D-Link Xtreme N  DIR-655 Wireless Router Logo
Posted on May 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can't figure out what password to enter when attempting to connect my iphone/laptop to the wireless network. Any help/guidance is most appreciated.
Prashant M
Level 3:
  • Master 2,278 Answers
  • Posted on May 11, 2010
Prashant M
Master
Level 3:
Answers
2278
Questions
Helped
978486
Points
6246
Your wireless network must be secured
You will need to check the wireless settings of the router.
Is there any computer online using the router.
check the IP address on that computer.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Click Here for more information about the routers and network
Hey i am using a DLINK wireless 150, and i am unable to find a password to use for my iphone 4, i can access my internet by clicking the button on laptop just not my iphone, thanks
The encryption key (password) is in the D-Link's wireless settings.
Connect a LAN cable from the D-Link to your computer's LAN port, open a browser and enter the D-Link's configuration URL. OR
open the browser on your laptop and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter)
You can now go to the wireless settings.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
How we connect internet to iphone
The iPhone can connect to the internet through both Wi-Fi and EDGE. Wi-Fi would be the wireless network at your home or business. When the iPhone connects to the internet through EDGE, it is actually connecting through the AT&T phone connection (or any other service provider the iPhone works with in the future).
safari.jpgTo the connect to the internet, you simply need to open up Safari (which is the internet browser used by the iPhone). If you're used to using a pc, think of Safari as the 'Internet Explorer' that the iPhone uses. You can use Safari the same way you could use Internet Explorer.
Once you open up Safari, the iPhone will attempt to connect to the internet. If there are wireless networks available wherever you happen to be, the iPhone will prompt you to choose one to connect to. If you're trying to connect to a network that has security, you will be prompted to enter the password for the network.
If you want to check to see whether there is a wireless network available where you live, work, or play, go to 'Settings' and then 'Wi-Fi'. The iPhone will show you all of the wireless networks that are available.
If there aren't any wireless networks to connect to, iPhone will connect to the internet over EDGE. Connection speeds over EDGE will likely be somewhat slower than they would be over a Wi-Fi network. You will also not be able to answer phone calls while connected to the internet through EDGE. If the iPhone is connected to the internet over EDGE you will see this small icon at the top of your screen: edge-icon.jpg
for more information you can go thru this link
http://support.apple.com/kb/ts2756
Hope this helps. Please rate my response.
Thanks.
Have a good day
On my Windows XP laptop I cannot get the wireless to work. All it says is "limited or no connectivity" when it connects. I have tried a million things, and nothing works! What can I do?
Disconnect your laptop wireless connection from the wireless acess connection. (Reboot your laptop if necessary). Then reconnect your laptop wireless connection, if your wireless network is a secured wireless network, your laptop will prompt for a network key ie your wireless network SSID password. Make sure the network key correctly entered ie.("Most wireless password keys are Upper or Lower case sensitive")
If the problem persist, then use the "Command Prompt"
Start ->"Run" ->Type "CMD" ->The command prompt will appear, then type ie without the quotes,
1. "ipconfig /release" -> enter
2. "ipconfig /renew" -> enter
3. "ipconfig /flushdns" -> enter
Hope it helps.
I have a belkin 802.11g network adapter for my laptop, and although it can connect to the network it is with limited or no connectivity. This used to be fixed by clicking the box to allow windows to manage...
This message generally means that you are attempting to connect to a password (secure) network. You have to reestablish the connection by inputting the password before full connectivity can be achieved.
Let's assume you are using XP. Troubleshooting this problem is described at
http://support.microsoft.com/kb/892896
Let me know if you need more information. Thanks.
1helpful
2answers
My husband bought a dlink router (it says dgl-4500 on it) and i cant figure out how to use it to get wireless internet for my new laptop....i have three "codes" he wrote down- a "router pass", a "network...
Router password is the password to access the router settings.
SSID is the network name. When you try to connect to the wireless network on your laptop, you will see this network name.
If your network is secured network then it will ask you for the network key or the password. You need to enter the ' security key '.
Click Here for step by step by instructions
Hello...great forum for tech support, by the way. I was recently given a Compaq EVO n800v laptop (with Win XP-SP1) that came with a Linksys wireless adapter card and can't figure out how to connect to my...
The best way is to double click the windows wireless symbol by the clock and click preferences on the left. Open the Networks tab and the first option is a check box to use windows for wireless, check the box and click apply. Once again double click the wireless symbol and select your network.
1helpful
Iphone doesn't work with router Dell 1184 broadband router in my house works with windows laptops but not Apple iPhone or iTouch. I have had the router/software installed for 5 years, is there new software...
you said the laptop is connected to the network.
when you try to connect to the wireless network on the i-touch or i-phone, do you see your network.
if your network is secured then you must enter the correct password for the wireless. If you are not sure about the wireless key or the password then you will need to open the router set up page and check the wireless settings.
you can also try to upgrade the firmware ( software) of the router.
Click Here to know more about router and network
Wifi not connecting to wireless network where as other devices r.
Is your wireless network password protected? If so did you put that password into the iPhone properly?
2answers
Need to get laptop connected to wireless connection
the wireless network is secure... you need talk to the person that set it up to get the network key
if that is not possible let me know ... there are ways around that
and after you have the key it should hook up with no problems... as long as the correct driver is installed for your wireless
robert
10helpful
7answers
Cannot connect IPhone to 2wire :( HELP!
I had this exact same frustrating problem. The problem was a simple password issue. Although I had changed the password on the modem to my own personal one, that password only affected the administrator settings. When I used this particular password on my iphone it would put the checkmark next to the 2wire, but I would not get the wifi symbol at the top of the screen. I fixed the problem by using the 10-digit password supplied on the actual router instead. I told my iphone to 'forget' the network, then reselected it and when it requested my password I typed in the 10 digit number and 'presto,' i had wifi symbology! I hope this helps.
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
