Question about InFocus ScreenPlay 4805 Multimedia Projector
7 wide black vertical interference bars on all screens. Equally spaced with normal looking segments. Like the stripes on a flag. On both maintenance screens and program screens, too. The bars are "fizzzy" almost like a bunch of up and down lines jammed together. I took the covers off and I see no apparent problems. (Loose connectors, burnt components.) There's a lot of stuff underneath the motherboard that I cant get to, though
  • Ken Roller May 14, 2010
    The lines don't pulse so much as they squiggle. The bars look like someone took a pen and a yardstick and drew a bunch of black vertical lines close together, only they vibrate. I'm not sure what you mean by the engine. Is it a cable or a socket that connects it? What's it look like? I DID discover that the fan for the lamp is bad. It moans like a hurt animal and won't turn, but it spins by hand easily. I thought5 it might be messing up the display, but when I disconnected it, there was no change in the display.
I had the same problem and had to send it off to the company. I was definitely the motherboard which had to be replaced. The lines went away.
Posted on May 31, 2010
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 269 Answers
If these lines are pulsating, it sounds like the connection at back of the engine where it connects to the main board. you can try to reseat it and see if that fixes it. otherwise it could be one or the other. really hard to tell without a test fixture. if the bars are fuzzy like they look like they may be underwater then that would be a bad light tunnel.
Posted on May 11, 2010
  • patrick reagan May 14, 2010
    you can try new fans, that would be cheapest,but from my experience, the main board is what causes the fan problem and could be causing the lines.. Either way, with no fans the unit won't run.
Fix samsung plasma vertical black bar
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Mar 27, 2016 | Samsung PN50A450 50 in. Plasma HDTV
My TH-50PZ80U has developed a vertical black bar, about 3 inches wide, at the far left margin of the screen. How do I get rid of it?
Need to know if the bar is cutting off picture or if the picture is being squeezed to fit the remaining space
Nov 03, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
How to center a screen?
Horizontal centering is performed in the service menu. Beware! You can mess up a lot of stuff in this menu.
Aug 02, 2009 | Toshiba Televison & Video
Panasonic SC-PT460 - Little black box covers half of screen
Can you describe the 'box'? Is it the top half, bottom half, a little of either? What kind of TV do you have?
I suspect you might be noticing the aspect ratio of the various source programs being presented differently on a wide screen than you are used to. DVD programs come in a variety of aspect ratios. Normal TV is 4x3, that is, 4 units wide versus 3 units tall. Wide screens are more like 16x9, so a 4x3 image presented properly on a wide sceen would have black vertical bars on both sides. That is normal.
Some people are offended by the black bars and TV's are unfortunately designed to allow gross modification of the image to fill the space. That is akin to taking a photo of yourself and stretching it to fit an improper frame. That probably wouldn't be very flattering to you and certainly wouldn't be accurate. Which is more important - the picture or the frame?
Apr 08, 2009 | Panasonic Audio Players & Recorders
Very faint vertical bar moving across plasma screen.
OK... Left to Right is weird. I'd say one of two things.
Refresh Rate might be to low or to high, but i doubt this to be the cause. I'll put my money on external interferences. Something like another PC screen? TV? anything magnetic and I've even in some cases noticed PC side panels too close to a screen can cause this.
Dec 29, 2008 | Computers & Internet
Nec plasma tv 42MP4
these plasma vertical black lines are notorious. there's a video of a fix on this plasma tv repair site. good luck!
Jul 29, 2008 | Samsung PPM42S3 42 in. Plasma Television
Green vertical lines on the screen
Sounds like you may have some bad filter capacitors in the convergence board. Better take a close look at them before they damage the chips. Good Luck
Ed
NC Electronic
Mills, Wyoming
Nov 15, 2006 | Hitachi 42V710 42" Rear Projection HDTV
Wide black bar on bottom of screen
I you know how to repair electronics its not a hard fix. The worst case would be the vertical output IC but im thinking th its nothing more then a capacitor in the verticle sweep circuit The average cost to repair this should be around 75 to 125 bucks. Good Luck
Jun 01, 2006 | Toshiba 32A60 32" TV
InFocus ScreenPlay 4805 Multimedia Projector Logo
269 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
color wheel light...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
