Question about MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript
Direction arrow does not work can it be replaced?
The direction arrow does not work can it be replaced? it is not just off in position it moves around freely. Is that easily corrected?
It is a 70 lb thrust motor with foot petal.
    Problem Solver:
  • 5 Answers
Maybe easily fixed... Take the head apart...just 3 or 4 screws up from the bottom. The direction arrow is "driven by a plastic gear that may have a "C" type ring holding the arrow and the gear together. The arrow sits on top of the gear like a car radio knob sits on its control shaft...with knurled splines. If either one is stripped or broken you'll have to purchase a new head housing...around $50-$60. Good Luck and God Bless
Posted on May 14, 2010
Testimonial: "Thank you - sounds liketeh problem, the motor and footpedal work ok, apppreciate it - God Bless you too. "
Neil Williams8 minutes ago I was told to tighten the front caliper bolts to 26 ft. lb. and the bracket to 133 ft. lb.194,000 miles on odometer. Is this correct?
I would go with the Utube advice as the bolts in use will probably shear off at 133 ft/lbs
40 ft/lbs for the calliper bolts and 70 ft/lbs is more in the region of being correct
follow the specifications in the workshop manual or get advice from a specialist brake shop as to the required tension b for the bolts
Mar 25, 2016 | Cars & Trucks
On my casio edifice 4334 module and the digital works fine but the analog i can see the minutes handle trying to move but not succeeding , seems to me like it is stuck thanks in advance.
Check if the battery is still in good condition. If this doesn't solve the problem, swipe a magnet over the back of the watch in different directions until the minute hand moves. Take care not to scratch the watch with the magnet. It may be necessary to oscillate the magnet several times at the correct position and direction until the minute hand moves freely.
Sep 26, 2015 | Casio Watches
What's the right weight for a heavy bag?
If you're weighing in the 140-170 lb. you should buy a punching bag weighing around 70-90 lb. if your close to 140 you should buy a 70 etc. if you a big guy weighing over 170 lb. you should get over 100 lb. bag. There is also heavy punching bags suitable for children and the weight around 25-55 lb.
Aug 07, 2012 | Boxing
Cadet LT 2042 worked fine changed hydro filter by lifting front with hoist to vertical. Lowered and topped off fluid. Now wont go forward or reverse. Makes no noise when pedal is engaged to move either...
You will have air in the system and will need purged. To do that you jack up the wheels to where they will turn freely then disengage the hydro and at an idle alternate forward and reverse for a for about 4 or 5 minutes. Recheck the fluid level and top off. Now engage the hydro and do the same forward and reverse for 3 or 4 minutes. You should have axle movement at this point. Hope this will help.
May 20, 2017 | Cub Cadet Street Sign- tractor lawn riding...
How do I remove my car radiator?
Section 303-03: Cooling, Engine 1997 Explorer, Mountaineer Workshop Manual REMOVAL AND INSTALLATION Radiator - 4.0L Removal
  1. NOTE: Refer to following illustrations.
    Drain the cooling system by removing the radiator cap (8100) and attaching a 9.5 mm (3/8 inch) inside diameter hose to the draincock nipple, located at the lower rear corner of the radiator tank. Then, open the radiator draincock (8115) and allow the coolant to flow through the hose into a suitable container.
  1. Loosen hose clamps at throttle body and engine air cleaner assembly. Remove air cleaner outlet tube and position aside.
  1. Remove radiator overflow hose from the radiator, disconnect two hose locators at top of radiator and position hose aside.
  1. Remove two fans shroud bolts. Lift the fan shroud out of the lower retaining clips and position it on the fan blade.
  1. Position upper and lower radiator hose clamps, remove hose from radiator and position it on the fan blade.
  1. Disconnect the two transmission cooling lines from the oil cooler fittings on the radiator, install protective caps over lines and position aside.
  1. Remove two upper radiator bolts.
  1. Tilt the radiator back (rearward) approximately 25 mm (one inch) and lift directly upward, clear of the radiator support bracket and the fan blade.
Installation
  1. Position the radiator into engine compartments, make sure that mountings on both tanks are inserted into radiator support brackets. Install radiator retaining bolts. Tighten to 6-8 - (54-70 lb-in).
  1. Remove protective caps from cooler lines. Connect the two transmission cooling lines at the oil cooler fittings on radiator. Tighten to 16-24 - (12-17 lb-ft).
