Question about Quantum SuperLoader 3 LTO-3 Tape Drive
What is the unix command for ejecting a tape as mt rewoffl doesn't eject it out of the machine
3 Suggested Answers
SOURCE: My Drive will not eject the tape
I waited about 5 minutes and ejected the tape. It works.
Thanks for tips.
Posted on May 02, 2008
bluegreenash
  • 661 Answers
SOURCE: tape stuck in drive
you need to get to the underside of the tape drive itself, there is usually a manual tape release mechanism built in however it usually requires the user to wind the tape off off the spools until it is fully disengaged from the spool and then to unload the tape there are usually magnetic servos and lever arms that need to be moved to release the tape itself, without being able to see the drive myself I could not begin to explain further as each manufacturer's mechanism is different, however the tape release looks like a recessed screw on the underside.
it is possible that if you manage to rewind the tape using the manual release, that reconnecting the drive may allow the drive to eject the tape using the eject button on the front panel
Posted on Sep 30, 2008
Tape won't eject on my jvc gr-d60. help please.
Remove battery
Press and HOLD Eject as you place battery back on (so its the first command it recognizes with power) and try to eject. If it does not come out, camera will need service to remove tape or fix gears
Nov 16, 2014 | JVC GR Video Cameras
VCR EJECT FAILURE
When a tape won't eject, the problem can be caused by several things. The most common problem is that the belt that operates the eject mechanism is slipping and not allowing it to eject the tape. This can be fixed by either using a re-grip solution on the belt or having the belt replaced. With the cover off (be careful not to touch anything live with power) and try loading and unloading a tape. Try to find the motor and belt which operates the loading mechanism. When it "catches" as you say, try moving the belt pulley with your finger to give it a little help and see if it continues on with the operation. If it does, the belt is probably slipping. It takes more effort on the belt & pulley during an eject sequence rather than the a load sequence, so it may load fine but have trouble ejecting. Gravity and the weight of the tape is why you may not have this problem during the load sequence.
Jan 28, 2008 | Goldstar GBV241 DVD Player/VCR
My jvc camcorder shows me a message that my unit is on safeguard mode
E04 is the only one that a consumer can try to rid. This error normally is the fault of a bad tape. I recommend removing battery and HOLD DOWN EJECT, while reconnecting battery so its the first command camera sees. if tapes eject, try a new tape.
Jul 22, 2014 | JVC Video Cameras
Cd in macbook wont ejec
This can be a problem. First try rebooting the machine, and holding the eject button when you hear the startup tone. Hopefully, that will force-eject it.
If that doesn't work, you'll need to get creative. Get a playing card or something similar, and put some rolled-over tape on one side close to the edge, so there's a sticky side out. Turn the computer off, and try to get the playing card into the CD drive, with the tape making contact with the stuck CD. Reboot, holding the eject button when you hear the eject button again, and pulling the card out. Hopefully, the CD will come out with the card. If it doesn't work, just keep trying, and you'll get it out eventually.
Generally what causes this is keeping CDs in the computer for an extended period of time, especially while the computer is powered off. Make sure you remove all CDs before moving or turning off your computer.
Sep 07, 2011 | Apple MacBook Laptop Computer Mac...
I have a brand new tape adapter (for my iPod) that was working for weeks, but after I ejected it, it just keeps ejecting itself right when I try to put it back in. It will play just a tiny bit of the...
You might try flipping the adapter over the other way. If that doesn't work, you might want to try putting a cleaning tape in and clean the cassette heads. The tape player will sometimes eject a tape if it cannot read it very well. It assumes that the tape is damaged. Dirt on your heads can cause it to eject your adapter because it is having trouble reading the signal from the adapter.
Aug 22, 2011 | 1996 Chrysler Concorde
AIT-3 Tape Ejects when they put in MSSQL 4027
You will not find the list of the error codes on the internet. I know that Error Code: 0x81 is a "Reel" problem as I was just told by Sony Support. You should call them, have you serial number at hand when you do so. Check http://sony.storagesupport.com/ for a Telephone contact number.
Good luck, Bruno
Jul 15, 2011 | Sony (LIB81A3BB) AIT-3 Tape Drive
The command center comes on, and the radio is
The antenna wont go up because you have a tape in it, you will need to remove the radio,the belt inside may have broke, you will need to take to radio repair shop or replace it.
May 30, 2010 | 1988 Buick Reatta
Exabyte-220 Tape Library with a 8900 Mammoth drive. Tape cartridge is stuck in the drive - had a power failure during boot of the library. Can press the eject button and hear the tape rewind but the...
These drives are a right pain in the neck!
There is no easy way for an end user to remove the tapes and they are a terrible drive (certainly unless you are using a unix/linux server with all data on this server and not on another networked machine)
My suggestion would be to buy a new drive/library!
Failing that try sending the drive to www.tape-drive-repair.com who should be able to help - but these Mammoth drives are so awful they almost sent exabyte bust so i wouldnt invest too much money in keeping it going. Better to upgrade to an HP LTO4 desktop and cut your losses - Again these guys should be able to help with an upgrade
Jan 19, 2009 | Exabyte 220 MAMMOTH (2700061150) 8mm Tape
Power problems on VCR
When a tape is inserted or ejected the machine will attempt to tighten the tape by turning the rewind hub for a second, then it watches the counter to see if the fast foward hub turned (thus the tape is tight), if the tape can not turn or the counter sensor is bad then it shuts off (a safety mode to prevent tape damage). So, you could have a bad belt, bad idler wheel, or bad sensor.
Hope that helps...
Geno
Mar 26, 2008 | Televison & Video
Turn off the tape drive. (Switch in the back of the unit. Wait 2 minutes and then turn unit back on. Tape drive should issue a write data command and then rewind the tape. After rewind completes the tape should eject. If it does not eject after rrewind completes than try holding the eject button for 5 seconds to attempt a "force eject"
Note: Do not repeatedly press the eject button as this can cause damage to the tape and the tape drive.
Dec 07, 2007 | Quantum SDLT 320 External LVD...
Quantum SuperLoader 3 LTO-3 Tape Drive Logo
165 people viewed this question
Top Quantum Computers & Internet Experts
Tape-Techie
SirEbrum
terminalcon
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
