Model JH7X30. SPECIFIC USB CABLE I NO LONGER HAVE. HOW DO I RETRIEVE MY DATA WITHOUT THAT CABLE OR CAN I ORDER POWER AND USB RELACEMENT CABLES
SOURCE: Convert a USB power/data to power only
I have found a partial fix for my problem at http://pinouts.ru/GPS/garmin_nuvi_power_pinout.shtml
This explains why a mini-usb "sees" data/power or just power. It has a different resistor between X and ground - the 4 pin. 200K ohm for data/power and 17.3 or 22K ohm for just power.
OK - where does this resistor "live" in the cable and what do I have to break to get at it to change it OR is there someone out there making a USB to mini-usb power only?
Posted on Feb 09, 2008
jamers2004
  • 96 Answers
SOURCE: USB Data Cable Driver Samsung M300
http://tinyurl.com/anp6kx
Samsung pc studio for free is what you need.
Posted on Mar 05, 2009
  • 5 Answers
SOURCE: free download usb data cable driver software of nokia 3120
http://www.nokia.com.ph/get-support-and-software/download-software/nokia-pc-suite/download
click here bro just choose what device
dont forget to vote if i have helped you!
Posted on Mar 23, 2009
iwctoys
  • 126 Answers
SOURCE: Can you trickle charge the Olympus FE-20 via the usb cable?
Very few cameras will charge through USB ports. This is only to connect to computer to access pictures. Your camera will not charge via USB. I suggest to many people that using cameras that take AA batteries is the best cameras to buy when traveling. Many camera owner fall victim to different voltage outlets when travelling.
Posted on Jul 02, 2009
  • 4 Answers
SOURCE: USB cable
A USB 2.0 cable should do the trick
Posted on Oct 24, 2009
Dvd not working to initiate repair disk- no boot on hard drive
If the internal DVD drive worked previously, try changing the boot order in your BIOS. Depending on your computer, you will need to press Esc, Del, F1, F2 or F10 to access the BIOS. Save the new boot order when you exit the BIOS. If your DVD isn't listed, replace the SATA cable with a new one and make sure that the power cable is fully seated. You can try connecting the data cable to another SATA port on the motherboard. It's possible that the DVD drive failed as well; you can try a different optical driver.
All of the SATA ports should be able to support a boot device unless there is a specific controller/bandwidth sharing issue involved.
If you are using a USB DVD drive, you need to make sure that your motherboard supports booting from USB.
Please add a comment with your computer make/model or motherboard. I can provide more assistance with changing the boot order or determining the limitations of your SATA ports on your system.
Dec 16, 2012 | Computers & Internet
I just moved and am trying to set my computer back up but can't get my printer to work, I dont know if I somehow lost one of the cords, but I have one cord plugged in the back and it looks like there is a...
You need two cables - one for power and the other for data. The USB cable is easy to replace at most stores with computer accessories. You need a cable with A/B male ends (standard USB cable). If you need the power cable, that may be harder without contacting HP. The end of the power cable may be specific to HP.
I hope this helps.
(Even Walmart has USB cables. HP recommends using a cable that is no longer than 6'.)
Mar 10, 2010 | HP DeskJet F4280 All In One Printer InkJet
My Passport Drive is no longer recognized by windows
Check to see if the drive is available in disk management, if so and it's got a blue bar at the bottom, try changing the drive letter. If not, try the following:
Normally with the passport drives, you receive a shorter USB cable (this is because the drive relies on power from the PC, which your normal length USB cannot offer sufficiently. If you are using a short cable, try connecting the drive to the back of your desktop PC, this generates more power than the ports on the front (the ports on the front are actually hubs). If none of these options work try it on another PC, using the steps above.
If you still have an issue, the drive has most likely failed and you will need to get data recovery done to retrieve your data. If you do so, contact samsung for warranty information, so that your warranty doesn't become void.
Jan 24, 2010 | Samsung Portable 120GB USB 2.0 External...
Canon printerip4500 shows error USB003. Nothing wrong with output tray
Usually, USB error show when there is some problem with your USB Data cable, follow the instruction to resolve it.
1) Disconnect and reconnect the USB cable at both ends to ensure there is a secure connection on the device side as well as the computer side. It may also be necessary to try a different USB port on the computer. Additionally, you may need to disconnect other USB devices, temporarily, in order to determine if a conflict exists.
Else...
2) You can try a different data cable on the computer, may be issue with that specific data cable.
Visit this link for more information & Type "Error USB" in enter your question space.
Good luck.....don't forget to rate the solution.
Nov 14, 2009 | Canon Pixma iP4500 InkJet Printer
Sansa view is no longer recognized when plugged into USB port
Solutions are in order of increasing probability of data loss AND device recovery.
Screen messages are loose approximations
A Soft Reset
1. Hold Power switch up for 5 seconds.
2. Screen displays "Goodbye".
3. Restart
B. Hard Reset
1. Hold Power Switch for 30 seconds
2. Restart
C. Recovery Mode
1. Hold Power Switch for 5 seconds to switch device Off
2. Move switch to Hold
3. Press and hold Home button
4. Connect USB cable to device
5. Screen displays "USB" in small type and "16 MB Format" shows up in My Computer
6. Copy firmware files to "16 MB Format" drive letter
7. Disconnect USB cable
8. Screen displays "Firmware update"
9. Restart device
C. Force Format (This one wipes the data partition. Make sure all needed music/pictures/video exist elsewhere)
3. Press and hold top/North/up of Scroll Wheel
5. Screen displays "Format and lose data"
6. Press right/East on Scroll Wheel to confirm
7. Screen displays "Formatting"
8. Restart device
D. Manufacturing Mode (included for completeness only)
3. Press and hold centre of Scroll Wheel button
5. Windows detects a new hardware device
6. ???
7. ???
8. ???
Sep 07, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
I purchased a USB Data Cable for my new LG8360 but I need the software and drivers in order to run Bit Pim. Any help is appreciated.
the manual says to go to:
http://us.lge.com CLICK SUPPORT then DOWNLOAD
and then search for LG USB driver
but I don't know how to get it to your phone without a data cable
Apr 21, 2009 | LG CHOCOLATE VX8500 Cellular Phone
I have 3in1 USB 2.0 to IDE & SATA Cable but nothing to show me how to use this kit
SATA 3.5" 2.5" IDE 3 IN 1 TO USB 2.0 CABLE ADAPTOR KIT
1 external connection kit
1 internal connection kit
The internal connect kit consists of 1 red USB connector cable
and 1 internal white male molex connector to SATA female power connector
( 1 yellow wire , 2 black wires , 1 red wire )
the external connect kit
consists of a 3 pin power adaptor (with a tiny plug to save space) feeding a power supply which powers either IDE thru a Molex connector or SATA through a supplied adaptor. Supplied also are data connectors to link the IDE or SATA hard drive with a USB port. Use this adaptor set to retrieve data from a hard drive when it is not mounted in a computer.
Selah :-)
Sep 14, 2008 | Computers & Internet
Usb cable
We have used up to 20 foot USB without a problem. They are just not common to find.
Feb 25, 2008 | Computers & Internet
Usb lead
http://www.samsungparts.com/1/1/82095--usb-cable-ah3900498a.html Double check your manual for your specific version to be certain this is the cable before ordering it. www.samsungparts.com
Sep 15, 2007 | Samsung YP-T8 Digital Media Player
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
