Question about Dell Latitude D600 Notebook
Help on no boot
My Computer is not booting up
  • Anonymous Feb 12, 2009
    i bought a dell latitude d600 notebook off ebay with xp pro installed this worked for a couple of hours then the screen froze it would not turn off and had to wait for battery to discharge now when i switch it on it will not boot, will not start in safe mode
  • 3,587 Answers
Not too it black screen? try F2 as it power up.
and, take out battery and run on AC only.
Posted on Mar 28, 2008
No boot disc
Try n use a friends pc, go to gateway web site. Create an emergency boot disk, start your computer up from there. When booted create a boot disk n use this to problem solve your startup problem. Which windows r u using. Normally when you switch it on if you continuously press either f5. Or f10 the computer will boot into emergency boot mode. Hope this helps
Jan 01, 2014 | Gateway NE56R41U Black
Can't boot from flashdisk
USB thumb drives give you the ability to mobilize information, but they also have the power to act as a boot disk for both Windows and Mac computers. If you have a bootable thumb drive that you want to boot your computer from, you can easily set it up in the BIOS menu of your Windows computer or through the boot menu in Mac's OSX.
Plug your USB thumb drive into the computer. Boot the computer and follow the on-screen prompt to enter the BIOS (Basic Input/Output System) menu. You should "Press a certain key Usually the DEL or the F2 key to enter BIOS setup" or something similar when you turn your computer on. Follow the directions to enter the BIOS menu. Scroll over to the "Boot" menu in the BIOS screen. Change the primary boot device to USB port or something similar depending on your BIOS menu. Restart the computer with the USB thumb drive in the USB port. b> Mac b> Plug your USB drive into your Mac's USB port. Turn on the computer while holding down the "Option" button on your keyboard. Wait for the boot menu to appear with all of your bootable devices shown. Use the mouse to select your USB thumb drive from the boot menu. Wait for the computer to boot using your thumb drive. Hope this helps.
Jan 03, 2013 | IBM ThinkCenter S51 (8171Y1A) PC Desktop
Reboot with cd
Hi Friends
If you want to Boot your computer from CD or DVD in this case you have to set the "Boot Sequence" from BIOS. Follow then mention below instruction and try.
  1. Restart you Computer and press the "Del" key from when computer is boot.
  2. Your will see one Blue Screen with lots of option.
  3. Select the "Boot configuration" and select "Sequence"
  4. There you will see some option like "First Boot :- HDD, Second Boot:-CD-Rom, Third Boot :- Floppy Drive. ect.
  5. So what you should do you just select the "First boot :CD-Rom"
  6. For move the option you see the down help windows and configure the boot sequence .
Thanks to Visit Fixya...
Sep 07, 2012 | Lenovo 3000 Y410 Laptop
When device is getting on device is hanging in windows mobile version screen
If its not booting up correctly you can either clean boot the device or reflash the firmware. Note this will return trh device to its default state and loose any information stored on the device.
Clean Booting the CN50
If the CN50 seems to be locked up, try warm booting and then cold booting the computer. If neither method works, use a clean boot to get the computer up and running for further troubleshooting. When you clean boot, the CN50 only loads files and applications that are absolutely required by the operating system. A clean boot returns the CN50 to an "out of the box" or factory default state, so that you can run diagnostic tests to troubleshoot the normal boot processes:
To clean boot the computer using the mobile computer:
1 Remove the battery pack from the back of the CN50.
2 Reinsert the battery pack and press the Power button.
3 When the CN50 starts the boot process, simultaneously press <and > until the IPL Boot Configuration Menu appears on the screen.
4 Press 2 to select Force Clean Boot and then press 0 to select
Continue with Boot.
The CN50 executes the clean boot. This process takes a few minutes
The clean boot process erases the CN50 memory, including all applications and data files in the object store. To preserve applications through a clean boot, store them in the Flash File Store.
If you need any more help then please do not hesitate to contact us:- or TEL +44(0)1202 620955
Jul 15, 2012 | Intermec CN50 Handheld Mobile Computer -...
When I restart with the boot disk I made (or the intstallation disk) the computer starts up normally. I am not being prompted to scrub it. Help!
you need to change the boot order of the computer to boot from cd instead of hard drive.
When you first start up the computer you should see a message to press to enter setup the most common keys are:
  • Delete
  • F1
  • F2
  • F3
  • F5
  • F10
  • Escape
  • Insert
  • Control + Escape
  • Alt + Escape
  • Control + Alt + Escape
  • Control + Alt + Enter
Once you've entered setup you should be able to find a selection something to the effect of boot order chage the fist boot selection or primary boot device to the CD rom so that the computer will boot from the boot disk instead of the hard drive
Apr 19, 2011 | Iolo Technologies DriveScrubber
Wen I turn on PC using Windows Vista I get the warning no boot device available. What does this mean?
Hi britchel07,
I see that you are having issue booting into windows on your system.
I can help you with your concern, we can first try to boot into the Hard drive manually, follow the steps below,
1. Power your computer ON then keep on tapping the F12 key on top the keyboard until you get the Boot Menu screen,
2. On the Boot Menu screen select the Hard drive it maybe listed as SATA or HDD, but if it is not listed then we may need to try a different option, on the Boot Menu the Hard Drive should be the first one on the list.
3. Highlight the Hard Drive on the list then press Enter to make your computer boot into the Hard Drive.
if this does not work then your Hard Drive may not be detected by the machine, why I really can't tell there are many possible causes, but we can try other options to see if this can be rectified.
I believe that you have a Desktop machine, we will need to open up the tower to check if there are lose cables inside from the Hard Drive to your systems Motherboard, inside you should see a Flat Orange like red colored cable sometimes Blue that should be your SATA cable going to your Hard Drive from the Motherboard, try reseating the SATA cable to make sure it is properly connected and also check the SATA power cable just to be surem it should also be a black flat cable connected to the Hard drive just right nest to the SATA cable, after reseating the two cables try turning the computer ON again and see if the system will boot into Windows.
If still you get the Error no boot device found then you may need to get a new Hard Drive for your system.
I hope that this will be helpful with your concern, Have a nice day.
Apr 06, 2011 | Dell (Inspiron 531) PC Desktop
How to boot to CDROM? unit: IBM Intel Pentium 4 1.8 ghz
At power on, you should have an option to hit F12 or another key for boot options. From there choose CD/ROM
Aug 08, 2010 | IBM Netvista Intel Pentium 4 2.4GHz /...
you cant boot to a network with an empty computer,
Oct 08, 2009 | Toshiba Satellite 5005-S504 Notebook
HP Inkjet C3100 - Boot up problems
try going into the bios by pressing F2 as the computer boots, then go to boot options and choose to boot from the hard drive first, cdrom second and floppy drive third (if you have one) then save the changes and exit the bios. You computer should boot as normal now.
I hope this helps
Jan 07, 2009 | Office Equipment & Supplies
My nec versa 2635cd wont boot from cd
most computer boot sequence is set up in the bios, you can access the bios if you watch the computer start and press the appropriate key, some are f2 as it boots or escape.
then enter bios look for the boot ......and make the cd first boot option.
then save the bios most by pressing f10 to save it, the computer will reboot......
then say press any key to boot from cd.
hope that helps
Oct 19, 2008 | NEC Computers & Internet
Dell Latitude D600 Notebook Logo
Alun Cox
