Question about Frigidaire GLEQ2152ES Electric Dryer
My dryer stops drying after 10 min. All the lights flash on the right hand side. I've tried different drying settings and different amounts of clothing. Nothing works. What's wrong?
My dryer does the same thing. Additionally, it is not heating what so ever. Clothes are cool and damp, and heating vents at back of dryer are cold to the touch.
Posted on May 12, 2010
My AEG T37400 lavatherm standanlone tumble dryer works for a turns of the drum then stops.
Alarm conditions during operation of the dryer
The LEDs begin to flash if one of the following malfunctions occurs:
  • NTC open (the LEDs flash in sequence from right to left)
  • NTC short-circuited (the LEDs flash in sequence from right to left)
  • If the START button is pressed for more than 20 seconds while a cycle is in operation all the LEDs flash.
25679338-hf2jxxovvq5cn05mugly0fcq-5-5.jpg If the microprocessor identifies one of the conditions listed above, operation of the dryer is interrupted; the LEDs continue to flash in order to warn the user of the malfunction.
If the error is eliminated, the dryer returns to normal operation when the programme selector knob is turned to RESET and the drying cycle is re-selected.
Dado
May 04, 2015 | AEG Dryers
Leq2152ee1 dryer does dry but keeps stopping if put on any setting over 15 min. Dryer stops single beep and top four lights blink.
MAY BE BAD MOTOR WITH BAD WINDINGS USUALLY STOPS AFTER 20 MINUTES OF USE? OR HEATING ELEMENT IS OVERHEATING? DUE TO BAD VENTING? THERMAL CUT OFF KEEPS SHUTTING IT DOWN?
May 08, 2014 | Frigidaire GLEQ2152ES Electric Dryer
Dryer is tumbling but no heat - when I reset it shuts off after about 10 min and the Drying, Cool Down, and Extended Tumble lights are all flashing.
Janet McDonald,
I understand that you are having trouble with your dryer not heating and not running a full cycle and shutting off with the Drying, Cool Down, and Extended Tumble lights flashing. What I suggest is to give your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back and try to start a cycle. If it does not complete the cycle and shuts off with the lights flashing, I suggest to either contact the manufacturer or a local appliance technician. This way you will be able to locate the cause of this issue and have it resolved.
-Best Regards-
Jan 14, 2014 | Frigidaire AEQ6700FE Affinity Electric...
Frigidaire dryer - turns off after 10 min???
Have you ever cleaned out all the link from inside the dryer cabinet, it can cause this problem.
Jun 08, 2012 | Dryers
Hi I've Got A Hotpoint Aquarius CTD40 Tumble Dryer
that isn't a model number,open the door to the dryer,look around the opening where you put the clothes in and send the full model number,
Dec 21, 2017 | Hotpoint Dryers
I have a CDA ci992 with no instruction manual. I cannot get it to JUST dry. I just need to know which setting to put it on. Any chance you can help? I've tried searching for an instruction manual...
Lisa set the time required on the Drying time control right hand side for high temperature up to 130 mins max and left hand side for low temperature up to 90 mins max. Now set the washer timed dial to the drying emblem (3 vertical wavy lines) next to position 8, then finally you need to push in all 4 control buttons on the left of the thermostat. It should now work according to my wife. Dave
Sep 02, 2011 | CDA CI592 Front Load All-in-One Washer /...
The dryer stops after about 15+ seconds.
No, but mine started doing the same thing today. Did it once before and same- started working again. Any suggestions for last poster and myself?
May 31, 2010 | Frigidaire AGQ6000ES Gas Dryer
98 Dodge Caravan-why are the led lights on the AC control panel flashing?
The blinking lights in the rear wiper rear defrost area can be reset by holding 2 buttons of the 3 on the left hand side. The top and bottom buttons. Turn the key on and hold them for about 10 sec and they should start flashing differently. Just let it do this. After they start flashing different. It will take 5 to 10 mins. Then one or more will quit flashing all together. If they don't after about 20 min reset them again it can take about 5 trys sometimes before they all go out.
Feb 21, 2010 | 1998 Dodge Caravan
Yellow light flashing dodge caravan1998 reset afer 30 min rear wiper defrost ac
The blinking lights in the rear wiper rear defrost area can be reset by holding 2 buttons of the 3 on the left hand side. The top and bottom buttons. Turn the key on and hold them for about 10 sec and they should start flashing differently. Just let it do this. After they start flashing different. It will take 5 to 10 mins. Then one or more will quit flashing all together. If they don't after about 20 min reset them again it can take about 5 trys sometimes before they all go out. Good Luck
Nov 13, 2009 | 1998 Dodge Caravan
Frigidaire GLEQ2152ES Electric Dryer Logo
325 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
