Question about HP Pavilion F1503 15" LCD Flat Panel Monitor
Blackout problem I have a HP F1503 monitor and it goes blank after few seconds.
    Champion:
  • 220 Answers
Normal problem is dry solder of Inverter transformer and/or transistors around it .
If you can see the backlight ,white 2pin connectors connect to invertor pCB.Look around these two connectors you should see 2 brown/yellow/red transformers with a ferrite core.These are the inverter transformers , resolder all pins and power transistors around it.
That should solve your proble.
Please provide feedback and rate this solution.
Samir.
Posted on Apr 08, 2008
Hp l1908w monitor
before goes blank does work ok for the few seconds. If not maybe does not get signal from the cable. The osd menus works ok?
Jul 02, 2014 | HP L1908w Monitor
My hp w17e will only work for about 5-7 seconds when I first turn it on, and then goes blank. If I turn it off and back on again, the same thing happens. Is it fixable?
You should do some research here first: www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ It's an old blog, but could offer a solution worth exploring. Just remember to rate this response after you do your research there. 12fixlouie
Sep 25, 2010 | HP w17e Monitor
My HP vs19e Monitor went black, when I turn it off...
guest, If monitor vs19e acts same when connected to different "known good" pc then try this site for info: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ How old is this model? When was last time it worked correctly? 12fixlouie
May 19, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
Screen goes black after booting up
amprich63, You should try to evaluate the state of the "switch-mode-power-supply" in the F1503 unit. Reconnect it to a FULLY booted KNOWN GOOD PC that is currently displaying the WIN-desktop screen! Then and only then push the "ON" button for the F1503. Did you see the desktop window?? if only for 1 second? What did you see next? Did you see a BLACK and BLANK screen? or Maybe just a BLACK screen? Do another post to this and tell me EXACTLY what you see or don't see when you shine a bright torch 2-3cm from lcd panel!!! I think you may have a BACKLIGHTING or POWER SUPPLY problem. I'm12fixlouie on fixya. if this was of some help rate this on fixya
Nov 02, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
I have an hp pavilion 1503 monitor and it blacks out after a few seconds after turning it on.
Open your monitor up and look for 4 coils on the circuit board. Re solder these coils to the board and it should work fine.
Oct 14, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Hp pavilion 1503 monitor lcd
Believe it or not, I got given a f1503 not working but without the power cable. He said the same thing everyone else is saying. I did not have a 12 volt 3amp converter but a 12 volt 1.5 amp converter. Plugged it in turned it on and wow it worked fine. It has been working for 1 week on with no problems. So try a different power converter, worked for me.
Jul 06, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
HP Pavilion F1503 1503 15in Flat. screen blanks out constantly
THis is a problem of the invertor board.If you are technically able you need to disasseble the monitor and resolder components around the red or yellow inverter transformers.
Samir
Mar 04, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
HP Pavilion F1503 15" LCD Flat Panel Monitor Logo
297 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
