Question about Poulan "" Push Mower
Clogged fuel filter
Mower runs for a short period of time and then seems to run out of gas and "choking" out.
  • Poulan Master
  • 7,482 Answers
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
Posted on May 15, 2010
Lx288 mower quit running I thought it was out of gas so filled with gas started up but wouldn't keep running.
  • If unit will not run without choke , the main jet in carb is clogged and the carb needs to be cleaned out.
Nov 07, 2015 | Garden
Mower started and ran great for about 50 mins. and then stopped. I added gas as it appeared to run empty. It started back up, but would only stayed running for a few seconds, before turning off again. ...
You did not mention whether your mower has a 2-cycle or 4-cycle engine. 2-cycle engine may require 2-cycle oil mixed with the gas to lubricate the pistons/cylinders.
4-cycle engines do not require mixing gas & oil as they have a separate sump for oil. These engines are quite easy to maintain and will last for many years. The most common problem is the fuel delivery system. If you allow the fuel to run low, debris sitting at the bottom of the tank is picked up and can clog the strainer (if so equipped). Check for a clogged in-line fuel filter and replace as needed. Occasional cleaning of the fuel inlet and strainer may be necessary; some disassembly is required. The carburetor jets also suffer from blockage usually caused by varnish residue from gasoline if the mower was allowed to sit for long periods of time without the fuel being drained or at least treated with some type of fuel stabilizer (Sta-Bil is one). If you have time, open up the carburetor and spray all the fuel passages with Gumout Carburetor cleaner to dissolve said varnish. Jiggle the choke mechanism while spraying to dislodge carbon build-up at the butterfly valve. And if you have a compressor, blow out these passages with pressurized air. Poking them with wire is a NO-NO. If it has a paper-element filter and it looks like you can plant grass on it, it is time to replace them. Does it have a re-usable/washable air filter? Clean the filter element with an air filter cleaner solution (or dishwash detergent) and re-oil (I use K&N filter oil) once dry.
Always use clean gas (your gas container may be contaminated over the years) and an ounce of STP carb cleaner per gallon of gas usually keeps things clean.
Apr 04, 2011 | Garden
Will start but only run less than a minute
If it starts on choke,runs a short period after the choke is pushed in it is a fuel starvation issue, remove the fuel hose in the tank and replace the filter on the end, at the same time check the condition of the hose up to the carb, any signs of splits or cracks and the hose will need replacement.
Feb 08, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Bike is running like the choke is on . no power
old gas, fuel filter in the tank, air filter clogged on carbs , sometimes suzuki likes to run on 93 octane , more responsive.
more than likely it filter if you let sit for long periods and same gas
ethenol produces water,after long periods, let me know ..
Oct 22, 2010 | 2000 Suzuki VS 800 Intruder
Runs with choke out.. dies if pushed in. Will only run a short time then seems to flood. After that it will continue to leak fuel from under the air filter somewhere until the tank is empty... crazy....
Try rebuilding the carb. It might be your float is messed up. You can also get some carb and choke cleaner and take the sediment bowl of and clean everything in it. Give extra attention to the float and needle valve. They might have some build up that won't let it work properly.
Also your gas cap might not be venting properly.
Oct 09, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Mower has to be chocked to run
Oftentimes, this problem is the result of mowers left outside in ambient air that is high humidity. This, in turn, allows algae to grow inside the carb fuel float bowl and/or inside the fuel tank if left out for extended periods (one month or longer). Also the same thing will cause air filters to clog rapidly with mold and mildew - slowly at first, then more rapidly as the mold continues to grow. Get out the carb cleaner in spray cans and go through every ported passagewway in the carb body then reassemble using CLEAN screws, gaskets and all interrior parts. Any residue mold or mildew will continue to grow - and it can grow in gasoline!! Imagine that!!
Jun 23, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Engine only runs with choke full on. Dies when off full choke.
Hi Dave, it sounds crazy, but try this. Check your gas cap. It could be clogged, causing a vacuum to occur in the tank, and therefore not allowing the carb. to take on gas. It usually take 10-15 min. for this to occur. The next time you run the mower and it starts to stall out, loosen the gas cap and see if it begins to run again. If it does, then you know that the gas cap is clogged.
Jim
Jun 04, 2009 | Craftsman Garden
Redmax weed wacker wont stay running
Have these unit been stored with fuel in them or sitting around for a long period of time? If so the carbs may need to be overhauled. Also check for a clogged fuel filter and vacuum test the fuel lines for cracks.
Apr 12, 2009 | Garden
Yard machine 139cc will only run short time with choke
Check the float and the adjustment screw on the bottom of the carb. Usually if the float stays up it will continue to leak gas and also will only run on choke. Spray some carb cleaner in there and try to get rid of any debri also try changing your air filter or cleaning it
Feb 08, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Poulan "" Push Mower Logo
88 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
