Question about Sony DSC-T30 Digital Camera
Camera vibrates for half an hour - Sony DSC-T30 Digital Camera
    Problem Solver:
  • 5 Answers
Replace lens assembly.
Posted on Mar 06, 2011
Hyundai reverse cycle air con inside unit, intermittently vibrates for about half hour even though powered off
you have to find were it comes from, if fan motor and compressor are not powered up check the revers valve, relay and transformer you can use your insulated hand (Glove) to feel any vibrations comming from them as some transformers and relais tend to vibrate under load
Jan 05, 2015 | Hyundai Heating & Cooling
Vibration encountered on a 98 Honda CR-V only occurs when steering wheel turned to max left or right....or when making 90 degree turns.
replace the rear diff fluid with honda dual pump fluid. drive it for about half an hour and replace the fluid again.
Nov 28, 2010 | 1999 Honda CR-V
Vibrating and shaking
the sstepper motor of the focus assembly has slipped out of its track. that motor is a very powerful one which can cause the vibration.  once u change the mode to take the picture the motor should run in both direction to make some calibration. you cannot disable it. in the preview mode the optical assembly returns to it closed position and then the motor is switched off.
since it is a cybershot you need to be very careful in handling the camera if you have any plan to open it. it is recommended to be taken to the nearest service centre. any way the wheels might need replacement
Jul 04, 2009 | Sony Cyber-shot DSC-T300 Digital Camera
Wobbly lens
Half mm or so movement is normal in fully extended lens. If camera is not giving any error display during function then every thing is just fine in it.
Feb 04, 2009 | Sony Cyber-shot DSC-W130 Digital Camera
Plz help
remove the SD Card and the batteries. Wait for half an hour and then insert two new batteries. Do not put the SD card in as yet. (Waiting for half an hour or more allows the camera to reset itself).
Now try switching on and good luck.
Dec 27, 2007 | Kodak EasyShare C653 Digital Camera
Blurred pictures
I had the same problem. The solution is in the manual but it is not straight forward. You have to set steady shot to auto when the shutter button is pressed half way down. The vibration warning will still show. At this point the camera is sensing low light. The to need to make sure the flash is set to always on. The flash setting for background will not turn the vibration warning off.
Dec 10, 2007 | Sony Cyber-shot DSC-T100 Digital Camera
Sony DSC-T30 Digital Camera Logo
52 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
