Question about Acer Aspire L100 PC Desktop
My Acer Aspire L100 doesnt start. Only the fan works but not the system. I had this problem for 2 years but when i switched off the button and then on again after some tries it worked but now even the ON light doesnt beam
    Scholar:
  • 193 Answers
Ok, try to locate the battery on the mother board, before that make sure the main power cable is unpluged.
remove the battery , and then remove your ram carefully, wait for 10 minuts, the replug every thing, and dnt forget the power cable :)
it should work.....if not, replug everu thing again and plus the vga...
Posted on May 11, 2010
Acer aspire l100 will not boot but fans run
Try removing/disconnecting the hard drive and see if the BIOS boots up, if it does the HDD is causing the problem. Are you getting any beeping codes on start up, if so how many and hoe long in between?
Dec 06, 2011 | Acer Aspire L100 PC Desktop
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    My aspire L100 will not boot. When on button pressed blue light comes on and then goes off straight away and fan starts Ok but nothing else
    You may need a new power supply....also check your internal fans to make sure they are spinning. Make sure memory is seated properly. Motherboard may also be in question. Try unplugging letting it sit for a few then plugging back in.
    Aug 05, 2010 | Acer Aspire L100 PC Desktop
    My Acer Aspire L100 PC Desktop won't start.. when i press power button it only flash LED light jus one time but no HDD sound or CDROM working sound. only CPU fan works thas bout it...Any help? pls
    Do you see anything on the screen?
    Try the following things:
    1. Try starting the computer with only the battery
    2. Remove the battery and try booting with only the power adapter
    3. Try removing and replacing your memory
    Could be a bad power supply or bad battery. After you try the above steps, report your results.
    May 22, 2010 | Acer Aspire L100 PC Desktop
    Thanks for the response to my Acer L100. have checked the cables and they are fine. have noticed the fan doesn't start up when the computer is switched on....could this be the problem???
    The CPU fan should turn on when the PC is powered on, and then it usually slows down until the workload on the processor causes it to heat up, then the fan spins faster, it might also be a power supply issue, but if your able to boot and its giving you messages and not shutting down then you should re-install the operating system.
    Nov 18, 2009 | Acer Aspire L100 PC Desktop
    HI THERE, MY L100 DOESNT WANT TO START UP. ON START UP THE SCREEN SAYS MEDIA TEST FAIL, CHECK CABLES AND THEN ASKS FOR THE CD DISK TO BOOT UP. I HAVE OPENED IT UP AND IT SEEMS THAT THE FAN DOESNT SPIN. ANY...
    Sounds like your hard drive might be bad, its also possible that your cables are loose, follow the cable from your hard drive to your motherboard and make sure they are plugged in securly. If they are and your still haveing the same message then its possible that your hard drive is bad or at the very least that somehow the operating system has become corrupted. If you have the software that came with the computer, then you will need to reinstall the operating system.
    Nov 17, 2009 | Acer Aspire L100 PC Desktop
    Acer Aspire L100 overheating
    You could try a new cpu fan and heatsink. They are normally inexpensive. if this does not work make sure all the case fans are working and check to see if your ram is overheating
    Dec 22, 2008 | Acer Aspire L100 PC Desktop
    Acer aspire sudden death my acer aspire L100 can't boot, only the noise of the fan and the DVD player. nothing else can anyone help please ?
    Dear sir
    if u don't get eny display 1 you need to cleane RAM then it's still not working you need to chek power suply.. and chek yr cables is attached is right or not.
    simple.. if u need more help please contact feel free.. thianks..
    Dec 15, 2008 | Acer Aspire L100 PC Desktop
    Unwanted System Shut Down
    Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} ok guys this is the problem i work for Acer and basically if you own an aspire L100 then you have to be prepared to modify your little bad boy because of acers poor design and a crappy little fan the anything inside the case feels like its on holiday in the tropics what you have to do is side mount 2 extra fans with separate 12v supplies and your system will never overheat or die on you if you have any questions on how to do this just email me :-) me
    Aug 10, 2007 | Acer Aspire L100 PC Desktop
    Acer Aspire L100 PC Desktop Logo
    154 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
