Question about Nokia 6233 Cellular Phone
Calculator error - Nokia 6233 Cellular Phone
  • Nokia Master
  • 4,737 Answers
Reset your mobile to Factory Settings using 12345 and see if it helps or not. To do this, go to Settings - Press Up key once and select Restore Factory - press Ok - enter 12345 - Ok this will reset your phone to it's default settings. If it doesn't help, you need to update the firmware of your phone. If you need more help do let me know through comments.
Posted on May 11, 2010
Which Casio calculators are capable of calculating the error function?
  • The Casio FX991ESPLUS is Casio's most advanced scientific calculator with 417 mathematical functions
  • Recommended for Advanced GCSE, A/AS level and Highers
  • This ever popular model is now available with Random Integers and an improved equation mode
Oct 27, 2014 | Casio Office Equipment & Supplies
How to fix error 3 on Sharp financial calculator?
You have entered too much data into the calculator or your sum is too long and you should break it down into two separate calculations.
Jul 30, 2014 | Sharp EL-738 Financial Calculator
Math error
e^500 is about 1.4*10^217. That's 14 followed by 216 other digits before the decimal point. This number is much too large for your calculator to handle, thus the error.
e^.500, on the other hand, is about 1.65 . (That's e to the point five). I think you dropped a decimal point somewhere.
Sep 26, 2013 | Casio FX-300MS Calculator
SYNTAX ERROR
I am willing to bet that if the calculator could talk she would tell you to stop feeding it commands that make no sense. Joking aside, each command has a certain syntax, similar to sentences you make in English: a prescribed order of the components of the sentence.
For some calculators (the older generations) you press a number then the square root key to get the square root. For the newer ones, you press the square root key. The calculator keeps waiting until you enter the radicand, then it calculates the root.
So before using the command you must know in what order to press the key sequence. If you get an error with a certain key order, do the opposite.
Now, why is the calculator giving you a syntax error always?. There could be may reasons.Try a simple addition or a multiplication. If you get a syntax error, it may be due the computational mode. You may be in statistics mode , or some other modes, I cannot begin to guess, because you say nothing about what you were doing when you get the errors.
Try to reset the calculator to get to default computational mode.
May 22, 2012 | Casio Office Equipment & Supplies
Whenever i try to link my calculator with other ones it always says error in xmit. no matter what i do
Read the following answer from the TI Knowledge Base.
Hope it helps.
How can I troubleshoot an Error in Xmit error message when transferring data between two graphing calculators?
The Error in Xmit error message is returned when a connection cannot be established between two calculators when attempting to transfer data. There are several factors that can contribute to this error message.
• The calculators being connected are not compatible for data transfer.
• The data cable is not firmly connected to both units.
• The receiving calculator is not in receive mode.
• The I/O port on one of the graphing calculators is damaged.
The procedure for connecting two graphing calculators is as follows:
• Connect the data cable to the I/O port of each unit. The cable will fit tightly in the I/O port and snap into place. If silver from the cable is visible, the cable is not properly connected.
• Access the Link menu on each unit
• Place the receiving graphing calculator on "Receive"
• Place the sending unit on "Transmit" or "Send" from the Link menu.
Once the data has been selected, the transfer will commence accordingly.
The data transfer protocols for graphing calculator is as follows:
• TI-73 - Link allows data sharing with another TI-73, TI-82, TI-83, and TI-83 Plus.
• TI-82 - Link allows data sharing with another TI-82.
• TI-83 - Link allows data sharing with the TI-82, TI-83 family calculator, and TI-84 Plus family calculator.
• TI-83 Plus/TI-84 Plus family- Link allows data sharing with another TI-82, TI-83 family calculator, and TI-84 Plus family calculator.
• TI-85 - Link allows data sharing with another TI-85(To a TI-86. Not From a TI-86).
• TI-86 - Link allows data sharing with another TI-86 and from a TI-85 to a TI-86.
• TI-89 family- Link allows data sharing with another TI-89 family calculator and from a TI-92 family calculator.
• TI-92 family- Link allows data sharing with another TI-92 family calculator and from a TI-89 family calculator.
• Voyage™ 200 - Link allows data sharing with another Voyage 200 and TI-92 family calculator.
If the cable does not fit properly into the I/O port, or if the I/O port appears to be damaged (broken or separated plastic, obstruction inside the port), call 1-800-TI-CARES (1-800-842-2737) M-TH 8:00 AM - 7:00 PM FRI 10:00 AM - 7:00 PM Central Standard Time to speak to a representative or sending an email to ti-cares@ti.com.
Oct 22, 2009 | Texas Instruments TI-83 Plus Calculator
WhAT IS AN Ma error
It is an abbreviation for mathematical (calculation ) error:
You did not actually ask about how to cure the problem, but here it is.
1.Calculation exceeds calculation range.
2.Calculation outside the input range of a function
3. Illogical operation (division by 0)
4. Poor precision is Sigma calculations (stats)
For all the above check input values.
5. Poor precision in differential calculation results (derivatives:decrease the delta, the step)
6. Poor precision in integral calculation results ( integrals: Change the tolerance tol)
7.Cannot find results in equation calculations (Check coefficients of equations
Take your pick of the above:Only you know what you were doing before the error condition arose.
Hope it helps satisfy your curiosity.
Oct 19, 2009 | Casio CFX-9850G Plus Calculator
Ma error appears in stat menu with casio cfx-9850gb plus
Here are the possible causes for such an error
1. calculation results exceeds calculation range.
2. Calculation is outside the input range of a function
3. Illogical operation (division by zero, etc.
4. Poor precision in sigma calculation results,
For all these reasons
Check the input numeric values and correct them . If you are using memory, check that the numeric values stored in memory are correct.
Hope it helps
Apr 07, 2009 | Casio CFX-9850G Plus Calculator
Nokia 6233 Cellular Phone Logo
51 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
