Question about Mattel 2009 Hot Wheels Monster Jam 6975 IRON OUTLAW 164 Scale Collectible Truck
What is the ratio of cement to ironite matle in ironite flooring
    Problem Solver:
  • 9 Answers
1 part ironite, 4 parts portland, 2 parts clean water for a heavy duty floor
Posted on Aug 08, 2010
WHAT THE EXPRETION "CORE-BORED" MEANS
when drilling cement floors to add new mounts for equipment theres two ways to do it , Impact = useing a impact drill to chip cement out of hole Or core boring , this uses a hollow round drill to slowly saw the cement out of hole this tends to make a less ragggy hole in cement so hole is smoother and has less fractures in it (takes longer to do than first method )
Sep 07, 2014 | Drills
What is the correct ratio for mixing concrete?
generally about 2:3 water to cement. it should say on the bag, if it is too watery add more powder, if it is too thick add more water
Jan 15, 2013 | Building Materials
Where does the rubber membrane go when tiling a bathroom floor
tiles on wooden floors will always move and crack the grout/tiling cement
therefore the rubber membrane goes down first with out nails and then everything is laid on top
that way when the wooden floor moves , there is a water proof membrane to prevent the water from rotting the wood over time
Jun 14, 2017 | Home
What is the sand and cement mix ratio for a patio
Hello. The typical volume-ratio for a self-mix concrete in this application would be one part Portland cement to three parts sand. For a stronger pad (capable of higher stress loads) it would be as low as two parts sand, but this is not necessary for a standard patio pour. The gravel should be three parts, more will make it tougher to achieve a smooth finish. Re-cap: Portland cement - 1 part, sand - 2 or 3 parts, gravel - 3 parts. Hope this helped.
Apr 12, 2011 | Garden
What do I use and how do I keep the shower base level.
Hi, As with most shower trays, you must bed the tray down onto a suitable floor ( ie; solid and dry) surface using a bedding down mixture. Weak mix sand and cement is ideal for this purpose. Mix sand and cement at a ratio of about 5 or 6 to 1 and spread out on to the area where the tray is going. NOTE: it is important that the mixture is spread out evenly and touches all of the underside of the tray. Make sure you seal the floor a day before using a water and PVA glue sealant mixture so that the mortar will stick. Tap down the tray BY HAND or by using your fist, and use a spirit level on all four edges until the tray is completely level ( or as near as you can get it) I have provided a link for you with the full installation instructions. Hope this was of help to you.
http://www.americh.com/site/index.php?option=com_docman&task=cat_view&gid=19&Itemid=12
Jan 14, 2011 | Americh A4234ST Single Threshold Shower...
EMBLEM, ELJER TUB. DO I CEMENT THE NEW TUB INTO THE FLOOR? HOW MUCH CEMENT AND WHAT KIND?
The tub should just sit on the floor, and caulked around to seal out any water. If it as a fiberglass tub, you might want to put some grout under the bottom to help support it.
Apr 29, 2009 | Home
Tile over a cracked cement floor
You can get a crack membrane to put over the cracks. First use a primer on the floor, this is a primer just for this application, then put membrane on top of primer. these products can be found at home depot or lowes or any tile store.Also do not use cheep thinset. the better thinset is more flexible and will absorb any movement. The cement board would not work as they will move or flex and cause the grout to crack and tile to loosen
tom
Nov 13, 2008 | Mk Diamond 154861 MK-100 7'' x .060'' x...
Tile floor installing
you need to have all the equipment and goods. The tiles, cement to fix them, the cutter, a level, a rubber hammer, a marshy, a water drum, and paper.
1. use the paper to cover all the area that may be damage.
2. level the surface
3. put the title in the level floor, without pasting them, and measure the titles you need to cut, to fix all the are, measure and align them.
4.with the marshy apply the cement to the area
5. Put the titles and with the robber hammer hit them softly.
6. went finish clean them with a soft rag and water.
Oct 02, 2008 | Measuring Tools & Sensors
Mattel 2009 Hot Wheels Monster Jam 6975 IRON OUTLAW 164 Scale Collectible Truck Logo
162 people viewed this question
Top Mattel Toys Experts
thegtw
Nikki  Mclean
Nikki Mclean
Tracy E
Level 1 Expert
Are you a Mattel Toy Expert? Answer questions, earn points and help others
