Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Increased drying time; removal of lint behind tumbler ???
I thoroughly cleaned all the lint from the door, beneath the lint basket, and I noticed when I inspected the inside of the tumbler drum, that there seems to be an accumulation of lint at the bottom behind the holes at the back of the tumbler. There must be a way to empty this. Please let me know ASAP
  • 1 more comment
  • GadgetMan513 Mar 29, 2008
    The vent starts at the rear of the dryer and exits through the ceiling straight through the attic and then out through the roof . There is a covered roof vent The dryer is 10 yrs old and has worked flawlessly, but like I said before, the drying time is a little longer than normal. I just want to know how to access the lint that has built up that I can see through the holes in the rear of the tumbler. Thanks, in advance for any assistance you can give me.
  • Anonymous Aug 26, 2008
    I am at work and do not know my exact model, but it is probably 10+ yrs old. I too am experiencing long drying times. I see ALOT of build up in the rear of the tumbler. How can I access this to clean it out? I am going to check my venting as I suspect the venting might have build up as well but I can not figure out how to get access to the rear of the tumbler.
  • robert samples May 11, 2010
    i can tell you how to do that but describe your vent to me from the back of the dryer to the vent under the house to the out side if you have a bird screen on the out side door see if its lint blocked
I have a top loading Kenmore High capacity dryer that is over 10 years old, it has been working very well, unfortunately when cleaning the lint filter my wife dropped a piece of paper down the lint duct hole. The paper evidently fell to the bottom of the lint duct. I am unable to reach the paper from the top of the dryer where the lint filter is inserted.The dryer now makes a grinding type noise when it is turned on. Can you tell me how to reach the paper and remove it
Posted on Sep 06, 2008
No water from spray on base
I had same problem. Remove all fluid from machine, I used a wet dry vac. As someone else said unscrew the 2 screws that hold the filter basket. Take out the filter basket and clean thoroughly. Find plastic hose that is now visible under basket and pull up and remove that (noticing where the slot is to put it back when finished) and pull the screen off top of hose and clean that as well. I then vacuumed out that hose with my wet dry vac. Reassembled everything and now works perfectly.
Oct 15, 2014 | Rug Doctor Mighty Pro X3 Value Pack - Blue
Drying time increased
you may need to check your heating element in it.
Oct 17, 2013 | Maytag Neptune MDG5500AW Gas Dryer
The clean light came on and I cannot find my manual to find out how to clen it. Plaeas help
Always turn coffeemaker OFF and remove the plug from the electrical outlet before cleaning. Lift up the reservoir cover. Remove and discard the paper filter and ground coffee. The filter basket can be washed in warm, soapy water and rinsed thoroughly, or cleaned in the upper rack of the dishwasher. Dry all parts after use. Do not put any water in the unit once the filter basket has been removed. Wipe the area under the filter basket with a damp cloth. Remove the carafe from the heating plate. Discard any remaining coffee. The carafe and lid can be washed in warm, soapy water and rinsed thoroughly, or placed in a dishwasher. The carafe and carafe lid should be placed on the upper rack only. Do not use any scouring agents or harsh cleansers on any part of the coffeemaker. Never immerse base unit in water or other liquid. To clean base, simply wipe with a clean, damp cloth and dry before storing. Fingerprints and other blemishes on the stainless steel housing can be washed off with soap and water or a nonabrasive cleaning solution. Wipe warming plate with a clean, damp cloth. Never use rough, abrasive materials or cleansers to clean the warming plate. Do not dry the inside of the water reservoir with a cloth, as lint may remain.
You can print the manual on this link:
http://www.cuisinart.com/share/pdf/manuals/dcc-1200.pdf
Feb 15, 2011 | Cuisinart DCC-1200 Coffee Maker
Fisher paykel smartload dryer degxius does not dry cloths. Drum is hot, and lint basket is empty. I have cleaned lint out behind lint basket.
Check and make sure that your exhaust tube and outside vent are not clogged. If they are clean them out and you may have to buy and new lint screen that come with a seal whcih will solve your problem. Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ . This forum will further help you through your problem.
Sep 04, 2010 | Fisher and Paykel DEGX1 Electric Dryer
My dryer gets hot but does not dry efficiently. Clothes are still very damp after more than 1.5 hours. I noticed that the lint trap is not really gathering any lint.
your problem might be in the actual vent to the outside. If the vent to the outside from the drier has a clog and will need to be cleaned. Without the proper ventallation the clothes will not dry. I suggest pulling the drier out and removeing the vent hose that connects to the outside and clean it. Once this is done you shouldn't have any problems
Hope this helped
Dave
Feb 23, 2010 | Whirlpool LER4634J Electric Dryer
I recently had an ventless Bosch dryer installed (WTE8600US) and I keep receiving this message F:03 which the manual says "check hose for condensation outlet". any advice?
