Question about Polaroid TDA-03211C 32 in. LCD HDTV
Tv comes on and then goes off in seconds like breaker is kicking
Get video for just a second then kicks off. power light stays on is it worth trying to fix?tv is in great shape man. in 2007
  • Polaroid Master
  • 8,457 Answers
Yes,Ur tv still have sound after the video dies in a few sec.?Yes,there are sound than ur LCD inverter board is dead.No,there are no sound than ur T-con board is dead.U have a little machanical skills take ur tv aparts.The LCD inverter board is a long board in shape and it sit sides of the tv right or left.The T-con board sit at the botton center of the LCD screen.Tries websites like Shopjimmy.com,Ebay.com to buy refurbish boards either the LCD inverter board or the T-con board for the replacement.
Posted on May 11, 2010
Air lock for my aruba spa hot tub how do i fix it
This sounds like a problem with the circuit board inside the spa control box.Do this:
  • Turn the breaker off
  • Unplug everything that is plugged into the circuit board i.e. the pump, heater coil, air blower, light etc.
  • Turn the breaker back on
If the circuit board stays on then you have to go thru the process of plugging one item at a time turning the breaker on then off to find the part that is bad.
Rod
US Parts Center
888-521-6183
Dec 19, 2012 | Pool & Spa
Rheem 90+ NG Furnace. When furnace starts, draft inducer starts, ignitor glows and gas ignites. Burners stay lit for 10 seconds or so, then the flame reduces for a few seconds then goes out. Main blower...
Check the draft inducer air switch ( vacuum diaphragm switch) If the switch is opening when the burner starts, you might have a blockage on air piping coming into the furnace. Also prime the condensate trap on the condensate drain from the combustion fan. Also check the gas pressure, if your gas pressure is dropping, the gas pressure switch will shut it down. If it's too high the moment it comes on could raise the pressure in the furnace dropping out the combustion fan proving switch.
Oct 29, 2010 | Electric Circuit Breaker Kit for Furnace
I have a Phillips big screen tv and the front light is flashing red at all times and the picture will not come on the screen. This light is usually green when the set is on. What can I do to get it green...
I have the SAME issue and so far it seems to be an issue with the fan not kicking on.... I turn it on in the morning, as soon as you hear sound the red lights kick on and I shut it off... it takes a few seconds to shut down so stay close to your remote durring this process and as soon as the "red light" kicks in, turn it off, as soon as it's off, turn it back on... I have to go thru this about 30 times now before I can get the picture to stay on, but it eventually kicks in. Hope this helps!
Aug 24, 2010 | Philips GOGEAR SA6045 MP3 Player
Philips MCW770/37 stereo will not power on any longer.
Hi ,
This is just a suggestion. Check your speaker wires at the back and at the speakers. A shorted speaker wire will cause a tripped breaker.
May 19, 2010 | Philips MCW770 CD Shelf System
HP Pavilion dv6225us won't boot (power not the issue)
Check http://www.fixya.com/support/t3440299-presario_f500_laptop_problem
Nov 16, 2009 | HP Pavilion dv6225us Entertainment -...
Kenmore Coldspot compressor kicking on and off
It sounds like you may have toasted one of the starting componets. Either the start relay or the start capacitor has probably failed, causing the compressor to try to start, and then kick off on overload. Hope this helps
Sep 10, 2009 | Kenmore 50522 / 50524 Side by Side...
Turns on then off
quite possibly a defective flyback, as thats the number one problem with that model TV. they are inexspensive and easy to replace. You van get a new flyback at the following link with free instructions on how to install it. You need flyback 259296 for your model. Heres the link.
http://servicemanuals.vstore.ca/
Aug 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Polaroid TDA-03211C 32 in. LCD HDTV Logo
557 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
