Question about Sony Bravia KDL-40S4100 40 in. LCD TV
Vertical lines I found a Sony Bravia KDL-40S4100 on a loading dock at my work. Upon turning it on, it has vertical lines on the laft portion of the monitor that look similar to a test pattern. Changing the inputs doesn't help. Is the monitor shot, or is it possible to have repaired?
  • 187 Answers
SOURCE: i have a sony bravia model # kdl-40s4100 40 in
If you have the led light on, then you need to replace the mainboard.
If no led light then replace the powerboard.
Posted on Jun 06, 2009
  • 10 Answers
SOURCE: how do I connect my laptop to a Sony Bravia model
Two options are available to you-
1. Through VGA Cable(Same cable which goes from CPU to PC Monitor)- For Video.
Take to PC Mode from MENU -> EXTERNAL I/P -> PC.
2. Through HDMI Cable.
Take to HDMI Mode from MENU -> EXTERNAL I/P -> HDMI.
If Still No Video
CASE1- 'NO Signal' Message Comes, then toggle the laptop screen with Function Key (depending upon laptop company).
CASE-2- 'Un-Supported Signal' Message comes then adjust the resolution to 1024*768 or 800*600 or as mentioned in Manual.
Please intimate me if any other problem comes after that.
Posted on Jun 22, 2009
vinnyq
  • 157 Answers
SOURCE: My Bravia KDL-40S4100 lost all 3 of it's HDMI
There is a problem with the processor. The only way to resolve this issue is to replace the main board. It is called the A board in your TV.
There are two for this model and the correct one will depend on what your serial number is.
Part numbers are as follows:
part # 185709211 for Serial #
1,000,001 - 1,350,000
1,700,001 - 1,750,000
1,800,001 - 1,804,270
1,804,271 - 1,818,372
1,818,373 - 1,830,000
list price: $504.87 core charge: $680.00
part # 185709231 for all other serial numbers
list price: $505.87 core charge: $600.00
Posted on Nov 09, 2009
Testimonial: "Thanks, Now I wonder who all shares the same problem and if Sony is willing to do something about their defective products..."
  • 51 Answers
SOURCE: I have a 42" Sony Bravia KDL-40S4100
Probable power supply
Posted on Dec 15, 2009
  • 100 Answers
SOURCE: I also have the same issue with Sony Bravia
The inverter or ccfl lights are faulty will need to be tested on workbench or try on a warranty if still valid
Posted on Jan 06, 2010
Sony bravia KDL-50W800B got only vertical lines when turn on.
You need to take it to a TV repair service, preferably one that specialises in Sony TV's. There is nothing you can do to fix this yourself.
Jun 16, 2016 | Sony Televison & Video
I have a Bravia KDL 40BX421 that suddenly has green vertical lines on the bottom 1/4 of the screen. These lines are in a background bar that is mostly a reddish shade.
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/.../1127410-thin-vertical-lines-cover-screen-samsun...
Mar 7, 2009 - 30 posts - ‎25 authors
Hi guys, Ive had this TV for about a year now - all of a sudden thin vertical lines havecovered my screen (show in link below) No matter what ...Missing: 40bx421
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... hi i have a sony bravia mdel # KDL46EX523. i have horizontal multi colored lines ... My TV has the following symptoms: - Horizontal lines from top to bottom of .... thick(like 1-1/12 inch) and a couple of green vertical lines next to the black one.Missing: kdl ‎40bx421
Flat Screen TV Has Lines Going Through Screen - Possible ...
Dec 16, 2015 | Televison & Video
Sony tv KDL-40S4100 vertical lines on right side
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 09, 2015 | Sony Bravia KDL-40S4100 40 in. LCD TV
Sony faults
this could be your t-con board, but knowing sonys it most .likely your main panel meaning your screen,
Aug 17, 2014 | Sony Bravia KDL-40S4100 40 in. LCD TV
Sony bravia KDL 40s4100 vertical lines on left
LOD (lines of death) are a known service issue with the Sony bravia line of TV's contact Sony and cross your fingers. Wish I had better news for you. I had a 52w4100 and Sony arranged me with a service center to get it taken care of.
Aug 18, 2012 | Sony Bravia KDL-40S4100 40 in. LCD TV
Vertical blue stripe on my Sony KDL-40S4100
Was the telvision impacted? Usually a Blue line on various tv sets such as Sharp and Sony can also indicate a firmware upgrade being needed. Try that first, as to a panel if this is a panel we have in stock cost could be between $200-400 for the part that part cost from Sony coulb be double if you need to purchase new. Call or reference us if you need TV repair in Colorado 6_2_2012_7_06_05_pm.jpg
Jun 02, 2012 | Sony Bravia KDL-40S4100 40 in. LCD TV
Colored bars on Sony Bravia LCD Digital Color TV Screen
This is a screen tab fault and in most cases will require the screen replacing
Sep 13, 2017 | Sony Bravia KDL-40S4100 40 in. LCD TV
Vertical lines in screen
Are the Lines Symetrical in distance and space? Makes a diferernce..
Jan 21, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony Bravia KDL-40S4100 40 in. LCD TV Logo
82 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
