Question about TruTech PVS31170S1W 17 in. LCD Television
Setting up comcast rng110 cable box with tv
I just got this tv and am trying to set up my comcast cable box with it. I got the remote to work for the tv, and if i plug the cable cord directly into the tv i get the regular cable channels but the tv does not havec any picture when I hook it up to the cable box. How do I get the comcast cable box and the tv to work together?
  • Loretta Northcutt
    Loretta Northcutt May 11, 2010
    how are you connecting the cable box to the television i.e. are you using the coax cable or rca cables or which?
SOURCE: Trutech 35" LCD connecting to cable box
The official website for this item is http://1800customersupport.com/trutech. Try emailing them, or call them at 1-888-252-6252. Trutech is the store brand for Target stores. So many companies make their products. This website isn't the official site for all Trutech products,just some of them, like this 15" LCD TV.
Posted on Aug 20, 2007
  • 73 Answers
SOURCE: have hd cable box to hdtv, need cable remote to control hdtv- no code
It can be solved, but you have to buy a universal remote, and not use the comcast remote.
http://www.iconnectdots.com/ctd/2007/05/targets_trutech.html
Posted on Jan 09, 2009
FixFree
  • 12 Answers
SOURCE: Connecting antenna -- No Signal
Hi Shelly_Eddie,
Here are a couple of things to try:
Is the TV set to antenna or cable? Use the menu settings
Be sure a wire end is not bent outside of connection, i.e. coaxial cable wires sometimes bend or hide back into the sleeve.
Reset the TV and do a channel scan, unplug and see what happens.
Let me know how you make out. Good luck.
Paul
My Website
Posted on Jan 28, 2009
DerStrom
  • 103 Answers
SOURCE: need remote control code for universal remote activation
Most universal remotes have an automatic code search. If you google your universal remote, you should be able to find instructions, including how to do the auto-search. If you still have problems, just let me know. I'll do a little more research for you. Good luck! Der Strom
Posted on Apr 02, 2010
pctech1
  • 1940 Answers
SOURCE: I need to re-tune a TruTech 19" flat screen for cable
Trutech Service number 1-888-6TRUTECH
Posted on Jul 10, 2010
Olevia channel setup
With the remote of dish you will control the dish box. The tv control is only necesary to set the signal on channel 3 or Aux to get the signal from the dish box.
Now Your main remote will be dish remote control. Set your tv on channel 3, then turn on the dish box, and use normally.
Oct 02, 2008 | Olevia LT26HVX 26 in. LCD Television
Samsung LN-T2353H Remote Control for Pace RNG110
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Jul 22, 2017 | Televison & Video
Data light is on my Comcast RNG110. What does
It's probably on for the same reason mine was. It's on when the box is receiving data, or when there is an 'unread message.' For me, I had a message from comcast advertising their new service. You probably have the same
You can check your messages by going to the Main menu. You can get to the Main Menu by clicking the 'Menu' button on your remote, then hitting 'Main Menu,' which should be the second option.
Feb 06, 2010 | Televison & Video
Can't get my hannspree remote to work with comcast
10030 for the comcast dvr remote. Code is from NEC
Oct 02, 2009 | Hannspree HT09 28 in. LCD TV
Volume not working
You need to connect RCA cables Left/Right "audio out" on the back of your cable box to the "audio in" on your TV. Also, if you have a LCD HD tv you need to set the audio output to Analog NOT Digital.
Should work as I had a similar problem with a Comcast HD box and Remote.
Jul 07, 2009 | One For All URC-3021 Remote Control
Sylvania lc370ss9 remote problem, comcast
you have to turn off the power save setting
Mar 01, 2009 | RCA RCR450 Remote Control
Need remote codes for emerson lc320em9 so can program cable remot
If you only wish to power the TV off/on with the remote, there is an alternative. Plug the TV into the outlet on the back of the Comcast box. In the Setup Menu for the Comcast box there is an option to make the outlet switched or unswitched. Select SWITCHED then the TV will turn on/off with the Comcast box. The
LC320em9 will maintain the previously selected input.
Jan 16, 2009 | Televison & Video
Sound cuts out- cable tv
I had the same problem when I installed the new HD Comcast cable box (DCH3200), initially with my CRT through RF, then with my HDTV through HDMI. Problem solved when I replaced the box with the Comcast RNG110 I got from my local Comcast. It is a neat miniaturized box and it works extremely well on HD. There is no power switch on the box so before activation do not forget to put it on with the remote (cable, power, the green light will come on).
Aug 09, 2008 | Sony STR-DE595 Receiver
LASONIC DVD PLAYER NOT WORKING WITH COMCAST BOX OR SOYO TV
you have to plug everything to the tv. only thing them are good for is recording to some other unit. like dvd recorders
Mar 05, 2017 | Lasonic DVDP | DVD-7050 5.1CH
TruTech PVS31170S1W 17 in. LCD Television Logo
785 people viewed this question
Top TruTech Televison & Video Experts
Bill Wright
Level 1 Expert
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
