Question about Villeroy & Boch 9955 S1 Subway Toilet Seat & Cover w/ Quick-Release & Softc
Hi i am looking for Villeroy & Boch seat product no: (9955 S1 01). Kindly, provide me Quotation
    Scholar:
  • 102 Answers
V & B US customer service number used to be 877-505-5350 it has been a while since I used it, but they were very helpful when I did. Hope this helps.
Posted on May 26, 2010
Knob of coffee pot knocked off, Villeroy and boch switch 3, can I find a replacement without buying full pot
www.villeroy-boch.com/.../faq.html?&...en..
https://pro.villeroy-boch.com/en/.../technical-data.html
Jul 05, 2014 | VILLEROY AND BOCH USA Villeroy n Boch...
Villeroy and boch toilet parts
attach 2X4s behind it to ensure its stable. I had same problem but used that wood to reinforce it (covered with hardy board & paint) and reattached it and wall is very strong and toilet does not move.
Apr 27, 2013 | Villeroy & Boch 9955 S1 Subway Toilet Seat...
I have a VB slow close toilet seat and one of the pins is broke. I'm also in need of the two nylon sleevs that hold the screws in place on the bowl. Is it possible to purchase these items?
Since no one welds part back together (unless you can) so you will have to buy them, but I suggest you call the manufacturer as they will send you the needed parts for free.
Jan 02, 2013 | Villeroy & Boch 9955 S1 Subway Toilet Seat...
Leaking water into bowl
Your question has been posted under the heading of Villeroy & Boch. If this is the brand you are working on then the flush valve is set up like the old Mansfield Fush valves and is replaced in the same way. But if VB is the brand you might try calling 877-505-5350 it is or was their US number. Hope this helps.
Mar 29, 2010 | Villeroy & Boch 5C06 01 P8 Twist One Piece...
My Villeroy and boch toilet's water level inside the toilet is always low. I was seeing if there was a way to increase the level inside the toilet, not the tank.
V & B toll free number was 877-505-5350. I hane only worked on one in 25 years and they were very helpful. Hope this gets you in the right direction.
Feb 09, 2010 | Villeroy & Boch 9955 S1 Subway Toilet Seat...
How can I replace toilet seat for the Subway model? It does not seem accessible without taking the toliet down
There are little toggle bolts hidden at the back underneath the seat. The location and the image is shown in this PDF:
http://www.villeroy-boch.com/fileadmin/picdb/produkte/bad/daten/XX/9955Q1.PDF
It's difficult to describe how to disconnect them but pretty easy to figure out just fiddling with them once you find them.
Good luck.
Aug 02, 2009 | Villeroy & Boch 9955 S1 Subway Toilet Seat...
One of the softclose buffers on the Subway toilet seat has pulled
Each soft close 'Barrel' is handed - one left - one right. (One is grey - the other white).
Most soft close errors occur because the seat hinges come loose. When this happen, the barrels slightly pull-out of the seat. (There are silver discs on the barrels - These should be tight against the seat).
Once the barrels become loose the first thing that happens is the top cover won't soft close - but the seat still does.
To rectify - puch both barrels tighly into fitting and tighten the hinges. (See below).
To tighen the seat hinges you need to get a flat headed screwdriver underneath the chrome round hinge cover - and 'flick off'. Underneath is a X head screw which id also hexagonal. You can either tighen both by spanner - or screw driver. (sometimes these can be tricky - but it will come off).
If both cover AND seat do not soft close AND the barrel silver discs are firmly located against the seat - the barrel has probably broken.
If so - spare parts can be obtained here:
http://bathroomstudio.co.uk/villeroy-boch-spares/cat_131.html
Jun 15, 2009 | Villeroy & Boch 9955 S1 Subway Toilet Seat...
Villeroy & boch flush mechenism needs to be replaced
This problem is either two things:
1/ The water inlet valve is letting by and going down the overflow pipe. (Connected to the main centre column). You can check this by taking off the lid off.
2/ Centre column seal at the base is letting by. You can unclick the centre column by pushing the two paddles either side.
Then lift out the centre column and check the grey washer at the base. You can turn this washer around and see if this solves - if not the column has probably has a part snap off.
You can get spares here:
May 27, 2009 | Villeroy & Boch 98M2 S1 01 Bellevue Toilet...
Villeroy & Boch 9955 S1 Subway Toilet Seat & Cover w/ Quick-Release & Softc Logo
359 people viewed this question
Top Villeroy & Boch Home Experts
J.D. Browning
J.D. Browning
Lisa Zhuo
Lisa Zhuo
Level 1 Expert
Are you a Villeroy & Boch Home Expert? Answer questions, earn points and help others
