Solution #1
posted on Mar 28, 2008
verify the water supply to the valve first, second verify valve to icemaker works(unit has dual valve at rear bottom of fridge, switch plugs, then press water dispenser and see if icemaker fill with water ) if fills icemaker is bad , if not valve is bad. replace one or the other.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To:
GE GSH25JSTSS Stainless Steel Side by Side Refrigerator
GE 23.1 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black-on-Black
GE (PSS26MSRSS) Side by Side Refrigerator
GE GSS20IEP Side by Side Refrigerator
GE Profile? GCG1580LSS 15" Built-In Trash Compactor with 1.4 cu. ft. Capacity, Hidden Controls & Remo...
GE Monogram ZICS360NRRH C... Bottom Freezer Refrigerator
GE Monogram ZIR36NMRH Refrigerator
Can you Help with these Refrigerators problems?
Hotpoint FFA70 Bottom Freezer Refrigerator
ffa70 bottom freezer high...
Hi the red light indicating... Answer This...
Repair Service
Find Refrigerator Repairman Near You:
