Question about LG WD-3632HW Front Load All-in-One Washer / Dryer
Will not pump water out of the hose intermittantly
Lots of debris from hose after repositioning hose, but it worked, then no more water from hose in spin cycle.
drained and cleaned filter, the it will spin properly.
I suspect a clogged pump impeller. how do I access this pump.
aborcass
  • 2651 Answers
SOURCE: washing machine
place it in spin do you hear it runnig at all???lift the top real quick to tell if its moving. if motors runing but kinda sounds loud and ratchety, like something broken. you probably have a bad motor coupling. part number 285753a
Posted on Mar 02, 2008
ngfam1
  • 639 Answers
SOURCE: F21 error
Peace Friend,
ngfam1 At your service!
NO GOD FOR BID DO NOT USE DRAIN OPENER IN AN APPLIANCE!
First try this, unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!!!!!!!!!!!!!!!!!
Posted on Sep 02, 2008
barkencoa
  • 3463 Answers
SOURCE: washer drum doesn't spin, no draining of liquid
If you have got rid of all the water, and it still will not spin, then the odds are it is the brushes in the motor that need replacing.
Quite a common problem
Posted on Jan 19, 2010
Testimonial: "I will tell repairman from Sears ( coming Friday ). i'll ask him to check brushes before he pulls motor. "
heatman101
  • 43501 Answers
SOURCE: How do I access the drain pump to see if it is
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Aug 19, 2010
rylee_smith
  • 8619 Answers
SOURCE: Good Morning Sir/Ma'am, We own an
Hi
Thanks for using FixYa. You are right OE error is caused when the washer is unable to drain for 10 minutes. As you have already checked and cleaned the drain hose and it seems that you have cleaned the drain pump filter & still the issue is not resolved then it seems that the pump has gone bad and should be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 30, 2010
Heater blows hot then starts cooling down
Sounds like a plugged heater core or weak water pump.
Take the heater hose loose from thermostat area and the other hose loose from water pump inlet,and reverse flush water from a water hose from the water pump heater hose,assuring that the hose end from the thermnostat outlet is pointed downward away toward the ground.
I always tie a loose WHITE rag around this end so I can see what debris is backflushed out.If very little debris,you probably have a weak water pump after all.
The backflush is a good thing though.
don-ohio
Oct 19, 2011 | 1999 Chevrolet Silverado 1500
Water is draining from pool iwth Rike 1800 pool pump, but flow is very slow and weak and definetly nothing like 1800 GOH
How long is the hose the pump is connected to?
What is the inside diameter?
With no hose, the pump gives 1800 gph, 30 gpm
with lots of small hose, that could drop to 5 gpm.
Ensure no debris in inlet or hose.
Gary
Sep 24, 2011 | Rule 1800 H53SP-24 Swimming Pool Cover...
My Paloma 42PVN shuts down and shows code IL. The manual says it's Lime deposits. How do I remove these deposits. The unit has been running fine for over 1 year but now it only runs intermittently and...
You need a 5 gallon bucket and a small sump pump that connects to a garden hose. The hose connects to the inlet of the water heater and and then run a second hose from the hot water outlet into the bucket. Pour in about a gallon of white distilled vinegar. Turn the pump on and let the vinegar run through the heater for 15 minutes. Reverse the hoses and run another 15 minutes. reconnect the heater and test the water flow. You may need to repeat these steps several times to remove enough debris and buildup.
Installing a water softener treatment system will prevent the buildup from occurring so fast, if ever again.
Oct 15, 2010 | Rheem Paloma PTG-42PVN / RTG2-42PVN...
Washer will not drain
Hello,the drain hose COULD be plugged.
Mine had the PUMP INLET plugged with lint/dimes.
That's right, three dimes and some lint kept the water from getting to the pump.
For even an inexperienced handiman, the fix is easy.
1) DISCONNECT THE POWER !!!
2) Open access door in middle of back panel - 4 screws
3) Disconnect pump inlet hose - pump is on the floor/left as you face the inside from the rear. Have lots of towels handy as water will run out of the tub. This is a simple hose clamp - you dont have to remove the clamp - only loosen enough to remove the hose.
You can tell the inlet hose as it comes from the tub.
The outlet hose exits the pump and exits the machine.
4) stick your finger into the pump inlet and feel for any debris. I have found much lint and small coins. Somehow dimes get into the pump inlet and make perfect check valves preventing water from getting into the pump.
Remove the debris.
5) reconnect the pump inlet hose
6) replace back access panel.
7) plug back in and test.
If it does not drain now, you may need a new pump.
For even a handyman with four thumbs, this procedure should take less than 30 minutes !
