Question about Kenmore 24 in. 16032 Built-in Dishwasher
Ultra wash dishwasher
the unit is fairly new but when I push the buttons on it, no lights and no action
  • 868 Answers
First off you need to make sure you have power to the dishwasher.Take loose bottom panel and look to your left for your power box.Unscrew the cover plate and with a tester ,CAREFULLY,test the line at where your connections are made.
Posted on May 20, 2008
Just opened my cottage. Turned on the water supply. My dishwasher is filling up without any selection being made and only stops after the water is turned off.
As a handyman thinking it might be fairly new, you might try switching off electricity to it from the breaker and see if that causes the water to stop running. You might have started it but won't shut off, some new types have a computer and takes 30 seconds to stop doing what it is doing after you push the power button again to switch off. A dishwasher could have something in its water valve that makes it stuck on but that's pretty rare, might be a chunk of debrie got in there possibly from changing plumbing pipes.
May 03, 2016 | Kenmore Dishwashers
Kenmore Ultra Wash 665 dishwasher: start button not lighing
It sounds like you have a bad control console, and the problem is that your START button (the most critical one!) is bad. You can't replace just that button or key; you have to replace the entire control console.
Jul 02, 2012 | Kenmore Dishwashers
Blinking lights, unresponsive
I went to the Maytag site looking for a manual. None existed for my model, but I looked up won't start under the FAQs. The advice said to push the cancel button twice. My model doesn't have one, so I just started at the left side of the control panel and pushed each button twice. pushing the dry button twice made the lights stop blinking. i pushed the wash button and the unit started.
May 08, 2009 | Dishwashers
Four hour delay light flashing
I have a kenmore elite dishwasher and the 6hour delay light is flashing and no other buttons work when I push them.. whats wrong?
Apr 11, 2009 | Kenmore Dishwashers
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Kenmore Ultra Wash Dishwasher Problem
there is no real way of checking the keypad. Not with a meter but if you push normal wash for example and it does not respond this usually means that you have a bad keypad
Nov 09, 2008 | Kenmore 15899 Built-in Dishwasher
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Kenmore Ultra Wash Dishwasher - Blinking Quick Rinse Light
I had the same flashing light problem first the normal wash flashing light then the others. I tried shuting of the breakers but nothing. I tried resetting the panel by pushing normal wash and heated dry simultaneously and nothing. So I took the six screws holding the front panel out and unplugged the ribbon type wires and plug and unplugged it several times to help make a better contact and I was able to get it to work right away. This may not work for all but I worked for me. It is very easy to do and it's worth a try if you're having the same problem. It took me less then 10 minutes.
Oct 16, 2007 | Dishwashers
Kenmore 24 in. 16032 Built-in Dishwasher Logo
66 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
