Question about Vizio L37 Television
"No Signal" on the TV
Hit the channel button on the side of the TV instead of the menu button and the TV now says "No Signal". Can't get a picture? Tried changing the channel, power on and off, etc., nothing is working. Cable is on and connected, not sure what more to do. Thoughts?
  • 321 Answers
Have you try to reprogram using menu setup/auto channel /before programming in tunner set upcoose cable
after reprogram select channel 3
hope that will helps
regards Alan
Posted on May 11, 2010
How to change the channel my Sony Trinitron TV turns on to?
hit menu button on your remote, navigate to channel setup menu. on the sub-menu, set channel fix to your channel that you require. now when your tv powers up this will be the default channel. if this doesn't fix your issue then try cycling through video inputs tv/video button on your remote.
Nov 10, 2013 | Sony FD Trinitron WEGA KV-24FS120 24" TV
I Lost picture. Went to press mute button on remote and pressed last button instead. Now i can't get picture back.
If you hit the "last" button again, it should take you back to the channel you were on before you hit the button. when you lost the picture, was the screen blue? black? If you hit the "menu" button, does the menu come up?
Jan 11, 2013 | Vizio VW37L 37 in. LCD HDTV
I hit the Channel button on the side if the tv instead of volume and now I have no picture can't change the channels just says no signal ... What did I do?
Sounds like you may have set it to an "input" channel. You may have to go into your menu to change it back!
Mar 23, 2012 | Televison & Video
I am trying to get a picture on my tv. Since it was hooked up to a satilite receiver prier, I think the problem is the tv is still on Digatal instead of air/antenna. But I do not know how to bring up...
You will need the remote that comes with the tv if there is no menu button on the tv itself to bring the menu up. Hit the menu button and will want to go to the channel option and change it from digital to analog or even just scan for new channels. But honestly, when working with a satilite box you will usually not use your cable or antenna jack in the back of the tv so you might just need to change the input of the tv to get your channels up.
Sep 08, 2011 | iLO Televison & Video
LG 50" the pitcher is off the screen each side by
Ok, first make sure you or someone in family didn't hit the "HD Zoom" on your cable remote or whatever kind of remote you have. On ours - Cable- if you hit it once it is in "Normal" picture which on ours has black around edges on a non Hd channel. Then if you hit it again it Zooms once makes pix very large and if you hit button a third time brings it into a wide screen Zoom that fills the Tv screen. If we are viewing HD channels I put it on Normal which will fill the screen and give you the best HD pix. If we are viewing a NON HD channel, then normal will have black on sides, so I hit the Zoom a couple times to fill in the screen. My brother in law had this problem and couldn't figure out why his Sports channel Scores were always half cut off the screen! it was zoomed in too much for that channel. His sports channel was in HD so needed to be on normal instead of zoomed in.
if it is not the Cable remote then this is a second possible cause:
The other thing that happened to me was - we hardly ever use our original TV remote that came with the TV. but one day our picture looked weird and the cable remote didn't adjust it. One of us had hit the "P SIZE" button on the TV remote. this changes your pix from - 4:3 ratio to 16:9 ratio and vice versa. I put clicked that button and on the TV it shows whether it is at 4:3 or 16:9. For newer wide screen TVs you want that set at 16:9 ratio.
All cable company remotes probably are a bit different so check with your company ... to find out where the zoom control is on their remote.
Feb 27, 2011 | LG Televison & Video
My wife thought it was hooked to a cable box for high number channels and pushed 707 on the remote TV sig went out. TV powers up but no menu no signal just a power light and the background is on but no...
Hello
have you tried pushing 003 on the remote or the AV buttons?
All I can think of is that you must the get tv BACK ON the right channel or AV Input.
Hope you have a better day
Nov 25, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
No tv picture
Call a professional and have the V setup again.
A1 Elmbrook Electronics Inc. EEI.Vstore.ca Elmbrooke@gmail.com
Mar 30, 2010 | JVC HD-52G787 52" Projection Television
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Feb 12, 2008 | Televison & Video
Unstable signal
Are you sure it says unusable signal instead of unstable signal.
This means that you have the wrong input in place in the tv. If you got the original remote with it there may be an input button. on it. Some RCA's use 00 for the video input. If your cable goes directly to the antenna connector on the back you should get all channels when you do auto search in the menu provided you have the right input programmed. If you are using a cable box the tv must be on channel 3 or 4. video input uses rca cables red white and yellow to the proper input on the tv but there again the input must be set correctly. Possibly in the menu do a search there. Hope this helps.
Dec 29, 2007 | GE 32GT660 32" TV
Vizio L37 Television Logo
230 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
