Question about Alfred Karcher K 5.93 M Electric Pressure Washer
Karcher 620M Pressure Washer. No electric power
Have a Karcher 620M Pressure Washer. Using today no problem. The pressure hose flew off (Iprobably had not put it on properly), and having set it all up again, the motor does not work. There is electric to the machine but no green light appears on the switch. Is ther a fuse or similar that I can check and how. Thanks Robert
  • 92 Answers
SOURCE: no pressure on certain settings
Dear Osville,
It is not clear what type of lance or nozzel you have. You said that the machine works fine with the circulating water jet(the turbo). So it seems the machine is fine. I do sometimes service variable nozzels and variable lances. But the best solution is to replace nozzels and variable nozzles and lances with new ones. Regarding the fan spray setting it could have no pressure because it might be in the chemical setting. The chemical setting lets out a fan shape flow of water, but with less pressure. The chemical system only works on low pressure in domestic washers, that is why it needs a low pressure flat spray. The pencil jet has 2 jets comming out because if it is a lance or nozzel with ball bearings, these ball bearings must have stuck in a wrong position. Also 2 jets can come out, due to a damaged nozzel hole.
Altogether, the best advice is to buy a new nozzel or lance...which ever your machine uses. All Karcher machines have their own specific nozzels, lances and high pressure hoses. You cannot change these from one model to another.
Regards,
Fulltech.
Posted on Apr 29, 2009
  • 72 Answers
SOURCE: Cant change the high pressure hose on a Karcher
On the Kärcher, you have a bayonet mount at the base of the tip end of the pistol grip. This is where you attach different types of nozzles and gadgets after having removed the existing sprayer tube. Just push in and turn a quarter of a turn, then you pull it off the pistol grip. The hose is possible to remove from the machine as well, an ordinary threaded mount but since you need the pistol grip to regulate on/off this is probably not what you want to do. If the telescopic wand is made by Kärcher it should be very easy to snap it into place just like when you removed the sprayer tube/nozzle. If the attachment was made to fit Alto washers there is an inexpensive adapter that works very well. Good luck!
Posted on Jun 03, 2009
  • 174 Answers
SOURCE: everytime i switch on my 6.80 pressure washer the
This sounds like the bypass (unloader) valve is sticking and the internal switch it activates is being held in a half open position. This will blow a fuse. It could also be loose wiring inside. If you ran it with an extension cord you may have weakened the fuse. Sorry, I cannot find a schematic anywhere. I think it is European, correct?
Posted on Aug 22, 2009
  • 569 Answers
SOURCE: Pressure hose not working on Karcher pressure washer
A common problem with these is a pressure valve inside the unit that controls the power to the pump. If the unit has not been used for some time the valve can stick.
Does the motor run when you press the trigger?
Please respond and I will advise further. (add a comment)
Posted on Apr 06, 2010
kel1guy2002
  • 3740 Answers
SOURCE: k5.140 makes a revving noise when releasing the
Before you do the below steps check the water supply inlet screen for obstructions where the water hose connects to the unit. If you notice debris remove and clean the screen under running water with a small NYLON brush.
The bypass unloader valve is triggering earlier than it should. You can lubricate this by adding oil to the water supply inlet (at least 3 oz.) and very briefly switching the unit on then off 0.5 seconds. Then let is sit overnight. The next day connect power briefly and again cycle the unit on then off for 0.5 seconds. Connect the water supply and then purge the water wand hose into a bucket to catch the oil before use. After this restart the unit and operate the wand trigger under full pressure at 0.5 second intervals to ;scycle the bypass / unloader valve inside the pump. This method has worked in about 95\0 % of the machines I have worked on. The oil lubricates and fattens the seals in the bypass / unloader valve. It eihter works the first time or the seals are torn in the unloader valve and must be replaced. With only 3 uses I think your pretty much in the clear and will not need new seals.
Thanks for using FixYa.
Kelly
Posted on May 17, 2010
How do I fix my pressure washer when the high pressure hose keeps blowing off.
If hose fits over a hose barb try using a hose clamp from any auto supply store Or replace the hose barb GL
Oct 08, 2015 | Karcher K 367 M 1750 PSI 15 GPM Electric...
Karcher pressure washer 620m motor only runs with switch held down but will not water pressur is the same as tap pressure out the nozzle
it is not uncommon that the switch is bad? if the switch controls the pressure telling it their is water and to start working? then i would just replace the switch.
Dec 17, 2013 | Karcher Garden
I have a Karcher Pressure and cannot get any pressure out of the unit.
karcher K3.97 MB when connected up to tap and switched on pressure poor and motor seems slow cleaned hose end, and filter looks clean
Apr 19, 2011 | Karcher Garden
My Karcher 330 M has blown two water inlet ( Garden hose inlet ) elbows. Replaced one and then after about 5 min operation shut off the valve on the wand and immediately the new elbow split the same as the...
I have a larger gas powered karcher, just make sure the water going to your karcher is not obstructed from its path. on mine i bought a goodyear hose that can be purchased at northern tools or any hardware store. and use it just for pressure washing. good luck!
Dec 23, 2010 | Karcher PSI Electric Pressure Washer
Karcher K2.19 Pressure Washer - Hose Coming Off
yeh this is what happen if you remove the yellow cover and you will see the metle u clip that is all that part holds on. you will needa new one from your local pressure washer supllier
Jan 17, 2010 | Karcher 1750 psi Electric Pressure Washer
My karcher pressure washer seems to oscilate on and off,the pressure is low ?
The most typical reason for this is that your supply pressure or volume is not sufficient. Try using a larger diameter hose.
Oct 30, 2009 | Karcher K2.26 Electric Power Washer
Karcher 620m runs but will not pump water
The pump that connects to the motor could be bad/and or loose
May 10, 2009 | Karcher 2500 PSI Pressure Washer
Karcher prssure washer motor will not start
try going to www.karcher.com
then click on europe
the international,
then service and will then see spare parts, enter k620
tick the button for you are a engineer and you are on your machine
download.
micro switch might be at fault.
Mar 25, 2009 | Karcher Garden
Karcher Pressure washer
Hi
don't know if this will help, but when I use mine, to start the pressure up I have to turn the nozzle to fine spray then turn it to the power spray and it works every time, shouldn't have to do this but I got it for nothing.
May 29, 2008 | Washing Machines
Karcher 620M not drawing water
my 620m has a problem when i press the switch on it has no pressure and the pump sounds like it is not kicking in .... plese help !!!
steve ..
Jan 08, 2008 | Washing Machines
Alfred Karcher K 5.93 M Electric Pressure Washer Logo
373 people viewed this question
Top Alfred Garden Experts
Dennis Key
Dennis Key
john h
Are you an Alfred Garden Expert? Answer questions, earn points and help others
