My HP c4750 printer (wireless only) goes into sleep or idle mode after 10 minutes and won't recognize my print request unless I power it off and on. Any thoughts?
How can i reset the chips
Posted on May 11, 2010
Disable power saving mode
Sorry, but you will NOT be able to DISABLE the power saver mode on this printer. The printer will still go into "power saver mode", but it takes longer to do so, if you set diffrent as default time delay [ Two power saver modes: (1) print to standby mode 35 Watt, user-definable 1-30 minutes, default 3 minutes ; (2) print to powersaver mode 4 Watt, user-definable 5-60 minutes, default 10 minutes ].
See also:
Dell 1250C problems with sleep mode
Oct 01, 2014 | Dell 1320c Laser Printer
Printer not responding hp photosmart 6525 after going into sleep mode
My printer will not print after sitting for about 30 minutes. As soon as I turn it off and then back on the job I previously sent, prints out. I tried changing the amount of time before it goes to sleep but this does not correct it and does not seem to be related. You can hit the check mark to wake it up but it still will not print until turned off and then on. Source: How do you turn off the sleep mode in a HP 3600 printer?
This is the only solution is see and it didn't solve the problem
Nov 30, 2013 | Office Equipment & Supplies
Power save mode sleep
Hi Brian,
The printer goes to sleep mode irrespective of what cartridge you have in the printer. Printer goes to sleep mode if the printer is not in use.
Regards,
Sean
Jun 04, 2013 | HP LaserJet 5500 Printer
HOW DO I TURN OFF THE SLEEP MODE ON MY PRINTER BROTHER MFC 7420
Setting the Sleep Time reduces power consumption by turning off the fuser inside the MFC while it is idle. You can choose how long the MFC is idle (from 00 to 99 minutes) before it goes into sleep mode. The timer is automatically reset when the MFC receives a Fax or PC data or makes a copy. The factory setting is 05 minutes.
To turn Sleep Mode off press Menu/Set, 1, 6, 2. Then use the dial pad to enter the length of time the MFC is idle before it goes into sleep mode, in this case 00 so it wouldn't go to Sleep mode at all. Press Stop/Exit.
Feb 04, 2011 | Brother Office Equipment & Supplies
Have an officejet 6500 wireless printer and the printer goes to sleep and wont wake up without unplugging it
Power Save Mode.Just press the on/off button or wait for the printer to wake up when you start a print job.
Nov 07, 2010 | HP Officejet 6500 Wireless All-in-One...
4350 nosiy while in sleep mode
If it comes out of "sleep mode" every 10 minutes, and you haven't touched the printer or sent any data to the printer, try unplugging the LAN cable for 15 minutes. If the printer stays in "sleep mode"either the formatter is bad or whatever is on the other end of the LAN cable could be bad. If you can put the printer on another PC to see what happens, that would really help you out.
Jun 19, 2010 | HP LaserJet 4350 Printer
Prints fine then if printer is left for 10 - 20 minutes printer will not print at all until you reset it (open front cover and pull out then put back in paper tray)
for this problem you have to disable the sleep mode on printer
On the control panel,
Configure device menu ->
Resets submenu ->
SLEEP MODE to OFF.
this is better that altering the SLEEP DELAY under the System Setup submenu
Oct 23, 2009 | HP LaserJet P2015n Printer
Mar 25, 2009 | HP LaserJet 3600n Printer
HP photosmart c7280 wireless problem
Your wireless printer might frequently lose its communication with the computer and hence might not print all the documents when you want. Such an issue arises when there is interference in the wireless signals between the printer and the computer. get more information for HP Wireless Printer Problems .Hope this helps you.
Mar 02, 2009 | HP Office Equipment & Supplies
181 people viewed this question
jasbo
jasbo
