Question about Dishwashers
Delamination I'm installing KitchenAid KUDS03CT which has the venting out of the top of the door. The steam and heat are vented directly beneath the edge of the counter top. The counter top is a preformed laminate over high density particle board. Will this cause swelling of the particle board and delamination of the laminate?
  • hoganhagan Mar 01, 2009
    We are so unhappy with this dishwasher. Its a terrible design and our countop is wood so it will be ruined it we dont replace this dishwasher. It soaks everything around it, and we dont believe that the vent stays shut until after things have cooled down. All that steam need to go somewhere, and it will end up under your countertop and all down the front of your custom wooden panel.
    President:
  • 1,314 Answers
Its not supposed to as there is not that much steam coming out if it does contact whirlpool and check your installation instructions
Posted on Mar 28, 2008
6ya staff
SOURCE:
Should the steam vent on top of Kitchenaid dishwasher be visible when door is latched or should it be jnder countertop completely?
unless you have a granite countertop I would say it needs to be seen wood getting steamed will rot out rapidly
Jan 16, 2016 | KitchenAid Dishwashers
Is a gap at top between outer door panel and inner control door on Kitchenaid dishwasher KUDE normal?
When the dishwasher starts the drying cycle, there has to be vent that the steam can escape and it just so happens to be on the left side.
Aug 06, 2014 | KitchenAid Dishwashers
Hot microwave door handle
I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
Jan 08, 2013 | Whirlpool Microwave Ovens
Steam coming out of top of the door
Hello, Thank You for using FixYa. I will be helping you today.If you have a vent on your door which most dishwashers do then the unit will vent steam from that vent.
Thank You and please rate my answer if it was helpful..
Jun 24, 2011 | Dishwashers
Is it normal to see steam coming out of the dishwasher in the drying cycle?
Yes, The colder the room its in the more steam you will see. It will look like more steam if sun light is shinning over it. Just like your clothes dryer blowing steam out side. Its just drying.
Oct 30, 2009 | Dishwashers
My Whirlpool microwave hood combination was installed when I bought my home. I can hear the exhaust fan run when I turn it on but it does not pull any smoke, steam or odors from the stove top. I can put...
sounds like they forgot to flip the vent louver,
it sits atop the microwave and needs to be rotated to the proper direction for venting.....
Oct 13, 2009 | Microwave Ovens
Ge dishwasher gld4160looss
Where's the vent on top/or the end of the door under the cabinet? Some steam is normal.
Nov 21, 2008 | GE 24 in. GLD5560LSS Stainless Steel...
Dishwasher maytag 945 awq
Door gasket or sealOver time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Nov 08, 2008 | Maytag MDBH945AWW / MDBH945AWQ /...
Wet dishes; steam does not escape
Hi, Most dishwashers do not have steam vents! there are several reasons for poor drying in a d/washer! The first one is to see that you have rinse aid in the machine as this aids drying! Next if you have rinse aid then is it being put into the machine when it needs it? Also you must bear in mind that the dishwasher need to heat on the last rinse to create the heat to dry the items which use the steam to dry them. Check the rinse aid first and see how you get on....
Let me know.......
Aug 01, 2008 | Jenn-Air 24 in. JDB1100AWS Built-in...
Steam comes out of dryer after cycle and door is opened
Probably has a restricted vent. Go outside with dryer running and check air coming out vent. Should be a good blast...not just a breath. Clean out the vent and make sure it's not kinked. If it vinyl or foil vent, replace it! Also make sure lint screen is cleaned everytime.
Nov 16, 2007 | Whirlpool LGR3624JQ Gas Dryer
Dishwashers Logo
275 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
