Question about Weber Genesis Silver B Grill
Looking to bring a webber bbq back from the US and fit in ireland
Can you tell me the natural gas pressures in the US and are they compatable with ireland?
  • Weber Master
  • 2,517 Answers
The uk and ireland nat gas burns at 8.5 wg so the us i belive is lower but if you are going to bring one back you could change the reg but US threads are no the same as uk and ireland this where your problem would be
Posted on May 25, 2010
How do I convert a natural gas BBQ grill to propane?
You change the nozzle or jet or the complete regulator that regulates the flow of gas. I have seen some company's that will sell you the part or the regulator. You will have to go the the Webber and see if they even offer the part. Or maybe a BBQ dealer who sells and services Webber might do it for you. I know most companies will not sell the part or parts because of the liability. Good luck.
May 21, 2014 | Cook's Essentials Smoothie Maker Work Top...
I have a 3week old Webber Q220 bbq and it does not ignite - Plenty of gas but igniter does not work - what to do please?
If it's no longer sparking, then it sounds like your igniter battery is dead. Unscrew the igniter button and replace the battery.
Jan 01, 2014 | Weber Genesis Gold B Grill
Can a weber kettle be run on natural gas
They can be run on natural gas however since 2009 Webber stopped selling conversion kits for their grills. (Liability issues) Anyway the regulator in most cases and all of the burner orifices need to be changed. On high end grills it is a matter of changing the regulator and adjusting the burner orifices and air flow to obtain the proper burner fire. You may be able to contact a BBQ specialty shop and they may sell you a conversion kit after you sign a liability release form. Most will insist that you bring the grill to the store for conversion AND that they install the NG regulator at the place of use. By law.... all gas conversions must be performed by a licensed technician.
Thanks for choosing FixYa,
Kelly
Dec 30, 2010 | Weber Grilling
I am looking for a conversion kit for a BBQ Galore Turbo from NATURAL GAS to Propane
BBQ Best (www.bbqbest.com.au) have natural gas conversion kits so you can convert your bbq from LPG to natural gas. Great site and good advice - Simon the owner was the only guy that could help me out.
Jul 30, 2010 | Barbeques Galore Turbo Classic 3-Burner...
I have a BBQ Galore STS 4-burner grill. How can I
You need to look at the orifices to see if the hole on it is big for Natural Gas and small for LP!
Mar 14, 2010 | Barbeques Galore Turbo STS 4-Burner 169544...
New BBQ chaged from propane to NG
Hello. The conversion of any gas appliance usually requires changing orifices, regulator and burner. Then once those changes are made you can adjust the gas flow. The difference in the orifices is this.
Natural gas orifices are larger than liquid propane orifices simply because the gas pressure for the natural gas is lower.
I would double check to be sure that you have installed the correct orifice. Also, you can adjust the amount of gas by turning the orifice in or out, using that socket.
Please call the uniflame technician directly if you still have a problem 800-762-1142 Joe
Mar 11, 2010 | Uniflame Corporation LP Gas Outdoor...
Liquid Propane vs. Propane (like used for BBQ)
They are the same thing.
The propane you buy for your BBQ is liquid in the bottom of the tank. At the top, it comes out as a gas, which you run through a regulator and then into your grill. If you by some chance turn the tank sideways, the valve inside will shut and keep the liquid propane from coming out. If it did you could have a serious fire.
However, there is a difference between what most folks call "Natural Gas" and propane. If you have gas piped into your home, it's natural gas and not propane.
Natural gas dryers won't run right on propane (LP Gas) and vice versa. There is usually a conversion kit you can buy to switch them over.
Oct 14, 2009 | Dryers
Converting Weber Genesis Silver B from LP to Natural Gas
Hello...I have the same grill and want to do the same conversion...From my research, you need to drill out the three orifices with a size #53 wire gauge drill bit. ( this resizes each orifice to 12000 BTU's each, which the grill is rated at 36000 BTU's).Then remove the existing hose and regulator. Replace the hose with a Quick disconnect compression fitted hose. The NG supply needs to have a pressure regulator installed, with a shutoff and quick disconnect fitting installed. Connect the hoes from the grill to the supply, and fire it up...THIS IS WHAT I INTEND ON DOING TO MY GRILL,BUT YOU DO THIS AT YOUR OWN RISK>>>
May 07, 2009 | Weber Genesis Silver B Grill
Weber Genesis Silver B Grill Logo
88 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
paulcarew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
