Question about Kenmore 22422 Top Load Washer
My cabrio washer sounds like it has coins under the basket when it goes through the spin cycle. how do i get them out?
    President:
  • 1,937 Answers
Assuming that this is a Whirlpool Cabrio, see the following Whirlpool Service manual. It has sections on how to pull the agitators, tub etc.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Posted on May 11, 2010
My whirlpool cabrio washer wtw6200vwo shows f71code and wont spin out clothes
WHIRLPOOL CABRIO WASHER ERROR F71. The Cabrio Washer Error F71 code is the same as the SD code: This error means the main control board detects too much drag on the basket during the spin cycle.Mar 29, 2017
Nov 13, 2017 | Whirlpool Washing Machines
How to fix error message SD on our cabrio washer
Check the drain hose for kinks. Then check entire circuit: tub drain>drain hose filter>drain hose pump> drain hose for blocks. The particulars for your model would be in the owners manual or service maual.
Sep 06, 2014 | Whirlpool WTW6400SW Cabrio Washer
What does o L mean on the Cabrio 6th sense by whirlpool and how doe i fix?
The OL error code indicates that the washer is overloaded. If the washer is not overloaded, this would indicate either a drag on the drive system or the control board is failing. Be sure nothing is on the floor under the washer that could be causing a problem. Raise the lid & manually spin the basket, it should spin freely. If not, you may have an item stuck between the spin basket and the washer tub. The image below shows how to remove the spin basket. If you unplug the washer and follow that procedure, you may find the cause of your problem. I recommend scheduling for a technician to come out to diagnose and repair your washer.
Oct 27, 2013 | Washing Machines
Whirlpool Cabrio WTW6600SB2 won't spin or agitate. We bought it used and they swore it worked. It goes from 45min and drops down to 3mins. It never completes it's load. And after it beeps with a OL on
Hi.
Most spin troubles are caused by drain or pressure switch problems, but it does not look like that is your case. Check for blockage in drain system and clean the hose connected to pressure switch. As said I do not think that this is the problem but the drain system must be checked as part of troubleshooting.
OL code in fact is not related to drain problems, but to motor and mechanical problem. OL is returned when the washer is overloaded and the motor cannot turn the basket properly.
The first step to diagnose the problem is removing the basket and looking for problems under the basket (e.g. broken part or clothes stuck under the tub). Here a document showing how to.
If parts under the basket are OK the next step will consist in testing the motor. The motor can be tested reading impedance at its phase terminal and across the stator winding. The Cabrio's motor should read about 30/32 Ohms across its phase contacts.
If the motor and the rest are OK the problem is usually the RPS sensor that detects the rotational speed of the motor.
Regards.
Ginko
Dec 15, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My cabrio washer has change that got under the tub how do i get it out what do i have to remove
Step by step instructions found HERE starting on page 4-9 on how to remove your basket.
It will take a minute to load the document.
Hope you get rich....:)
Mar 26, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My whirlpool cabrio top loading washer with corner dispensers had some coins trapped in the bottom of the basket. I can hear the coins and some water. When the washer goes into spin it apparently throws...
You have to disconnect all wire connectors, inner basket, both pumps & Then unclasp the 4 shock rods then remove the whole inner assembly. Then turn the inner assembLy upside down & every which way until they all fall out. Like shaking quarters out of your piggy bank.
Sep 28, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
ERROR MESSAGE F50
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%^&*(
Jun 14, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Sounds like a jet engine at full spin cycle
These things are notorious for sucking clothing under the the drum , it could cause it to be noisy spin slow and have drain problems . This is such a poor design . Try removing the drum and see if there is an article of clothing under it , mine sucked up a mans large shirt . Even if the drum seems to spin freely it still could be the problem .
Mar 03, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
At high speed spin cycle sounds like a jet engine...
if your thinking bearing, its part of tub assm not basket hub. $200 part
Kenmore 22422 Top Load Washer Logo
869 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
