Question about Panasonic Lumix DMC-FS3 Digital Camera
Lumix camera blocked
The lenses do not come back into the camera, no led lights on, on/off has no effect; though battery is charged.
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 11, 2010
Telephoto lens stuck
batteries might need charging or try new batteries.
Jul 04, 2014 | Panasonic Pal Version Lumix Dmc-fz47/fz48...
How do you charge panasonic lumix DMC-LS6
You don't. The DMC-LS6 uses standard AA batteries, either disposables or rechargeables. If you use rechargeable batteries then you must charge them outside the camera using a separate charger. AA rechargeables and chargers should be available at just about any department, electronics, or office-supply store.
Jul 29, 2012 | Panasonic LUMIX DMC-LS6 Digital Camera,...
My DMC-TZ3 battery charger green light is flashing, why ?.
I have the same problem. When I try to charge a battery the green LED onthe charger flashes green and the battery does not charge. Any ideas?
Jul 08, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Lumix zs3. Used outdoors, there are times when the
are you using a polarising filter or sunglasses with polarised lenses. if so take them off.
Mar 28, 2010 | Panasonic Lumix DMC-ZS3 Digital Camera
When i power the camera up it won't come but the word access pops up and after a minute the message on the back of the camera will read "turn the power off and on again" . what could be the problem .
If the camera doesn't turn on when you move the power switch, remove the batteries from the camera, re-insert them and connect the camera to a camera dock--if you have one. Check the LED lights on the dock and make sure the batteries are charging. Refer to your manual to learn which lights should be on when the batteries are charging. If they are not, try powering the camera back on after inserting new batteries.
Also try cleaning the battery contacts in the battery compartment using a clean,dry lint-free cloth. Sometimes, little particles can cause short-circuits in the battery compartment. If the camera still does not turn on after you clean the contacts, your camera may have had a power failure. Contact the manufacturer.hope this helps you
please do rate me on this issue
Nov 21, 2009 | Cameras
My panasonic lumix dmc-fx3 camera does not turn on. it was working fine one day and then the next it just stopped turning on. Screen is black, lense doesn't come out. I thought it was that i'd ran out of...
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your camera may have a problem that requires professional repair.
Oct 21, 2009 | Panasonic Lumix DMC-FX3 Digital Camera
It wont stay on. when i press the power button the led light blinks red. the camera is off but the lens is sticking out
It looks pretty much as battery problem, try using a new and charged one. Low charged (bad)battery can do strange things to eletronics
Oct 12, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
My camera lens isn't working, how can I reset it?
it sounds like there is dirt, dust or something else in the lens mechanism. I'm assuming you don't want to take the camera to a repair shop. I've had several cameras and this issue comes up periodically.
You can try:
1. using compressed air (with as thin a nozzle as you can find) to blow out the dust,
2. try powering on the camera and zooming the lens at the same time, 3. gently knocking the camera on a hard surface to loosen the lens mechanism,
4. manually forcing the lens to go back in. This can potentially damage the camera, but it's not working now, so you don't have a lot to lose.
5. Googling the camera model to see if you can find instructions on opening the camera up to clean the lens mechanism.
Oct 09, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Lensis not coming out
If you turn it on in photo review mode the lense will not open so turn it on in photo capture mode or if dirt gets caught in the lense it would jamm it shut so try to clean it, or if the lense is dented it would jamm, or if at one time the lense tried to open indide a case or in a position where the lense was blocked the motor mioght have burned out or the gear that pushes the lense out might have broken, in the case of the last three answers then a specialist might be able to fix it , or you might need a new camera, (i reccomend a fujifilm)
Jul 23, 2009 | Kodak Easyshare C813 Digital Camera
Error message
*&%$@#%^&*&^% !!"It's working!!!! Turn your camera on and put it near your ear. Did you hear a softly motorized sound in the lenses area and the green LED is flashing? If you hear this sound do this. Do it under your own responsability. (any way your camera does not work). When you turn on the camera wait until the lenses come out, in that moment grab the lens with your hand and don't let it go back. The camera will turn off but the lens will stay out. With the camera off push in the lens with your hand. Turn on the camera and that's it. I had to do it 2 times, but now my camera it's working again. This system error could be caused because the lens get out of it rail and the camera can not set the focus system.
Oct 18, 2006 | Panasonic Lumix DMC-LC33 Digital Camera
Panasonic Lumix DMC-FS3 Digital Camera Logo
109 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
