst=&shdMod=
Sep 04, 2012 | Amana Refrigerators
My kenmore fridge is not working, the freezer works fine but the bottom will not cool. the fan is working but not blowing out air in the bottom
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 30, 2011 | Kenmore 64802 Top Freezer Refrigerator
I have a Kenmore refrigerator/freezer model # 596.65232401, this is the one with the freezer on the bottom and refrigerator on top. The freezer works fine, the refrigerator was not cooling, I removed the...
What you didnt state was whether you had cold air blowing when the damper opened up. If you did, then the problem will be with the damper assembly itself, or the control board, which is what you would adjust to change temperatures. This microswitch you mentioned, was this on the control board? then the control board is the problem. If you did something with the damper assembly, then that might be the problem.
If you dont have any cold air blowing when you opened the damper door, then airflow is your issue, and you will have to include more symptoms for a refrigerator repair diagnosis.
Nov 27, 2010 | Kenmore Refrigerators
The cooling is not working in the refrigerator portion of my Kenmore Bottom Freezer Refrigerator. The freezer works fine. Any idea why that is? Thanks.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 31, 2010 | Kenmore Refrigerators
Kenmore model 50503990 not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
fsfj
Jun 09, 2009 | Kenmore 57029 Side by Side Refrigerator
Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Oct 29, 2008 | Amana ABB2227DE Bottom Freezer...
Main food compartment not cooling
you need to replace the fan motor as it blows the cold air to the reefer section and that's why its not cooling the freezers cool both side in all units here's a diag and parts list http://www.searspartsdirect.com/partsdirect/retrieveModelActionHome!retrieve.action;jsessionid=1TlpO2RMjv7jqHUYRtODnQ**.shcapp3005?modelNumber=596.69272991&pop=flush
May 24, 2008 | Refrigerators
Kenmore 62232 / 62234 / 62239 Bottom Freezer Refrigerator Logo
222 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