  1. Install upper radiator hose and position hose clamp. Tighten to 3 - (26 lb-in).
  1. Install lower radiator hose and position hose clamp. Tighten to 3 - (26 lb-in).
  1. Position fan shroud in lower retaining clips and install upper bolts. Torque to 6-8 - (54-70 lb-in).
  1. Position radiator overflow hose, connect to radiator and locators.
  1. Position air cleaner outlet tube to throttle body and air cleaner assembly. Tighten to 2-3 - (18-27 lb-in).
  1. Fill the cooling system; refer to Cooling System Draining, Filling and Bleeding in this section.
Oct 28, 2010 | 1997 Mercury Mountaineer
My brush roller stopped spinning so I had to take it off and clean out all the hair that had gotten wound around it. I replaces it and now it is make a lound noise, but only when the brush is on. Could it...
Could very well be the belt. When cleaning the brush it is a good idea to add some WD40 at the ends where the plastic pieces are that hold the brush in the vacuum. The brush needs to be able to move freely around the plastic pieces. Add the WD40 and rotate the plastic pieces around the brush until they move freely. Reassemble making sure the belt is put in correctly so the brush moves in the right direction.
Please provide a Thumbs Up if this solution is of help to you. Paul
Oct 10, 2010 | Bissell Upright Vacuum - The Pet Hair...
93 Sierra - Cabin Heater Lights Flashing - Is that a warning?
Well this will tell you that the door that directs the air flow in not moving fully into position.Either the motor that moves the door is not working correctly or there is something obstructing the door.We had mice build a nest in the air ducts and would only do heat any other selection would make the arrow flash until we cleaned it out.Well hope this helped.
Mar 13, 2010 | 1993 GMC Sierra
What are the marks for the camshaft on a 2002 VW
There is a cutout on the inner part of the camwheel. It has a demarkation shaped like the tip of an arrow. This should line up to the 3:00 point on the edge of the head. you can tell for sure because at this position you should easily be able to move the camshaft sprocket about 3/4 inch in both directions easily from the pinpoint.
Sep 08, 2009 | 2002 Volkswagen Golf
I need to replace the alternator on my sisters car and its not here right now and was wondering where the alternator is located so i will know if ill be able to get to it to fix it
if you have the 2.3 liter engine follow these steps...
  1. On models with anti-theft audio system , refer to Technician Safety Information .
  2. Disconnect battery ground cable.
  3. Remove lefthand charge air cooler, then righthand upper seal board, Fig. 3 .
  4. Remove condenser fan assembly.
  5. Disconnect alternator, then alternator electrical connector.
  6. Remove lefthand splash shield.
  7. Remove drive belt.
  8. Remove A/C compressor, then, with pipe still connected, position A/C compressor away from generator for easy access to alternator.
  9. Remove alternator from under vehicle.
  10. Reverse procedure to install, noting the following:
    1. Torque lefthand splash shield bolts to 70 - 95 in.lb.
    2. Torque condenser fan bolts to 70 - 95 in.lb.
    3. Torque lefthand charge air cooler nuts to 12 - 16 ft.lb.
if you have the 2.5 liter engine then follow these steps....
  1. On models with anti-theft audio system , refer to Technician Safety Information for system deactivation procedure.
  2. Disconnect battery ground cable, then remove electrical harness, Fig. 4 .
  3. Disconnect terminal B wire, then alternator electrical connector.
  4. Remove righthand splash shield.
  5. Remove drive belt.
  6. Remove A/C compressor; then, with pipe still connected, position A/C compressor away from generator for easy access to alternator.
  7. Remove alternator from under vehicle.
  8. Reverse procedure to install, noting the following:
    1. Torque upper alternator bolt to 12 - 16 ft.lb., then lower alternator bolt to 24 - 33 ft.lb., Fig. 4 .
    2. Torque A/C compressor bolts to 12 - 16 ft.lb.
    3. Torque righthand splash shield bolts to 70 - 95 in.lb.
Aug 04, 2009 | 1995 Mazda Millenia
Estimated Weight
Direct quote from 2001 Mitsubishi Product Catalog Specs. Gold Series
VS-70707
Weight (approx. lbs.) 365
Jul 19, 2009 | Mitsubishi VS-70707 70" Rear Projection...
MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript Logo
723 people viewed this question
Top MotorGuide Electrical Supplies Experts
jdthefixer
Mike
ken skalski
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
