Question about Amana ALE443RAW Gas Dryer
Loud bumping sound from dryer. - Amana ALE443RAW Gas Dryer
  • Amana Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
DryerLoud bumping sound from dryer. - 2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Posted on May 12, 2010
How can i test my dryer to find out if the motor is bad
If the drum goes around, your motor is working.
If the drum doesn't go around, the belt could be off or broken, or the motor could be bad.
Try to listen for the motor starting up as you turn the dryer on. If it sounds like it is running (an initial 'bump' followed by a quiet hum), chances are it is a belt problem.
If you can't hear the motor running, or it is a loud buzz, or there is the smell of burning insulation or smoke, chances are your motor is bad.
It is also possible that the selector switch that controls everything is not turning the motor on (bad selector) or the overheat safety switch is malfunctioning, but these need to be tested by taking the dryer apart.
Nov 18, 2014 | Crosley CDE6000 Electric Dryer
Plastic piece over beater bar when hit sounds so loud
Sounds like you have found the problem. The bearings get hot and melt the housing. Replace the nozzle may be the solution.
Jan 09, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
Loud noise coming from dryer when clothes are added
-Every thing are worn out. The tumble is not round any more, seal is loose so any loose thing or seal hit a bump. It will make sound.
This is normal for old dryer.
Mai
Dec 07, 2013 | Samsung Dryers
Loud bang when I hit a bump with my foot on the break. No sound at all if I hit a bump without my foot on the brake. What is this?
indicates that lower suspension rubbers are broken and should be inspected by an accredited front suspension professional service center
Aug 09, 2017 | 2005 Nissan Murano
My dryer is making a very loud rumbling sound now when I turn it on. It's still working, but obviously needs some repair. I'd really appreciate your help! Thanks, Bridget
The drum on some dryers are driven by a rubber covered wheel beneath the rear of the drum. When the dryer is at rest, the drum sits still on that wheel. The longer the dryer sits still, the more the drum pushes down on that wheel and eventually causes a slight indentation in that wheel. When the dryer runs and then stops it sits at a different spot on the wheel. After a number of years of use, this wheel gets a number of these indentations and as the wheel ages the rubber loses its ability to return to its' original shape and causes a "bump" as the drum contacts these indentations. Enough of these "bumps" in a row sets up a vibration causing a rumbling sound that gets worse and worse. The vibration in my Whirlpool got bad enough to move the dryer around the floor.
There is a kit available to repair this problem for around $35 that consists mainly of a new wheel and belt and it is fairly simple to do.
Jul 03, 2011 | Dryers
Dryer makes bumping noise and also a loud squeaking noise can please help us. thank you
Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Dec 01, 2010 | Dryers
Loud bumping sound when operating
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Oct 19, 2010 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Loud noise when i hit bumps and turn the sterling
chances are that noise is the ball joints telling you they are dry and have no grease and they should be replaces fairly soon
Nov 04, 2009 | 1999 Ford Explorer
The dryer (Bosch Nexxt 500) makes a loud grinding noise when rotating. Any idea what this may be?
The noise could be your drum rollers need lubricant or replacement.
When the drum rollers get flat spots on them they will make a bumping/thumping type of noise.
The grinding noise sounds to me like the drum rollers are in need of lubrication.
Sep 26, 2009 | Bosch Nexxt 500 Dryer
Maytag Neptune dryer increasingly loud.
Sounds like you need new drum rollers installed, when they get old they squeak,squeal, and make loud bumping noises.
Sep 25, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Amana ALE443RAW Gas Dryer Logo
132 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
