Question about Garmin GPS
Garmin gps I have a garmin 176c marine gps. The lcd screen has a defect in the bottom left side--dark blue, to rainbow, to normal screen. This occurred right after I reassembled the unit after fixing a battery contact. Garmin says the unit is no longer made, and they cannot help me. The screen has a serial number KHSO38AAOAN-G72-13-O7 Made in Japan. Any idea how fix or replace? Kurt
  • Serwen Bagadiong
    Serwen Bagadiong Sep 16, 2008
    Yes I want to know how to fix this
SOURCE:
SOURCE: Screen Blanks
11-08-07
I had the same problem with an etrex Vista. I spoke with Garmin, they said that a recently launched WAAS satellite is interferring with some models (he mentioned it is the models with a black and white screen). Garmin tech support said that they're working on a software patch but for the meantime switch WAAS off.
Call Garmin tech support with any questions or to find out about the software patch, 1-800-800-1020
Posted on Nov 08, 2007
  • 537 Answers
SOURCE: Need Garmin GPS Fix Advice
It sounds like the ribbon cable that connects the screen to the controller might be seated incorrectly. I would check that.
Posted on Feb 06, 2009
  • 8 Answers
SOURCE: dark screen on garmin ique 3600 pda
Turn the unit on and try holding the on/off button down for three oe four seconds.
Posted on Mar 21, 2009
  • 3289 Answers
SOURCE: Garmin gps keyboard -- left upper corner fails to
Sounds like you need to recalibrate the screen. This can be done by following the steps below:
To Calibrate the Touch Screen on a zūmo®:
1. Turn the unit Off and make sure it is not attached to any outside power source.
2. Power the unit On, continue to hold the Power button for 1 minute. 3. A screen will display that says, Press dot in the lower left corner. 4. Release the Power button and touch the sequence of dots until your unit says Calibration complete.
Posted on Sep 19, 2009
pabloloco
  • 2335 Answers
SOURCE: GPS operation freeze up
Upgrading the system software of your GPSMAP 545s will most likely fix your freezing up problem.
I hope that helps.
Posted on Jan 31, 2010
Dark screen
It's either the logic board or some component that has gone bad. No real way to repair it, unless you tear it down and it's maybe a bad joint or something simple like that.
Best I can tell you to do is to FULLY discharge the battery, as in turn it on, let it die and keep pushing the power button to make sure it's dead. Takes about 48 hours. Once you do that, plug it in and DO NOT try to turn it on, just let it do it's thing and see what happens. Maybe hooking it to a computer after that and seeing if an update will help, also make sure that if there are any cables, external antennas, or cards plugged into it, to remove them during all of that. Best of luck for a resolution.
Nov 02, 2017 | Garmin GPSMAP 176C GPS Receiver
Hi the screen on my 176c is so dark it can barely be read. I have to turn the light on to see whats going on.Is there any way to restore it to its former glory cheers ......john wainwright. ...
John, the light sensitive IC has failed. This is a small piece of electronic wizardry that adjusts the brightnessdepending on the ambient light. At night is is supposed to add brightnes and in sunlight reduce it
The sign of failure may have been early but you didint notice it. They often turn on ok then suddenly in daylight the screen will darken, turning the unit off and on resets it for a while. however it gets worse as time goes on.. iT is not a DIY and has to be sent back to the manufacturer for correction.
Contact Garmin for a quote before submitting it for repair, you might need a chair to sit on when they give you an answer. Contact the service support in 7 hills NSW 1 800 235 822
Please rate my help++++ Thanks forf using FIXYA
Aug 04, 2010 | Garmin GPSMAP 176C GPS Receiver
WE HAVE PURCHASED A ETREX GARMIN BLUE IN COLOR AND ARE WANTING TO KNOW HOW TO GET DOWN LOADS FOR MARINE WITH OUT PAYING FOR THE CD OR DOWNLOAD
You need Garmin MapSource (Trip and Waypoint Manager) and a data cable. Then for free maps visit the murky internet sites and beware of what you download. I would not bother with a topo or marine maps on a grey screen GPS anyway as the colour maps will not be easily understood on a grey screen.
Aug 28, 2009 | Garmin eTrex Legend GPS Receiver
The GPSmap 176c does not turn on. I have put in new batteries and cleaned the metal parts of the battery receptors
Do you use rechargeable batteries? The 176C seems to be extremely picky about the voltage. I had the same problem. Afer changing to non-rechargeable batteries, everything works fine again. Not great for the environment, but for my bearings.
Jul 12, 2009 | Garmin GPSMAP 176C GPS Receiver
Nuvi 200 screen is extremely dark
The screen brightness could be turned down or the display itself is defective. Even if it was turned down all the way it should be somewhat visible, so if the display is completely blank, I would suggest that the LCD display has become defective.
- Jim
Sep 29, 2008 | Garmin nuvi 200W GPS Receiver
Looks like screen of 176C has been damaged---can still see it works
If the screen is already damage the only thing that can do here is to have the screen replace from the service center, so you can still use this unit...
Hope that helps...............
Sep 16, 2008 | Garmin GPS
Cannot see screen but it turns on
Have you tried resetting the unit?
Remove the face cover (GENTLY pry it loose by the fingernail groove directly under the GARMIN logo), press the RESET button, then re-attach front cover... this is covered in the owners manual which is available online at garmin.com /support /downloads
You might try this... point a bright flashlight at the screen while it's ON, but dark... see if you can see the normal screens, but just dark. If so, you've got a LCD backlight issue. It could the backlight dimmer circuit got damaged somehow, and if a Reset dows not help, sounds like it's repair time.
Garmin 1-800-800-1020
Apr 15, 2008 | Garmin StreetPilot c340 GPS Receiver
My 176c is not responding
get the download (updater from garmin website , download it then hook up 176c to computer and run file .if it doesnt go thru hit power and try again if you get the screen under a good light so you can see it will say downloading when this is done your screen will be back to normal .I dont remember if the unit is on when it beeps or off .try both ways if it doesnt work replace batteries as even though your not seeing the screen the unit is still on like i said ; fresh batts and try it and if it doesnt work hold down power key for a second or two and try again. good luck PS garmin doesnt know this i figured it out myself ...bob
Feb 24, 2008 | Garmin GPSMAP 176C GPS Receiver
GPS Logo
71 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
