Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Model # 9p5540 c104
Some channel are tyoo dark to see
  • 44 Answers
Try adjusting the Brightness of your TV...
Kindly give a feed back to Improve my statistics and to see If it was helpful for you...
Thanks and Regards
Posted on Mar 28, 2008
SOURCE:
1994 mustang GT 5.0 blows 20 amp EEC fuse
Have a short. This procedure may help out. Need test light and volt meter.
1. Disconnect C104 and see if the Red (RD) wire out of the Constant Control Relay Module (CCRM) (pin 12 and/or 24) is shorting to ground, to verify which side of the connector the circuit is shorted.
2. If the RD wire no longer indicates a short to ground after disconnecting C104, inspect the engine harness feeding the injectors, Idle Air Control (IAC) solenoid and Canister Purge (CANP) solenoid for chafing against bare metal on top of the engine.
3. If the RD wire still indicates a short to ground after disconnecting the C104 connector, inspect the harness to the secondary air injection solenoids, EGR Vacuum Regulator (EVR) solenoid, Mass Air Flow (MAF) and Powertrain Control Module (PCM) for a short to ground.
INFO Tip C104 is a 42-terminal connector located at the rear passenger side of the engine, near the A/C accumulator.
Nov 16, 2013 | Cars & Trucks
I need this older magnavox tv I bought to go to channel 73, at this time I can only go to 69. It is model # 27TS73-C104. I have sat. reception and need the channel 73. Thanks!
I am assuming you have a dish network duel tuner. You can actually use any channel under 60 for the second t.v.. You can find all that information in that big pamphlet that your remote comes in. It also sounds like your in antenna mode, (please make sure your tv2 side is on before you do this) go to the second tv go to menu system set up scroll through until you see input type or something along those lines, make sure you select cable, then do a channel scan/ setup it should pick it up.
Sep 04, 2010 | Philips Magnavox 27MS343S 27" TV
Looking for user manual for philips magnavox tv. 9P6044 C104, 3911Q1716. Trying to find out how to hook up my VCR to this tv. It has s viedo, video, L audio & R audio holes on front side of tv. I want...
Barb..be sure you run a TV signal through the VCR first. And then a coaxial from the VCR to the TV. This is the easiest solution for now. And set the vcr to tv/video {channel your movie is on}hit record and hit tv/video and watch your tv for another movie!
Feb 06, 2010 | Philips 9P6044C 60" Rear Projection...
Mita AI-3010 with error code C104 after coming out of sleep mode.
indicative of faulty main board or firmware, can be updated with compact flash card
Jul 30, 2009 | Kyocera KM-1510 Copier
I have aMagnavox 9P6040 C104.The picture is extremely poor.
The problem is the fluid in the Blue and Green CRT's needs replaced. ( ethylene glycol ) It not something you should attempt if you've never done one. The average price with most shops is around $250.00, and your other concern, there is no auto convergence on that model. It's all done by remote in your menu and in the service mode, but that's not your issue, just get the fluid replaced and your back in business. Have a nice Holiday Weekend.
May 23, 2009 | Philips Televison & Video
Double picture
Youre convergence Ics need to be replaced. Use STK392-120 Ics you will need to replace both of them. You can get replacements at the following link and they provide free instalation instructions with pics.
http://servicemanuals.vstore.ca/
Jun 15, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
78 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