Thanks
May 24, 2010 | Kenmore 45087 Front Load Washer
How to replace a water pump on a 2003 yukon
Water Pump Replacement (4.8L, 5.3L and 6.0L Engines)
Removal Procedure
1. Drain the cooling system.
2. Loosen the air cleaner outlet duct clamps at these locations:
 Throttle body
 Mass Airflow/Intake Air Temperature (MAF/IAT) sensor
3. Remove the radiator inlet hose clip from the outlet duct.
4. Remove the air cleaner outlet duct.
5. If necessary, remove the engine sight shield.
6. Remove the radiator vent inlet hose from the radiator hose clips.
7. Reposition the inlet hose clamp at the water pump.
8. Remove the inlet hose from the water pump.
9. Remove the fan blade.
11. Reposition the outlet hose clamp at the water pump.
12. Remove the outlet hose from the water pump.
13. Reposition the surge tank outlet hose clamp at the water pump.
14. Remove the surge tank outlet hose from the water pump.
15. Reposition the heater inlet hose clamp at the water pump.
16. Remove the heater inlet hose from the water pump.
17. Remove the water pump bolts.
18. Remove the water pump and gaskets.
19. Discard the water pump gaskets
Installation Procedure Important: All gaskets surfaces are to be free of oil or other foreign material
during assembly.
1. Install the water pump and NEW gaskets
2. Install the water pump bolts.
3. Install the heater inlet hose to the water pump.
Zoom Sized for Print
Notice: Refer to Fastener Notice in Service and Precautions.
2.1. Tighten the bolts a first pass to 15 Nm (11 ft. lbs.).
2.2. Tighten the bolts a final pass to 30 Nm (22 ft. lbs.).
4. Position the heater inlet hose clamp at the water pump.
5. Install the surge tank outlet hose to the water pump.
6. Position the surge tank outlet hose clamp at the water pump.
7. Install the outlet hose to the water pump.
8. Position the outlet hose clamp at the water pump.
9. Install the accessory drive belt.
10. Install the fan blade.
11. Install the inlet hose to the water pump.
12. Position the inlet hose clamp at the water pump.
13. Install the engine vent inlet hose to the radiator hose clips.
14. If necessary, install the engine sight shield.
Important: Align the arrow at the throttle body end of the duct with the throttle
body attaching stud.
15. Install the air cleaner outlet duct
16. Install the radiator inlet hose clip to the outlet duct.
17. Tighten the air cleaner outlet duct clamps at these locations:
 Throttle body
 MAF/IAT sensor Tighten the clamps to 7 Nm (62 inch lbs.).
18. Fill the cooling system.
I hope this helps. The numbering is incorrect in the sequence but the instructions are correct.
Roy
Nov 06, 2009 | 2003 GMC Yukon
It wont unlock after giving me the f04 code... cause it has water in it but i need to open it! it also the drum wont spin
sounds like your water pump has failed or blocked position your drain hose on the floor into a bucket or floor waste let water drain out you should be able to open door reposition drain hose in original position and try again if drain pump does not work check for blockage or replace faulty pump good luck
Nov 04, 2009 | Bosch Nexxt 700 Series WFMC6401UC Front...
We think we overloaded the machine with bath mats and since then the water did not drain and the machine does not work any more. All buttons are flashing.
your pump is totaly clogged with the math matt sand
you should be able to access the pump from the rear wall,
bring towels you will loose water
remove both hoses from the pump and ensure they are clear, wash the drain hose completly run water through it
make sure you pump is clean and free
to spin
reassemble and and plug back in
errors should clear
Oct 23, 2009 | Washing Machines
Water pump
go to this link
http://www.autozone.com/autozone/repairinfo/repairguide/repairGuideContent.jsp?chapterTitle=Engine+Mechanical&partName=Engine+%26+Engine+Overhaul&pageId=0900c15280067c3f&subChapterTitle=Water+Pump&partId=0900c15280067bc9
Apr 22, 2009 | 1995 Buick Regal
Washer won't rinse and spin
clean the drain hose, but make sure you have a container to catch the water and lot of debris will come out. Then unplug the washer and put water on spin cycle to drain water, after draining water remove the pump filter located next to the drain hose turn left to open and clean more debris. I found my husband wedding band I thought he lost it on purpose. You will be surprise how much funk is in that filter. Turn pump filter to right to close and put cap back on hose. Don't call the repair guy. Hope this helped.
Darlene, New Orleans
504-296-4391
Jul 24, 2008 | LG WM-1832C Front Load Washer
Water flowing back into washer after wash
There is a back flow valve attached to the outlet port of the drain pump. It is just a small rubber flap. This sometimes comes loose or remains open due to debris and allows the water in the drain hose to flow back into the machine after the drain pump shuts off. It can be checked by removing the drain hose from the pump inside of the machine. You will lose all of the water in your machine (about 1/2 gallon)when you do this so be prepared with a bunch of towels.
Feb 14, 2007 | Whirlpool GHW9100L Front Load Washer
LG WD-3632HW Front Load All-in-One Washer / Dryer Logo
21 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