For the F:03 problem on the Bosch Axxis (WTE86300US) do all the things mentioned in Solution #1 above. Sometimes the lint in the condensation filter channels (those that run from front to back)can be quite stuck. Use a pipe cleaner to get in there or a garden hose with a spray nozzle. However there is one more crucial step not mentioned in the manual or in Solution #1. Once you remove the condensation filter you will see a small plastic panel on the lower wall of the condensation filter slot. Slide a flat blade screwdriver and gently pop it open. Under the panel is a small chamber where you will find a slurry of lint/water which is what clogs the condensation outlet. With latex gloves reach in there and clean it out. Blow hard into the dryer through the condensation hose to clear up any last bits. Pop the panel back in place. This should fix your problem.
Dec 13, 2009 | Bosch Dryers
How do i clean my cuisinart grind and brew coffee maker? i can't find my instruction booklet and it needs to be cleaned. thanks!
From the manual I found online here.
CLEANING AND MAINTENANCE COMPLETELY CLEAN AND DRY ALL PARTS AFTER EVERY USE. Always turn coffeemaker OFF and remove the plug from the electrical outlet before cleaning. Open the reservoir lid*. Remove the grinder basket lid by using the recessed area on each side of the lid. Then remove Grinder Basket. Open Filter Basket Door. Remove Filter Basket Cover, Filter Basket and Filter Basket holder. The grinder basket, grinder basket lid, filter basket and filter basket cover can be washed in warm soapy water and rinsed thoroughly, or cleaned in the upper rack of the dishwasher. Dry all parts after every use. Do not put any water in the unit once the grinder basket has been removed. Wipe the area under the grinder basket with a damp cloth. If water gets into the grinder motor, the motor may become damaged and may malfunction.
DECALCIFICATION Decalcification refers to removing the calcium deposits which form over time on the metal parts of the coffeemaker. For best performance from your coffeemaker, decalcify the base unit from time to time. The frequency depends upon the hardness of your tap water and how often you use the coffeemaker. To clean, fill the water reservoir to capacity with a mixture of 1/3 white vinegar and 2/3 water. Turn the coffeemaker on by pressing the ON button. One cycle should be sufficient to adequately clean the coffeemaker. When the cycle is completed and the five beeps sound, turn coffeemaker off. Repeat operation, this time using fresh cold water.
Sep 09, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
I have a grind and brew and can't get the grinding basket out to wash.
Open the reservoir lid. Remove the grinder basket lid by using the recessed area on each side of the lid. Then remove Grinder Basket. Open Filter Basket Door. Remove Filter Basket Cover, Filter Basket and Filter Basket holder. The grinder basket, grinder basket lid, filter basket and filter basket cover can be washed in warm soapy water and rinsed thoroughly, or cleaned in the upper rack of the dishwasher. Dry all parts after every use.
Sep 01, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Dryer goes with 3-4 cycles to dry load of clothes
unplug the dryer.
Open the top lid.
Remove the front panel.
Inspect the blower wheel attached to the motor.
If it moves on the motor shaft replace it.
If iy does not move on the motor shaft, clean the lint out of the exhaust from the blower wheel to the rear of the dryer.
Mar 12, 2009 | Maytag Dryers
FEX831CSO dryer stopped heating mid-cycle
Apr 22, 2010 My dryer would not dry the clothes either. the heating element would only come on once then nothing. The high limit thermostat was bad. Pull the electrical plug. Remove the top cover and the thermostat has an orange/black wire to it. It is hard to get to the screws but I was able. Then I found the element would cycle many times but not stay on long enough to dry the clothes thoroughly - I found the culprit - the motor driven fan creats a suctionin the drum and the hot air from the rear coil is pulled thru the drum, thru the front door (via the holes in the door's inner face) down thru the lint screen, thru the outer fan housing and out the exhaust. My problem was that the door's cardboard backing had seperated and along with the trapped lint clogged the door's holes and restricted the air flow. I took the door off, seperated the 2 halves, removed the cardboard and cleaned the lint out. The dryer is now working like new. Summary: The high limit thermostat was bad probably from cycling so much and the air flow diminished slowly over time to the point I did not notice until the clothes just wouldn't dry. Check the air flow first. Hope this helps
See less
Dec 29, 2008 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
217 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
