Question about Peg Perego John Deere Gator HPX Ride on Toy
Bought on craigslist and it rides fine on flat land. As soon as I brough home on small hill it clicks and does not move. Is this a transmission/drive sytem problem? Paid $100 should I junk or fix
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Do both wheels move in all gears?
Posted on Jun 14, 2012
Cub cadet lt1042 will not back up a small hill
When is the last time you changed out your drive belt?
Oct 02, 2014 | Cub Cadet LTX 1042 KW 42" 18HP Kawasaki...
My Craftsman riding lawn mower LT2000 (2002/2003) stopped moving. The drive belt seems to be loose. The engine starts and cutting blade engages fine. Was working fine but stopped working when it started...
there should be a drive belt tensioner somewhere on the belt, it usually works off the clutch/brake, when you push on the brake it apply's the brake and also takes the tension off the belt to stop it from moving.
Not sure of your ride on mower but that is how my ride on mower works so I hope this helps.
May 19, 2014 | Craftsman Garden
Transmission
Get an engine transmission warranty through an oil company like castrol or something. Should cover it for free no matter what happens for the period of the warranty.
Nov 23, 2013 | 1996 GMC Sierra
When first start my husqvarna yth 150 runs fine goes up hills plenty of power after running for while starts loosing power wont go up hills will stll move on flat surface
Hi, it sounds like the hydrostatic drive is getting too hot. Remove the battery and battery cradle and clean all grass and debris from around the hydrostatic drive and cooling fins. Also check the fan wheel on the hydro is not damaged. Regards Phil.
Apr 28, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Won't pull itself up hill
You didn't indicate what model of tractor you have but most likely it is a hydrostatic drive problem . The power is transfered from the engine to the wheels by hydraulic pressure. If the fluid level (hydraulic oil) is low then it won't drive correctly. Follow the owners manual to check the fluid level. The other possibility is if this is an older unit it could actually have water in the oil.The water will not operate correctly. Where did the water come from? The transmission housing, is vented to atmosphere. On a hot humid day, while you're driving, the fluid and housing is heated. When the tractor cools, the ambient humid air enters the housing. When night rolls aroound the water condensing inside the housing. If you're lucky this transaxle may have a drain plug in the bottom. You can remove this and see if the oil looks milky. If it does, I'd drain it all and refill with fresh oil.
Jul 18, 2010 | Husqvarna 24HP 54" Yard Tractor ()
Peg Perego John Deere Gator HPX Ride on Toy Logo
109 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
