Question about NEC Versa LXi Notebook
Need a part
I need the connector that goes from hard drive (in caddy) to the computer. It looks like a parallel connection. I bought a new caddy and it came with a connector that goes on the hard drive OK, but has a lot of "squares", and is intended to connect to pins. Where can I buy this part?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Sniper:
  • 62 Answers
You can buy it from ebay. Please click here.
CompQ
Posted on May 11, 2010
I just bought a Dell DHS computer without a harddrive at a yard sale, how do I install a hard drive for it
First you have to make sure you bought the right kind of hard drive (IDE or SATA) to make the installation and connection easier. IDE drives have a set of prongs or pins that stick out. SATA is the later type and does not have prongs or pins sticking out. You just turn the laptop over and remove the cover where the hard drive will be housed. Usually it will have an icon of 3 circular discs on it. Most laptops will also require a Caddy that the drive sits in before it goes into the laptop. And some might require a interface.
I suggest you look on ebay and see if your computer's make and model requires a hard drive caddy or interface.
http://www.ebay.com
In the search box just type your computer's make and model followed by hard drive caddy. Example: Dell Latitude D610 Hard Drive Caddy
In the search box type this is see if it requires an interface: Example: Dell Latitude D610 Hard Drive Interface
May 20, 2012 | Computers & Internet
Our MAXTOR Onetouch 4 mini is not recognized by computer. Can your software recover the data?
could be several issues to cause this fault, make sure your usb port is usb 2.0, replace the usb cable, take the unit apart and look for loose conections, try the drive in another caddy, or try another drive in the maxtor caddy. You will probably be able to remove the drive from the caddy and connect it into your computer if you have a tower and the correct connections.
May 02, 2011 | Maxtor OneTouch 4 Mini 120GB External USB...
What printer do I use to connect an Officejet d135
A printer does not connect to a hard drive.
Is the connector on the PC a Male (Parallel) or Female "D" (Serial) shaped connector?
Does the PC have a flat USB connector you can use?
If it does, then you should be able to purchase a cable that has an "End Point Connector" The "U" shaped block and the other end is the flat conector that is oon just about everthing.
Don
Feb 06, 2010 | HP OfficeJet D135 All-In-One InkJet...
Specifically where is the hard drive for the toughbook cf- 27 - i've looked all over
Flip the laptop over and slide the 2 tabs that are near the carry handle to the unlocked position. This will allow the metal cover on the underside of the laptop to hinge up and be removed.
With the laptop upside down and the carry handle facing you, you should see the battery on the left of the laptop. On the right, there is a silver case about 4 inches long and 2.5 inches wide. This is the hard drive caddy.
To remove /this/ part, carefully push the connecting cable towards the battery until it smoothly disconnects from the hard drive caddy. Remove the caddy from the laptop. Using a small phillips screwdriver, remove the 3 small screws which hold the top of the caddy on. Remove the top, and you will see the hard drive.
As a note - be sure you do not remove the gel lining. This is 99.9% of the hard drive's shock protection. When you remove the hard drive, the cable should come out of the caddy as well. Put the new cable on a new hard drive (HDD must be smaller than 65,536MB), put the new hard drive into the caddy with cable attached, make sure the cable assembly is fitted into the caddy slot, replace the caddy cover, replace the screws, replace the caddy into the laptop. Then, make sure you connect the cable from the laptop PC board to the caddy cable assembly. Replace cover, turn on computer, and set up your Operating System (if needed).
Nov 10, 2009 | Panasonic Toughbook CF-27 Notebook
I have an E1505 with no hard drive, no dvd drive. 2 questions: Is there a special "sled" or tray needed for a new drive, and do the connectors for any new hard drive line up and plug into the bay...
Answer for question 2 is yes, get into the BIOS and change the boot menu to include a ISB device if one is not enabled. I am unsure of the factory default, but once you are in the BIOS you can check that usb booting is enabled.
The hard drive of the E1505 use a "caddy" which consists of a smooth plate and a caddy head that screws to the hard drive and allows easy access to the drive by allowing you to pull it free of the side of the computer. Some people do not use the flat plate and just screw the caddy head atraight to the drive itself. I would recommend the whole caddy setup. Ebay sells them by the hundreds. Dell does not use an adapter on the hard drive to get it to connect with the motherboard. Your drive should be a SATA interface and that is what is on the motherboard as a connection. All you need is a "caddy" to be able to easily remove and secure the hard drive.
Oct 28, 2009 | Dell Inspiron E1505 Notebook
How do i fix a hard drive on a lap-top
You need to remove the old hard drive first. Depending on your model, there should be a screw or two on the bottom of the computer that gives you access to the hard drive. You remove the old drive, take it out of it's caddy, take the special connector off of it and install it on the new drive, put the new drive in its caddy, and replace the hard drive.
Thanks and please take a moment to rate this as fixya.
Jul 06, 2008 | Gateway Computers & Internet
Hard drive connector
It is called Hard Drive Caddy connector or Hard drive bracket , part number 465170802.
Ensure that you do not need the whole caddy.
Here is a reseller find more by putting part number in google.
regards
Mar 23, 2008 | Sony VAIO F540 Notebook
Gateway solo 2500
Here is a picture of the hard drive caddy itself. http://cgi.ebay.com/NEW-GATEWAY-SOLO-2500-LAPTOP-HARD-DRIVE-CADDY-ADEAL_W0QQitemZ6863173195QQcmdZViewItem
You see that hole in it towards the front?. If you look underneath the laptop you should see a tray that looks like that with a screw in it. Just take the screw out and the whole caddy should slide right out.
Mar 01, 2008 | Gateway Solo2300 200MMX Pentium, 200 MHz...
NEC Versa LXi Notebook Logo
41 people viewed this question
Top NEC Computers & Internet Experts
Martin Murray
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
